04-11-2001, 06:00 PM | #1 |
Member#: 447
Vehicle:1999 RSTI WRB |
Help! I need help with turbo 99
Hi folks...
I have a EJ22T on MY99 SOHC and a JC sports Custom Turbo. It uses a T28-T3 hybrid. I have a TCII and a S-AFC, Walbro fuel pump, and 440 cc RC Injectors. I have a boost gauge, EGT and oil pressure (not connected yet). The EGT is connected to the header up pipe to the turbo. I have done a complete ECU reset and My S-AFC settings are all correct and I have leaned it out 35-40% accross the board for both hi and lo throttle. My lo throttle is set to 0% and hhi is 50%. For the first five minutes after the ECU reset I have a nice pull from 3000rpm to 5000 rpm and I get EGTs at throttle at about 1200 F But then after a while the CE light comes on and I can't rev past 4300 (I beleive it is in limp mode, since it bouces on 4300 like the rev limiter). And when a do another ECU reset it does the exact same thing The MAF is fine I have changed a new one too and reset the ECU but this still happens. It goes into Limp mode... I'm going to the dealer to scan the error, but whatever they tell me I think you guys know. (probably knock or fuel problems... I think) but even if they tell me, how do i correct the problem. I can't lean it out any further since I tried -50% and still no difference. I have a rough idle... goes up and down from 900 rpm to 600 and sounds close to dying. sometimes it does die... I have tried the deceleration feature on the S-AFC but it still has a rough idle. Also anyone know how iridium plugs are rated for cold or hot... does it even matter? Anyone know whats going on or can help... thanks in advance....
04-11-2001, 06:08 PM | #2 |
Member#: 2188
Vehicle:2004 Impreza STI 82 BRAT with 12 in. lift |
Are you venting the BOV to the atmosphere or the intake tract?
04-11-2001, 06:14 PM | #3 |
Member#: 2003
W. Canada
Vehicle:'99 BGP Legacy GT '98 QS Legacy L (auto) |
FEI (For Everyone's Info) It's vented back into the intake track.
04-11-2001, 06:18 PM | #4 |
Member#: 526
Vehicle:1995 Supra Turbo Red |
Instead of leaning it out, richen it up. Try it and tell us how it went.
Sean |
04-11-2001, 06:28 PM | #5 |
Member#: 689
NESIC
Vehicle:2005 Outback 2.5 XT Champagne Gold Opal |
I highly recommend an A/F gauge as well - you don't get the complete picture with just an EGT, except during steady-state conditions.
Or if you can read fast enough (I can't), watch the O2 sensor voltages on the S-AFC (blue wire mod), and find out what it reads just before, during, and after the engine stumbles. You want to see something like 0.80V or higher. -WaC Wayne |
04-11-2001, 06:57 PM | #6 |
Member#: 2003
W. Canada
Sean - the reason of going with the AFC is to reduce fuel (b/c of 440cc injectors), so why would you want to richen? 440CC injectors are 57% larger than the OEM RS'
04-11-2001, 07:19 PM | #7 |
Member#: 447
Yeah i've tried to richen.. but it back fires and I think that is not really the problem... I think that the ECU and TC and AFC are arguing over settings. I think that since the ECU and the TCII "learn" over time there may be a possibility that if i drive over time it will come to a compromised setting for all three. TCII is ignition and S-AFC is fuel and ECU is being "tricked" by both. I think this is the culprit, it may be getting sensor readings that may be too different because of the 50% lean...
??????????? Guesses - guesses???? thanks for all the help keep em coming... |
04-11-2001, 07:35 PM | #8 |
Member#: 689
NESIC
The RC injectors might be 57% higher capacity. (440-280)/280 = 1.57.
But going the other way, RS injectors are 36% lower capacity than the RC's. (440-280)/440 = 0.36. I would start at -36% instead, and go richer from this point on... -WaC Wayne Edit: richer. [This message has been edited by wac (edited April 11, 2001).] |
04-12-2001, 10:39 AM | #9 |
Member#: 447
at -36% my EGT is at 1200... and when i go to -45 it goes to 1300 i thought lower EGTs mean rich... I was driving for like 15 minutes yesterday before i got the CE light... i'm so mad... I was in 3rd at 3500 rpm... urrrr (what kind of EGT's should i be targeting?)
Thanks! |
04-12-2001, 11:02 AM | #10 |
Member#: 1109
Vehicle:1999 Suzuki Samurai Blackish |
1300 is good - up to 1400 is okay under boost
04-12-2001, 11:30 AM | #11 |
Member#: 2188
But remember the EGT guage needs to be about 1 - 1.5 inches from port #3 for the 1300 ~ 1450 target to mean anything.
04-12-2001, 03:25 PM | #12 |
Member#: 2338
Vehicle:1988 323 GTX black |
I thought if you have a TCII you don't need the S-AFC. I thought the TCII did tend to richen up the fuel (on stock injectors anyway).
Also, the idling problem seems like a blown MAF...except that it kicks in after running fine for 5 minutes. Good luck. |
04-12-2001, 05:27 PM | #13 |
Member#: 2003
W. Canada
HOK is using the 440CC injectors, the TC2 will work w/ the stock injectors, but since the 440CC's are 57% larger, the TC2 cannot compensate for that much of a change.
04-12-2001, 06:49 PM | #14 |
Member#: 699
Vehicle:2002 golf TDI Blue |
Sorry to hear of your difficulties ... this is a great arguement for a aftermarket ECU upgrade though ... no offense
I agree with the assesment that the stock ECU is confused. Too many pararmeters have been changed for the stock ECU logic to compensate or in fact make any sense of what the engine is doing. Joe Hogan |
04-12-2001, 07:19 PM | #15 |
Member#: 447
UPDATE UPDATE....!!!!!
Went to Dealership... It was a speedo error from wiring the TCII... JC SPORTS was a great help... They said they will send up a new unit since they think it is faulty... They have been a great help for my problems... Things work good now... but still hesitating at around 4300 but no CE light I think the TCII should fix the little hesitations... I'll keep on tweaking. THANKS FOR ALL YOUR HELP!... HOK |
04-14-2001, 05:17 PM | #16 |
Member#: 501
International
Vehicle:1998 2.? RS Turbo ;) RBP |
What are you doing for fuel pressure control?
If it is still stock FPR Change it, THEN start playing fith fuel settings. |
04-15-2001, 09:20 PM | #17 |
Member#: 447
yes... stock...
its actually is doing very nicely... I'm getting boost itch.... but i stiall have to find a way to either adjust my wastegate or get a boost controller... how much boost are you running Andre? I'm just at 5 and still i'm pretty fast.... |
04-15-2001, 09:45 PM | #18 |
Member#: 501
International
Watch out for the boost bug...... it cost PLENTY to clean up after it
I am running 0.8 bar day in day out, after ECU & tranny upgrade I hope to run 1.2 bar day in day out. The stock FPR sucks to say the least.... MAJOR restriction inside of it. Dump it and get an SX or something similar for insurance. |
04-15-2001, 10:00 PM | #19 |
Member#: 2003
W. Canada
Andre Vandenberg - just out of curiousity, are you using the stock injectors for fuel? Hence using a RRFPR and Hi-flow fuel pump?
04-16-2001, 07:23 AM | #20 |
Member#: 501
International
Stock MY 98 injectors.
Here is where I'm coming from: I don't care if you 1000cc injectors with 350 lbs of fuel pressure, if you have a restriction, (wich in the stock FPR you do) BEFORE the injectors that decrease the orriface size by more than 50%, you are NOT using your very expensive add-on goddies to it's full potential, since only a SET amount of fuel can pass through the restriction. If it is AFTER the injectors you will NEVER get it to run lean or at stoich since the "backed up" fuel will just sit in the line and raise the pressure to an unmanagable point for the stock regulator. With my set up, (RX-7TT pump, SX ARFPR, gutted stock regulator and stock MY 98 injectors and Field HyperR Fuel controler), I can get it to run rich to the piont where you can SMELL the gas. With race gas (100 octane unleaded) I have run 1.5 bar boost with NO problem. Well, stock Ign maps are NOT good at that boost level, but I did not see ANY J&S activity and EGT's were fine, but the car did not pull smoothly through the rev range. AGAIN, Stock ECU with add-ons are FINE, and SAFE for up to, but NO more, than 10lbs boost. Anything more than that, and you are playing with your future retirement fund and food budget. |
04-16-2001, 08:05 AM | #21 |
Member#: 689
NESIC
Andre,
Are you sure the stock FPR is before the injectors? If so, how does it raise pressure for the injectors? My Bell RRFPR is connected downstream of the stock FPR, which in turn is downstream of the fuel injectors. It goes like this: 1. Fuel tank. 2. Fuel pump. 3. Fuel filter. 4. Injectors. 5. Stock FPR. 6. RRFPR/FMU. 7. Back to fuel tank. -WaC Wayne |
HELP! We need help in Woodside, Queens with a Forester! | rice h8r | Tri-State Area Forum | 1 | 01-12-2008 10:31 PM |
HELP!!! i need help on a UK 1995 Legacy Turbo | plumber | Engine Management & Tuning | 9 | 09-14-2005 02:55 PM |
HELP, I need help w/ Greddy Turbo Timer ASAP, 05 WRX | Ohannon7 | Electrical & Lighting | 3 | 05-06-2005 02:23 PM |
Help ASAP: Need help from someone who knows turbo pascal | Syms | Vancouver Impreza Club Forum -- VIC | 0 | 11-18-2001 03:30 AM |
