Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 06-30-2003, 02:29 PM   #1
azn2nr
Member#: 35276
Default STi WHP?
Has anyone dynoed their STi to see how much horsepower it actually puts out to the wheels, not to the crank?
azn2nr is offline
Old 06-30-2003, 02:36 PM   #2
rally_wannabe
Member#: 15799
vishnu tuning has posted their baseline numbers for their first STi.
Interestingly, my stage 1 made slightly bigger numbers on Pruvens Dyno (I know, different Dyno, different numbers).
not that I think I could hang, but i'd sure like to try.
Wait til those 2.5s start getting modded!!!
oh yah, a few different people have posted STi dyno numbers godspeed did a while back.
rally_wannabe is offline
Old 06-30-2003, 03:55 PM   #3
JDM nut
Member#: 34529
04' WRX STi
White/Silver
I read as low as 248 WHP and as high as 263 WHP for a stock STi.
JDM nut is offline
Old 06-30-2003, 04:22 PM   #4
rally_wannabe
Member#: 15799
that's a whole lot higher than my measley 222.
Old 06-30-2003, 04:47 PM   #5
prost893
Member#: 29710
2004 WRX STi
WRB / Gold
He was talking about WHP - Wheel Horse Power - not CRANK or BRAKE HP. To get 222 to the wheels you would need several decent mods.
prost893 is offline
Old 06-30-2003, 04:55 PM   #6
rally_wannabe
Member#: 15799
see my post above.
vishnu stage 1, 222 WHP.
Old 06-30-2003, 06:25 PM   #7
metoo
Member#: 4764
2004 STi sold :(
forizzle
metoo is offline
Old 06-30-2003, 06:44 PM   #8
deadbolt
Member#: 990
96 Brighton and...
many
Knowledge performance dyno'ed one last week and confirmed my suspicions that their dyno is very conservative, they only showed 228 WHP.
deadbolt is offline
Old 07-01-2003, 03:29 AM   #9
azn2nr
Member#: 35276
DENG! Then why doesn't one just buy a regular WRX at 227hp and pay 10k less? I guess that's "hp" though, not whp huh? Well, thanx for the replies you guys!
azn2nr is offline
Old 07-01-2003, 03:42 AM   #10
Scoobz
Visiting NASIOC Timeout
Member#: 33786
Hmmmm? Doesn't WRX get 227hp at crank and get around 170-185 wheel hp? So 228 doesn't seem so bad.. but the STi i think prob gets closer to 240-260..depending on the dyno
Since the Evo gets like 220-240...
Scoobz is offline
Old 07-01-2003, 03:58 AM   #11
Mr. Grinch
Member#: 34416
2002 BMW M3
Alpine White
For comparison, North american version of the M3 is supposed to be 333hp at the crank, most of them test in the 270 RWHP range but vary from the 260s to the 280s.
Is it possible that being AWD, the STi might see a bit more drivetrain loss than a RWD?
I think your estimate of 240 - 260 for the STi is close. Guess I should search the archives a little more see if I can find more posts on the topic.
Mr. Grinch is offline
Old 07-01-2003, 04:08 AM   #12
Seraph
Member#: 12251
Its not a just a possibility, its a fact that the awd drivetrain in the wrx/sti has higher loss than rwd drivetrains, i believe the order is:
FWD < RWD < AWD
Seraph is offline
Old 07-01-2003, 09:41 AM   #13
Mattr762
Member#: 31624
02 WRX White
uppipe, turbo-back, MBC
Here are some numbers I've seen:
- Dynojet = 255hp / 253 tq
- Godspeed Dynopack 5000 = 255hp / 247tq
- Unknown source = 250hp / torque not available
- TurboXS = 248hp / 267 tq
- Vishnu Dynamics Dyno = 223hp / 222tq
- FIS (mustang dyno) = 255-260whp / 255tq
TurboXS:
Godspeed:
FI-Systems
Mattr762 is offline
Old 07-01-2003, 10:33 AM   #14
strangerq
Member#: 13095
Evo only makes 180-185 on Shiv's dyno.
Honestly sometimes I think these dyno numbers threads are started specifically and intentionally to generate confusion by:
a) comparing wheel horsepower to crank horsepower
b) comparing awd results to 2wd results
and.......
c) comparing numbers acheived on different dynos.
The parent poster makes a big deal out of requesting "wheel" horsepower....then pretends like he doesn't understand the difference between wheel and crank hp. But if he doesn't know the difference.....why specify to begin with? This thread was meant to confuse.
strangerq is offline
Old 07-01-2003, 12:24 PM   #15
JDM nut
Member#: 34529
04' WRX STi
White/Silver
wheel HP vs. crank HP.
Simple, is not that hard.
Drivetrain lost can be anywhere between 10% from a very efficient FWD Honda to 30% from a very inefficient 4WD Jeep.
I think one source of confusion is from the manufacturer's claimed crank HP. A lot of the time they are not correct. One example is the latest SRT-4, Dodge claimed it has 215 crank HP, but it shows 220+ WHP on the dyno...........
JDM nut is offline
Old 07-01-2003, 12:26 PM   #16
azn2nr
Member#: 35276
No, I DO know what the difference btw wheel hp and crank hp. I just wanted to get the numbers and I'm sure that a lot of others did too. The only reason why I added the comment later was so that others WOULDN'T get confused, but I guess some aren't as intelligent to figure that out.
azn2nr is offline
Old 07-01-2003, 12:31 PM   #17
Mattr762
Member#: 31624
02 WRX White
Dodge never claimed that 215 was crank hp. It's very clear (now) that they are referring to wheel hp. Some dyno's are do get about 220 to the wheels.
Mattr762 is offline
Old 07-01-2003, 12:37 PM   #18
strangerq
Member#: 13095
Others such as whom? No one in the thread confused the issue except you, apparently on purpose. And if you know anything about dynos and awd you should already know that you will get a bunch of different numbers as they have been published and republished and discussed over and again for months, on this site and elsewhere.
Old 07-01-2003, 12:39 PM   #19
azn2nr
Member#: 35276
...I guess that's "hp" though, not whp huh? Well, thanx for the replies you guys!
How did I confuse everyone? SOOOORRY! Jeez you guys!
azn2nr is offline
Old 07-01-2003, 12:40 PM   #20
JDM nut
Member#: 34529
04' WRX STi
White/Silver
215 HP is what Dodge put on the factory spec sheet, and in general the factory spec sheet always refer to the crank HP.
Dodge never claimed that 215 is crank HP, but they never said it is wheel HP either.
I don't know why Dodge claimed such a conservative figure. My guess is to help with insurance cost for the car's targeted budget racer customer.
JDM nut is offline
Old 07-01-2003, 12:43 PM   #21
strangerq
Member#: 13095
Just stop the bs ok?
sti whp? silver_surfer Newbies & FAQs 22 04-05-2006 08:50 AM
Stock STI WHP P-TownWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 10-09-2005 06:52 PM
Difference in stock STi whp on different dynos? trhoppe Proven Power Bragging 28 09-01-2005 06:07 PM
STi whp? STiWanabee Proven Power Bragging 31 12-22-2003 01:17 AM
