Brakes & Suspension Forum sponsored by The Tire Rack |
04-30-2003, 11:42 AM | #1 |
Member#: 8351
Vehicle:2002 WRX Wagon |
STi Suspension Discussion
Decided to start a new thread about this, hopefully one that will focus on the STi and not a comparison with every other performance car out there...
-------------------------------------------------- quote:Originally posted by JT-KGY Could someone post the anti-sway bar sizes for USDM STi??? According to another thread http://forums.nasioc.com/forums/show...hreadid=333118 the sizes are: Front 19mm Rear 20 mm Another interesting thing in that the camber is very mild: front -0.3 rear -0.4 I totally agree with gtguy and Paul Hansen. People are saying (or implying) the understeer is incurable without even driving it! Those guys are nuts. There are plenty of well setup WRXs around. The numbers the STi has been turning in are as good or better than any STi (JDM included) I've seen published. Cars with the SAME suretrac front diff, DCCD, and rear lsd appear to drive much more neutrally (from Best Motoring) than reviewers are talking about. So if there is indeed a difference (or is it the "relative" feeling Paul mentioned?), the question should really be--what is different? I haven't seen a smaller front sway bar for the Impreza but an 18mm may help. I know the first thing I'll do after break-in is get a good alignment and get the front set to -1.1 or -1.2 camber. Adding a larger rear sway bar may be an option for some (depending on what class you want to auto-x in). Paul, can you verify the sway bar sizes on the JDM STi? Someone with access to the parts catalog should check to see what the part numbers are for the front struts and springs. I bet they are the same as the normal JDM STi. TRS
04-30-2003, 02:50 PM | #2 |
Member#: 33270
NWIC
Vehicle:2004 STi WR Blue |
Todd, thanks for starting this. It took me a while to search and I finally found Jon's post about the suspension geometry -- only to see that you nicely referenced it here.
I see that Rallispec has an 18mm front swaybar for the WRX. Not a huge change, but maybe a little (whether it fits in the STi is another question). As you mention, if we want to stay in stock autocross class, we can't touch the rear bars, only the front. Too bad, as leaving the 19mm fronts and going to 22mm rears might be a preferred option. I'd be really interested in hearing people's alignment experiences when they get the car (or thoughts now), especially for autocrossing. I have no experience with this sort of thing (I just got Puhn's book which may help my understanding). Hopefully one of the tuners (e.g. Prodrive, Cobb, Vishnu, Rallispec) will come out with a suspension kit. It sounds like it would be really popular (unfortunately, most tuners don't pay attention to autocross classes, not to mention most seem to concentrate on the drag racing giant-laggy-turbo crowd anyway). Any chance anything could be helped by modifying the struts, such as going to the STi adjustable struts? While I may like the lowering springs as well, that would kick me into street prepared / street modified class. At that point I'd be seriously looking at Praxis, Tein+EDFC, DMS, GAB, etc. Kind of frustrating -- the car at MSRP, then add stereo, wheels + tires for autocross, better seats, suspension mods -- what's next? |
04-30-2003, 02:56 PM | #3 |
Member#: 7852
Vehicle:03 White Lan EVO 8 97 Techno-Violet BMW M3/2 |
19mm and 20mm??
It's already tuned with less understeer than EVO's 24mm and 22mm....??? Sigh... maybe that multi-link rear suspension indeed make that much difference. |
04-30-2003, 03:14 PM | #4 |
Member#: 35838
Vehicle:2004 STi White |
Those camber numbers are pretty interesting. I know that my Boxster came with similar numbers, possibly even less, might have been set at zero. Many of the folks on the Boxster board had it reset at -1 or there abouts, and claimed it really transformed the car. I would hope it would have similar result for the Subaru.
Any idea what the EVO comes from the factory set at? Michael |
04-30-2003, 03:41 PM | #5 |
Member#: 35644
Vehicle:04 STi maybe blue |
Okay, you've got a real suspension newbie here .... thanks for your patience if you don't mind answering what will probably be a stream of questions. First two --
what are the negative consequences of changes to the negative camber? Tire wear? Or even that? can't some changes be made through changing air pressure? (If somewhere else would be a better place to ask basic questions, let me know! Thanks.) |
04-30-2003, 03:42 PM | #6 |
Member#: 8351
Yea, I think changing the front camber will definitely help a ton. It did on my wagon.
If anyone has the information, the stock alignment specs of the JDM cars would also be interesting to have. TRS |
04-30-2003, 03:48 PM | #7 | |
Member#: 8351
Check out the "make your car handle like you want it to" thread, among others. TRS |
04-30-2003, 03:53 PM | #8 |
Member#: 35838
As I suspected teh EVO comes from the factory with a more aggressive set up. According to this thread:
http://forums.evolutionm.net/showthr...ight=alignment -1 from the Factory. Michael |
04-30-2003, 05:40 PM | #9 |
Member#: 8351
Here is another bit of info on the suretrac lsd. This is from the MY01 STi description:
---------------------------------------- The New Impreza WRX STi also comes equipped with front & rear “Suretrac” limited slip differentials. These LSDs respond to a torque differential between left and right wheels transferring the torque from the slip wheel to the non-slip wheel. The benefit is that they only activate under drive and do not respond to differences in left & right wheel cornering speed when coasting. This means that at the limit of adhesion torque is transferred from the inside wheel that is losing traction as a result of weight transfer to the outside that has traction. The effect is to noticeably reduce understeer under hard cornering under engine power. The ‘Suretrac’ LSD function, differs from a conventional differential in that it does not have pinion gears and side gears. In their place are two opposing face cams and nineteen cam followers. The face cams are formed with a series of inclined ramps resembling sharp teeth. One face cam has nine ‘teeth’ the other has ten ‘teeth’. The cam followers have special asymmetrically shaped profiles to match the face cams, and they are splined to the differential case. This means that drive through the differential is via the cam followers to the face cams, and then to the axles. When moving in a straight line, there is no relative speed difference between the face cams, which are splined to the front axles. When cornering with no load, each of the face cams is free to rotate independently from the other. Under this condition, the cam followers oscillate freely from left to right. When torque is applied, the cam followers are forced against the face cams, transmitting driving force to the wheels. If a wheel begins to slip, the relative movement between the two face cams, combined with the angular forces of the cam teeth causes torque to be transmitted to the slower turning wheel. The Suretrac differential is lubricated by normal gear oil, with flutes on the side of the differential case used to direct oil into the cam followers and plates. It has been postulated that the suretrac is somehow adding to the understeer problem, but I seriously doubt it. TRS |
04-30-2003, 06:13 PM | #10 |
Member#: 21530
Vehicle:2004 STI--evo killer [email protected] |
IMHO, two main things make the EVO feel like it handles better. Less power and a quicker steering rack. Higher the HP, the harder the car is going to be to drive. A nice quick steering rack makes a car feel like it handles better. And handling is measured subjectively anyway. The driver's personal style decides the car's balance. (to a certain degree) (sorry to bring up the Evo here, but I felt I had to put my two cents in.)
And let's look at why the STI may have an understeer problem. A 300hp awd car from the factory. It is well know that understeer is the most safe driving charactoristic. I think subaru intentionally left some understeer in the suspension, so you (generic person) wouldn't put the car in a ditch. I think with some different swaybars and a few other goodies, it will not be a problem any longer. As for me, I am going to wait and drive the car myself before I do anything to the suspension. The way the STI is setup maybe fine for me staight from the factory. There will be plenty of days at the autox for me to find that out. |
04-30-2003, 06:18 PM | #11 | |
Member#: 13095
From Autoweek.... "On the road all those differentials feel noticeably unlike your generic front-drive compact sedan. Lift off the gas during easy cornering and you can feel the front diff separate and the car pull to the outside; get back on the gas and the differential connects to limit slip and pull the car around the corner." Just using logic, I know nothing like this happens in a stock wrx, because I own one. I know several people have reported this in STI's, both with and without the DCCD, but always with the suretrac front trick dif. So........... |
04-30-2003, 06:34 PM | #12 |
Member#: 8351
I still don't see how a LSD will ADD to understeer.
Although it sounds reasonable at first, it seems flawed since when not under power there is no acceleration vector to the forces on the contact patch, just the turning forces. Why would the front tires give up with less force being exerted on them? This is the same front diff on the JDM STi and spec c. The latest iterations of these reportedly don't understeer much. One explanation is that these testers are at the limit of the tires' grip--with the suretrac active under power--so that when they get off the throttle, the force being asked of the outside tire is now increased, it starts slipping and you get understeer. Which you would have hit before without the suretrac splitting some of the torque. Said another way, getting off of the throttle just put you back where you would have been without the LSD in the first place. TRS |
04-30-2003, 07:21 PM | #13 | |
Member#: 7370
Vehicle:2013 5.0 SGM |
Re: STi Suspension Discussion
04-30-2003, 08:13 PM | #14 | |
Member#: 13095
You are treating understeer as if it can be lumped together into one overall sum where we can then decide whether the suretrac's net effect it to increase it or lesson it. But you're leaving out the issue of when the understeer would take place. Especially relative to the issue of what the driver expects, and can be realistically expected to do about it. A driver knows when to expect power understeer and what to do about it. But, we are theorizing that the suretrac causes lift-throttle understeer. You are saying that even if it does, it doesn't matter because without it you would have understeered earlier. Even if that is true it's irrelavent. It's as if we were discussing whether old Porsche 911's have drop throttle snap oversteer due to the engine in the tail (they do), and you countered by saying that without the engine in the back helping the rear wheels to plant themselves you would have oversteered anyway long before. Well....maybe, maybe not. But it doesn't change the fact that you lift the throttle and the tail comes swinging round. From a driver's point of view you can't make that nasty reality go away with possibly flawed physics. I don't know what the deal is with the Sti lift throttle understeer. But the reality is, it's present in the STI and not in the WRX. It's significant enough that several road testers have commented on it. How else can you explain? |
04-30-2003, 09:01 PM | #15 |
Member#: 26812
Vehicle:-- sold 04 WRB STi MINI S VERT soon JCW baby |
I don't think the problem is quite as bad as the 911. With the 911 you go into a decreaseing radius turn (an off ramp for instance) too hot and the tail of the car starts to rotate around and you hit oversteer city. Panic and lift off the gas (or worse touch the brake) and you leave the comfort of the frying pan for the fire. I believe the term is "trailing throttle oversteer" Most Porsches (911 VARIANTS) leave the road BACKWARDS!
We don't quite have it that bad first we don't have a boat anchor in the trunk second we have understeer, not nearly as deadly. Get off the gas to fast and you come out of the turn not into it. We'll still need to do some research into the problem but I don't think we have 911 sized problems and even those are tuned into some pretty mean track cars. pk! |
04-30-2003, 09:07 PM | #16 | |
Member#: 13095
04-30-2003, 09:08 PM | #17 |
Member#: 5489
NWIC
Vehicle:2013 FR-S AVO Orange |
I'm coming at this from the JDM viewpoint, of course, but certain things don't add up to the extreme reactions here.
First off, a car that posts higher emergency-lane change numbers and identical skidpad numbers is not understeering hugely. In fact, the phrase "relative to the Evo" is something that is hugely ignored, as far as I can tell. Lift throttle understeer has probably been dialed in to the STi - as others said, the WRX doesn't do this, and well, it's not exactly a desired trait from the manufacturers point of view that it does do that. I take it everybody has forgotten the "dude, a tree ate my car" threads back when the WRX was introduced. Evidently, Subaru hasn't. If you read the article through, Rod Stillen stated that "when I get back on the power, it feels great. It grips and pulls strongly". His understeer comments are related to off-power - on the dirt. Not the tarmac. As far as I can tell, the article doesn't say that he was the one that ran it around the streets of willow, unless the SOW is a dirt track. The steering felt slow "in comparison to the go-kart Evo" that "feels nervous and harsh on poor roads". About what I've said in the past - which compromise do you want? Now, on to the suspension: If the USDM STi is different in suspension pieces, here are the easy to change areas that STi could have dialed the understeer in at. Front and Rear ARB's. That's the easy answer, and it was Glenn Wallace that pointed out that the front ARB has been upped to 20mm. I don't think that's made the printed information lists because it was part of the "running changes" that has been going on. ARB links. The JDM STi has a interesting thing going on with the arb links front to rear. The fronts are the standard, floppy links of dubious fame, which allow for quite a bit of movement before the arb comes into play. The rears, though, are solid-type links. Shorter, stronger midsection and solid pillow-ball ends. That would have the effect of promoting oversteer and turn-in from my experiences with such links. The drawback is noise and NVH. If Subaru/STi wanted to dial in a bit of oversteer and make the car a bit more compliant and quieter, that's an easy change for them. Put in the longer, plastic end links. The drawback of those is that it becomes a bit more unpredictable at the limits. Front/rear geometry hard points. They could have stuck with the older STi 7 hardpoints in the rear - the fronts are certainly the newer Spec C setup - but I doubt it. It's cheaper to keep the new hardpoints, and play with the links/arbs. Dampers/springs. While they have an effect, I've yet to experience big differences in understeer/oversteer due to minor differences in damper/spring setups. ARB settings tend to have much more of an effect, IMO. Cheers, Paul Hansen www.apexjapan.com |
04-30-2003, 11:04 PM | #18 | |
Member#: 456
NWIC
Vehicle:2008 Forester XT Steel Gray Metallic |
I think we are getting a 20mm front bar. The JDM STi should pick it up as a running change. Any talk of rampant understeer is ill-advised unless you also know the front and rear spring rates. (duh) Glenn |
04-30-2003, 11:05 PM | #19 | |
Member#: 8351
I think now that it has been highlighted that the front ARB is actually 20mm, and that the camber settings are very mild, the problem may be mitigated with minor tweaking. We should find out shortly if the struts are the same as JDM v8 STis. TRS |
04-30-2003, 11:11 PM | #20 | |
Member#: 8351
Well, what are the spring rates? Changing the springs is one way to address it, but a rather drastic one for a new car. TRS |
04-30-2003, 11:43 PM | #21 |
Member#: 8281
Vehicle:1967 Alfa Romeo GTA |
Given the reported alignment specs there is a good chance that dialing in extra negative camber in the front may take care of the reported understeer.
04-30-2003, 11:53 PM | #22 |
Member#: 5489
NWIC
To be honest, getting your braking done early, getting on the gas mildly towards apex then giving the pedal a look at the carpet post-apex seems to be a fairly straight-forward cure of this lift-throttle understeer to me.
05-01-2003, 01:16 AM | #23 | |
Member#: 24496
Vehicle:05 STi Aspen White "SOLD" '_' |
Sounds like fun to me. I can't wait to get down to the local track and see just how curable this whole understeering problem is with the use of one simple tool. My size 12 shoe!! |
05-01-2003, 01:20 AM | #24 | ||
Member#: 456
NWIC
Glenn |
05-01-2003, 01:32 AM | #25 |
Member#: 7852
How about putting on something like..
22mm/24mm?? (reverse of EVO's) Just that 19/20 or 20/20 seems small to me... when I got a bigger sway bar for my E36 M3 (which already has slightly bigger sway than STi's at 21/20mm stock)... the body roll reduced dramatically... which I really like... |
AutoX SM class 04 STi build...Discussion | Dirty25RS | Autocross | 101 | 09-20-2009 10:22 PM |
Ram air intake with STI hood... discuss. | Crashsector | Normally Aspirated Powertrain | 5 | 04-01-2006 03:01 AM |
STi prodrive suspension, oem exhaust, sti suspension.. more | MikeRambot[KaM] | Private 'For Sale' Classifieds | 0 | 06-15-2005 04:10 AM |
STi Technical Discussions... We should move to NASIOC Technical | rlavalle | STi Forum Archive | 4 | 08-29-2003 12:14 AM |
STi version suspension vs. STi suspension | wrx_sti_ver4 | Brakes, Steering & Suspension | 0 | 08-15-2002 09:35 PM |
