08-11-2019, 08:31 PM | #1 |
Member#: 471567
Vehicle:2018 WRX Limited White |
Tool Recommendations: Impact Wrench
There are so many different tool brands out there, I'm asking for recommendations on an impact driver/drill to change wheels at the track.
Ideally something that can get the lugs torqued reasonably well for the torque wrench to finish the job. Any suggestions? Thanks! Chris
08-11-2019, 09:29 PM | #2 |
Member#: 487500
Vehicle:2018 WRX |
I assume you mean something cordless/battery powered?
I have a 20v Dewalt 1/2 inch "mid range". Fairly compact with plenty of torque. 2 impact settings as well. Works with all my other 20v tools too. Part# dcf894hb |
08-12-2019, 09:39 AM | #3 |
Member#: 483915
Vehicle:2004 wrx WRB |
ive had luck with Milwaukee products, check out their impact driver.
08-12-2019, 09:49 AM | #4 |
Member#: 471567
Thanks! I'll look them up. I've heard of Milwaukee, but do not know anything about them. Cheers, CHRIS
08-15-2019, 02:29 PM | #5 |
Member#: 10228
Vehicle:2002 Subaru WRX |
Milwaukee is awesome. It can get expensive. They are a premium brand. But a great warranty.
Home Depot's Ridgid brand is great too, plenty for track and even more like semi truck lugs. Excellent warranty too. I've heard great things about Lowes Kobalt brand too. Dewalt, Even Harbor Freight's new Earthquake line (crap warranty) are also great contenders. Thing long term though... Once you buy into one brand, the battery works in other tools from the same company. So when you settle on something, look at the other tools they offer, and does it cover other things you may want to buy? As an example, I got a ridgid impact driver (not an impact wrench) as a gift. I then just bought a driver and impact wrench and saw. All brushless. But they make no outdoor tools. Ryboi does, Dewalt does, Milwaukee does, etc. All the batteries are interchangeable within the respective brands. You also want to pay for the brushless models too IMO. More efficient, and a bit more power. Pro-tip. All the brands above, often only come from a handful of manufacturers. Techtronic Industries (TTi) owns Milwaukee, Ryobi, and more! Each brand has their market and price point. Batteries are not compatible, but often share many features and components. You can rest assured the quality of the tool will be just as good on the lowend as the highend. |
08-15-2019, 02:32 PM | #6 |
Member#: 10228
08-15-2019, 08:41 PM | #7 |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
Milwaukee will do the trick and costs a lot less than Snap on or matco. You can also get several sizes for the battery if you want it really light. I've never used the cheapo harbor freight ones but even those seem too expensive for something from harbor freight.
Almost got the Ingersoll cordless because it literally smoked the snapons several years back, but a friend at work recommended milwaukee and after comparing prices and reading reviews it seems like a good choice. The 1/2 and 3/8 I got are also brushless, which will make them more reliable. They are doing well so far, but have only used them for about four months. My air tools are ingersoll and are really reliable considering how much they get used. |
08-28-2019, 01:56 AM | #8 |
Member#: 325805
I'm currently loving my harbor frieght Earthquake XT 1/2 inch cordless. Pulling lugs off my vette (about 100lbs tq) is no issue. I've pulled crank bolts, head bolts, subframe bolts and an axle nut with it no problem. The only thing I've ever seen thwart it was the cam bolts from my ej which are insanely tight.
08-28-2019, 07:50 AM | #9 |
Member#: 233053
I have the older version of this Makita. It's a little bulky but has performed fantastic. I have done axle nuts and suspension work with this as well and it doesn't quit. At the time I bought it the snap on equivalent was around $500 and I bought this with battery for $260ish. It looks like the newer version is a little more compact in length which is a plus
https://www.amazon.com/Makita-XWT08Z...15506155&psc=1 |
12-16-2019, 01:20 PM | #10 |
Member#: 265783
RMIC
Vehicle:2017 Forester XT Niner ROS 9 |
Husky is the Home Depot house brand. Ridgid is their own brand, made by Emerson. cool image of all the companies and their brands though! really interesting.
12-16-2019, 01:25 PM | #11 | |
Member#: 239822
South East
Vehicle:2010 WRX pandiculation |
The tools are generally good though. They sell direct through directtoolsoutlet.com too... |
12-16-2019, 02:38 PM | #12 | |
Member#: 265783
RMIC
I‘ve had a Ridgid corded drill for a good 15 years now, and it’s still running strong. |
12-16-2019, 02:58 PM | #13 | |
Member#: 239822
South East
I'm over committed on the 18v cordless Ridgid stuff and have no complaints so far. |
12-16-2019, 03:21 PM | #14 |
Member#: 265783
RMIC
I make the forging dies and tooling for Ridgid pipe wrench jaws, so I'm always on the lookout for where they are sold.
12-16-2019, 11:18 PM | #15 |
Member#: 470981
Vehicle:2008 Legacy GT spec DGM |
https://www.milwaukeetool.com/Products/Power-Tools/Fastening/Impact-Wrenches/2767-20
I bought one of these when they first came out. I was tired of my Snap-on MG725 having a hard time getting stubborn bolts loose on various vehicles. I needed more power and the 2767-20 did the trick! If you've ever tried to loosen crank bolts on Hondas that need the special locking tool, you KNOW tight. I've had 2 since purchasing that the gun could not take off by itself. I got the gun for $250. I then bought the 18v/12v quick charger and (2) 9.0A batteries for another $200. The snap-on gun was $500, requires air and has half the power. The 9.0A battery may be a little overkill but I use it 5 days a week and was unaware how long the battery would last (it was my first daily used battery tool). The 5.0A should be plenty of life for most people. |
12-17-2019, 04:16 AM | #16 |
Member#: 508225
South East
Vehicle:2006 Subaru Fusia |
+11ty on Milwaukee. Was invested in Default and my tool repair guy turned me onto Milwaukee stuff. Took me awhile to convince my old boss to transition... Honestly from a working tool standpoint the whole line is pretty awesome.
I did manage to save our "Default" investment by the 20v adaptors & new packs after the 18Vs bit the dust. They were given to crew noobs along with the hyper yella ryobis. The journeyman guys got the milwaukee stuff. Also the milwaukee 1/2" impact will pop the 500 ft lb lug nuts on my RV. Ironically the last flat I got... called roadside and guess what he had on the truck?? Yeap... big red. Said he uses it everyday on 18wheelers and large trucks. No airhose needed! |
12-25-2019, 10:49 AM | #17 |
Member#: 373868
Vehicle:'04 STi WRB |
That Milwaukee 2767 is industrial grade, pretty much made to impact fasteners on bridges and large constructions. Something like 1100ft/lbs of loosening torque. Hasnt failed me yet for anything automotive rated. You really cant go wrong with it.
01-07-2020, 02:57 AM | #18 |
Member#: 414507
I'm very happy with my Dewalt. It is powerful and reliable.
03-05-2020, 10:24 AM | #19 |
Member#: 512267
+1 for Milwaukee, I have the 3/8" cordless 18V Impact and love using it. Never had a problem with any Milwaukee cordless tools I own.
03-19-2020, 12:38 PM | #20 |
Member#: 10228
An ebay seller is making 3D printed battery adapters to mate X battery to Y tool brand. Im loving it so far.
I have all Ridgid tools and batteries today. I bought a ryobi adapter so i can buy their branded tools but use my existing batteries. I plan to buy some ryobi outdoor tools next since Ridgid doesnt have that today There are other mixes of dewalt, milwaukee, hitachi, etc available. Came out to around $100 shipped from Australia |
04-28-2020, 05:17 PM | #21 |
Member#: 437670
Vehicle:2005 2.5 SC OB |
Anything Milwaukee rated for about 200 ft lb. Stubby Fuel would work fine.
https://www.homedepot.com/p/Milwauke...dalType=drawer This tool will do 75% of everything you'd need to go on the car too. |
05-05-2020, 01:24 PM | #22 |
Member#: 507249
Ingersoll Rand
https://www.amazon.com/Ingersoll-Ran.../dp/B07L1LVFZ7 A bit on the heavy side but more power than anything else. |
05-05-2020, 11:06 PM | #23 |
Member#: 70710
Vehicle:2002 04STi Swaped RS w/PPGS & 02 Wagon w/PPGs |
Hilti all day long
Find on eBay for relatively cheap |
06-27-2020, 05:07 PM | #24 |
Member#: 516183
Do you own any existing battery tools? If so I would stick with that brand that way you can utilize the batteries your already have.
07-08-2021, 09:57 AM | #25 |
Member#: 525410
I can advise you to buy a Makita XDT042 18V LXT. It's currently the best you can get on the market with a battery. Works well for all kinds of jobs with no problems until the battery runs out. I didn't have any drill attachments since I'm new to this, so this was the perfect deal for me since the guys at powerdrillguru.com put it at the top of their list of reviews. With the 4-pole motor, it's a handy and powerful tool to work with all day long. I'm also happy to get the best drill on the market and provide the best work for my customers. If repairs cost half the price of your tool, you better get a Makita.
