12-24-2021, 07:56 PM | #2076 |
Member#: 528045
Model/Year:2017 wrx premium
Milage:32k Mods:Nvidia catback Fuel:93 Circumstances: Driving home from work, dash light up. Took it to dealership that has been upkeeping oil chamges/issues with vehicle. Has code p0018. Dropped off 2 weeks ago, told today metal all throughout motor. New motor, is covered atleast. Actual engine failure:Not sure, assuming turbo went. Talked to dealer about extended warranty since I have had a few problems with vehicle since I bought it new. Said call soa. Talked to someone there, he said im sol since its a 3 yr warranty and I'm 5 yrs in Feb. Told him I've had quite a few problems with car and was disappointed with it, he didn't seem to care too much.
01-07-2022, 07:12 PM | #2077 |
Member#: 437700
Vehicle:2016 WRX Premium |
2016 WRX bought now
79K Cobb AP with E tune TGV/EGR Deletes Cobb flex fuel kit Had about 30K on it since modding it. Fuel pump started acting funny, hesitation fuel spikes, probably due to cold weather and too much ethanol. Added some 93 to bring it down. Ran fine next day for about 75 miles until I did a WOT pull. Let go around 6K rpm just as I was about to shift. |
01-10-2022, 10:47 AM | #2078 | |
Member#: 477489
Vehicle:2018 WRX Limited CWP |
03-22-2022, 04:37 PM | #2079 |
Member#: 516426
Model/Year: 2014 Subaru WRX hatchback
Milage: 109k KM Mods: Cobb intake - Cobb stage 1 - Muffler Delete 4" Fuel: 91 I had cobb installed around 107k km with intake Circumstances: Started hearing a ticking sounds coming from my engine, waited to long to actually check the issue - car died in street. Actual engine failure: Crank bearing went on my engine. Solution: Dealer passed a brand new engine under warranty even though i was over the 7 year 100k km engine warranty. Guy from Subaru said to remove COBB since it tends to blow engines (in his view after seeing so many engines blowing to that) and go get a proper tune instead.. I'm taking everything out except muffler lol.. Don't want to chance this again. ALSO if you try to unflash your COBB before bringing it to Subaru they can see you did that lol as i did that thanks! |
05-06-2022, 03:14 PM | #2080 | |
Member#: 510701
TXIC
Vehicle:2018 WRX LMTD CWP |
Thanks. Sent from my SM-F711U using Tapatalk |
12-19-2023, 12:15 PM | #2081 |
Member#: 530610
Vehicle:2016 WRX WRB |
Model & Year:2016 WRX
Mileage on motor: 50k Mods: FBO e85 FP Blue turbo Headgasket failed, white smoke everywhere, led to rod knock. |
12-19-2023, 12:16 PM | #2082 |
Member#: 530610
02-13-2024, 12:01 AM | #2083 |
Member#: 537002
Stage 1+ CVT
Model/Year: 2019 WRX Premium
Milage:39,000 Mods: Cobb sf intake, boomba bypass valve, stage 1+ cobb ap OTS tune Fuel: 93 Oil: motul 5w-30 Circumstances: only 2.5k miles since I installed the intake, bpv and ots tune, I noticed a ticking in engine that was noticeably louder than normal but not obvious enough to assume as rodkncok. I assumed it was just the injectors but I could hear the ticking from inside the cabin which was unusual. Actual engine failure: cylinder 4 left the chat It is a cvt. I confirmed with cobb re transmission and the tunes were for cvt. I’m not sure how I ruined the engine after 2.5k miles of having the tune. Bpv had no boost leak, I did oil changes every 3k miles. Is it possible the tune wasn’t dialed in well enough for automatic despite cobb confirming? Could it be from doing pulls ~3x a week? What’s the point of having a car like this when it can’t handle it? Any ideas as to what could’ve gone wrong will be helpful. I don’t know if I want to keep the car if it can barely handle stage 1+. |
02-16-2024, 09:24 AM | #2084 |
Member#: 431141
Vehicle:2015 WRX WR Blue |
Has anyone running Ti valve spring retainers seen any excessive wear or failures?
Sent from my iPhone using Tapatalk |
