10-16-2011, 06:06 PM | #1 |
Member#: 275567
AKIC
Vehicle:2010 WRX Black |
Transmission stuck to the block??
Doing my clutch in the wagon, got all 8 bellhousing nuts/bolts off, axles out, driveshaft off, crossmembers disconnected, and STILL can't get the trans to separate... What am I missing?
10-16-2011, 06:11 PM | #2 |
Member#: 258491
South East
Vehicle:2002 VF34'd Bugeye My Other Ride's your MOM |
You have to pull the clutch fork pivot pin/guide/arm thing. Look right in front of the slave cylinder. Look for a hex key hole ( looks just like a oil galley plug) .
10-16-2011, 06:30 PM | #3 | |
Member#: 217208
Vehicle:BMW M3 DCT ARA #206 STI |
You're probably missing force if it's never been separated. Don't forget the pitch stop (under the intercooler), shifter linkage and neutral & reverse switch wiring as well, since you didn't list that. The locating pins are most likely stuck. I usually recommend pulling the motor for this reason, it's easier to apply force from above with everything out of the way. Last edited by retrac; 10-16-2011 at 06:43 PM. Reason: Put location of pitch stop. |
10-16-2011, 06:49 PM | #4 |
Member#: 275567
AKIC
Yep got the pitch stop, wiring, starter. Everything is loose, just not breaking free
10-16-2011, 07:28 PM | #5 |
some old guy
Moderator Member#: 112225
AKIC
Vehicle:1985 78 HP of Rage! Blue |
Retrac is right... If you aren't pulling the engine you need two jacks, one under engine the other under the tranny so you can assust with seperation. Undo your mounts before you do
10-16-2011, 07:55 PM | #6 |
Member#: 68709
AKIC
Vehicle:2012 WRX red |
What Retrac and Dubya said. The aluminum bell housing sticks to the aluminum block pretty tight after a few years. There are alignment pins that tend to really want to stay engaged. I had to *gently* use a sharp chisel to initially start the two sides apart (02 WRX). Once I saw a small separation, I used PB Blaster at the alignment pins to help free it up. Use a little anti-seize on the pins when you reassemble. Good luck.
10-17-2011, 01:44 AM | #7 |
Member#: 275567
AKIC
Well 10 hours and the engine is still seized onto the trans. Pulled the motor up to see if that would do it but it's still stuck. I got aggressive enough to have the jack stands start shaking so im at a loss. I was thinking about using a gear puller where the starter goes and see if I can get the cases spread enough to get a chisel or pry bar between them. If not, motor and trans are coming out together and I'll beat the piss out of the trans on the garage floor. Talk about frustrating!
10-17-2011, 12:03 PM | #8 |
Member#: 22923
International
Vehicle:2002 EJ207 V8 1.5xtr TWIN-SCROLL Black Bugeye |
10-17-2011, 01:13 PM | #9 |
Member#: 56464
AKIC
Vehicle:12 Ram White |
Mine was pretty stuck as well.... huge pry bar. I used a three footer and well placed jacks. Seamed like it would never come out, but it did.
10-18-2011, 02:36 AM | #10 |
Member#: 275567
AKIC
Great Success! Got the trans down tonight. What a pain in the @$$!
and my secret tool to start separating the cases: simply a 2/3 jaw puller, put a socket and extension on the end, insert into the starter opening and the jaws grab the outer ring of the opening. gently tighten, wiggle the motor, tighten some more until you can get a pry bar in the between the two. Worked pretty slick, only took us an hour after I rigged up the tool. |
10-18-2011, 10:02 PM | #11 |
Member#: 68709
AKIC
^^ Good thinking! Way to move on with the job.
04-08-2018, 08:09 PM | #12 | |
Member#: 484363
Vehicle:2008 Impreza WRX Obsidian Black |
I realize I'm revitalizing an old/dead thread but I'm having a similar problem on my 08 WRX. I'm hoping the OP could repost/pm the pictures of how they had the jaw puller set up. Thanks. |
Similar Threads | ||||
clutch stuck to the floor, not sure what to try. | b0nd18t | Transmission (AT/MT) & Driveline | 5 | 07-01-2011 07:05 AM |
What's funnier than a guy in a wheelchair stuck to the grill of semi? | Sharkbait | Off-Topic | 52 | 06-08-2007 08:24 PM |
clutch get's stuck to the floor | kettsupp | Transmission (AT/MT) & Driveline | 2 | 07-25-2005 01:05 PM |
Clutch pedal keeps getting stuck to the floor. | powerlabs | Transmission (AT/MT) & Driveline | 9 | 07-06-2005 10:12 PM |
Clutch stuck to the floor? | grue | Transmission (AT/MT) & Driveline | 6 | 04-27-2004 04:56 PM |
