11-18-2005, 09:35 PM | #276 | |
Member#: 55878
SCIC
Vehicle:0313 GR LTD & GD SDN SWP / PSM |
12-19-2005, 01:20 AM | #277 |
Member#: 98576
Vehicle:2005 WRX WRB |
2nd gear
-------------------------------------------------------------------------------- Name: Brian Shull Make: 2005 WRX Mileage: 18000mi Time Out Of Use: none yet Problem And Likely Cause: second gear disappears intermittently, synchro? Modifications: TXS Up-pipe, Helix Downpipe, CObb stage 2 Submitted For Warranty Work (Yes/No): tried Reason Given For Denial: tranny has not yet been inspected Your Story: About a month ago while accelerating quickly in first, attempted to shift into second and it was gone. No grinding, nothing, just like the slot for 2nd had disappeared. Problem resolves spontaneously and then reappears at random and 2nd is gone for a random amount of time. Took it in for service at a dealer two hours away who I trust, in fear due to the mods...couldn't replicate the problem while it was there. I think the second gear synchro is shot and I am panicking after reading all the complaints. They won't inspect it unless they can replicate the problem but if the 2nd gear synchro is going bad eventually 2nd gear itself will get chewed up, and I don't know what to do because I don't want to wait until the whole tranny is destroyed and I can't afford 3500+ install for a new one. I doubt they will cover it under warranty...they said they would unless it looks like "abuse" but what else would it look like if 2nd gear gets chewed up over time. |
12-27-2005, 03:02 PM | #278 |
Member#: 103734
Vehicle:2002 WRX wagon Black |
Make: '02 WRX Mileage: 35k Time Out Of Use: 1 week so far Problem And Likely Cause: Blown (?) clutch, stripped gears Modifications: Stock Submitted For Warranty Work (Yes/No): Yes Reason Given For Denial: Wear and tear items Your Story: I bought the car used one week ago from Burnsville, Minnesota. I drove it back to Grand Forks, North Dakota. A couple days later I was driving and as I shifted from 1st to 2nd there was a loud snap and my clutch/tranny ceased to work. I had it towed to the nearest Subaru dealer. They said they needed to check it out first. They called and said the clutch is blown and they don't cover that. I agrued about it for a bit and they said they'd wait and see how the gears look before making a decision. Now, it turns out the gears are stripped too and they won't waranty it at all. I have the warranty bulletin here that covers their ass when they don't warranty "wear and tear" parts. I also have my service record for the car which shows a NEW clutch put in at 20K miles. Now it broke again at 35K miles. What gives? I had only driven the car a few days before this all happened. Even if SOA won't waranty it, shouldn't the dealer that I bought it from cover it for me? Do I have any rights in this matter, or am I just screwed? Who can I turn to? What about the Subaru Reps that look at these problems on a case to case basis? Where are they at? Any help would be appreciated... Thanks -Taylor |
12-27-2005, 06:18 PM | #279 | |
Member#: 6140
Vehicle:2002 WRX 5MT Sedan WR Blue. Cobb Stage 2 |
Did the dealer you purchased from include a warranty? If so, you might be able to get some help from them -- if you can prove that the damage was pre-existing (which may be difficult). What exactly is wrong with the clutch? I wouldn't think that the stripped gears would affect it in any way. Is it just worn out, or does it have actual mechanical damage? It seems strange that it would break/wear out after only 15,000 miles. I have almost 95,000 miles on mine and it's still going strong -- and I don't exactly baby it (still get the 'judder' once in a while). Anyway -- that might be a way for you to show that the previous owner is responsible for the damage -- the fact that a clutch that was installed at 20,000 miles is gone at 35K. Good luck. |
12-27-2005, 07:48 PM | #280 |
Member#: 41730
Vehicle:1415 Legacy/Forester D.Grey/White |
Did you buy it from a Subaru dealer or another veh. manufacturer? Do you know if it is still under Subaru's warranty by time (less than 3 years old?) Seems strange that both the clutch and the gears went at the same time.
12-28-2005, 10:06 AM | #281 |
Member#: 103800
2006 wrx sti motor mounts
In the first week of owning it their was a clanking sound, took back and said that the motor mounts were broken. The car was not even close to being abused. They fixed them then told would not fix again under warranty. The mounts are broken again and they are saying they will not pay for repair. The car has not been abused, not even close to being red lined. Has anyone had a similiar problem?
12-28-2005, 10:35 AM | #282 |
Member#: 41762
International
Vehicle:04 STi in ur Floriduh |
This is the first year they used these new motor mounts. Not sure if it's on only STi or all imprezas/subies.
Sounds like a defect, design flaw. Don't let 'em jack you! |
12-28-2005, 11:02 AM | #283 |
Member#: 103800
motor mounts
do you have any suggestions as what to do? with the dealers attitude I just assume return the car and call it a day. SOA said that they will not fix the car again. Any help anyone can give would be greatly appreciated.
12-28-2005, 11:04 AM | #284 |
Member#: 41762
International
document at much as you can in writing from the dealer. Try to contact SOA (800 # around here somewhere)
Invoke lemon law if neccesary. |
12-28-2005, 08:34 PM | #285 |
Member#: 41730
The warranty booklet doesn't say anything about a one time only repair. Why did they tell you they aren't covering it? Did the dealer say it or did SOA say no? Who's the dealer?
12-28-2005, 10:37 PM | #286 | |
Member#: 63616
South East
Vehicle:1996 Volvo 850 Turbo with mods :) |
The first repair was probably deemed abuse, etc, and if it keeps happening then something is happening out of SOA's control. Trust me, they know when something should or should not be warranty. They build and design the car....they know how things break |
12-29-2005, 06:53 AM | #287 |
Member#: 41730
In denial
Thanks Rexy! I hope the OP gives us more details.
12-29-2005, 07:03 AM | #288 |
Member#: 103800
motor mounts
I'm confused? Without any modifications and not torquing the engine within the first week the mounts break, how can it be anything but underengineering! I have a 34 year old GM that has never broken a mount. I thought those were the things that someone should never have to worry about. I have had problems in the past with an Outback that I had purchased from them that had trans problems and they tried to tell me that it was my fault, three trans in less than one year, maybe they should look at who is rebuilding the trans and not make the customers feel like once you bought the car they don't stand behind their products. I have to call them today to have the mounts fixed again and they are going to tell me that I have to pay for them myself.
Any suggestions as to how I should get my point across? Help!!!!!!!!!!!!!!!! Last edited by Dave Wiltsie; 12-30-2005 at 12:29 PM. Reason: should not have named names |
12-29-2005, 08:57 AM | #289 | |
Member#: 41762
International
What kind of abuse would an STi have to endure to break a motor mount? |
01-03-2006, 01:16 PM | #290 |
Member#: 103800
motor mounts
Well, I just heard back from the dealer regarding my motor mounts. They said that they are willing to put in the performance mounts that they offer for the STI, they will cover the labor cost and not the mounts? Wouldn't that tell you that they don't have confidence in the stock parts?
Should I have them replace with the new ones or tell them to put the original ones back on and lemon the car? Any thoughts? |
01-11-2006, 05:16 AM | #291 |
Member#: 104827
YesSESE
01-11-2006, 05:17 AM | #292 |
Member#: 104827
yessese
01-11-2006, 05:17 AM | #293 |
Member#: 104827
eccallà
01-11-2006, 05:17 AM | #294 |
Member#: 104827
sinò bevi
01-11-2006, 05:18 AM | #295 |
Member#: 104827
sinerò berevi
01-25-2006, 09:23 AM | #296 |
Member#: 55539
Blown Engine Denied by Subaru of Dallas & Bill Davis
Make: 2005 STi Mileage: 6500 Time Out Of Use: Never got car back Problem And Likely Cause: Oil starved cylinder and threw a rod Modifications: Cobb Access Port (Stage2), Hotchkis Sway Bars and End Links, Whiteline rear strut tower brace, Cusco front camber plates, oil temp gauge, oil pressure gauge, and boost gauge, hardened tranny mount, APS Exhaust, APS Intake, Cobb pulley, Cobb track pads. Submitted For Warranty Work (Yes/No): Yes Reason Given For Denial: One time they told me I abused the engine, then other times they told me that using the accessport was the cause. Your Story: Let me start off by saying the Subaru of Dallas sold me all the parts and did all the install on my mods. They never once told me that in doing so I was getting screwed if anything went wrong with the car. I became friendly with the Service Mgr. Phil. He made it seem like anything was cool as long as they did the work, so I kept modifying the car and spending more money at his dealership. This was my second Subaru, I had tricked out my 04 WRX Wagon and tracked it several times with similar mods to the STi. So I had probably dropped close to $25,000 in aftermarket parts and service in his dealership in a little over a year. They knew me by name and my cell number was on speed dial from Chris in parts and Neil in service. Then when I was at Texas World Speedway in College Station, TX doing 120 mph down the banked straight my nightmare began. My engine went POP! I had the car towed back to SOD (Subaru of Dallas) and I asked them if I needed to strip the parts off before Bill Davis saw the car for coverage under warranty. They assured my it was no big deal, so I didn't give it another thought. Then 4 days later after Bill looked at it, he denied the claim. The mechanic Calvin had told him I was probably racing and that I had AccessPort on the car. I called a lawyer and he told me I was screwed. I waited and stalled trying to figure out what to do. I ended up trading the car in for a new STi 4 weeks later because the loss in equity in the car equalled the price of the engine repair, so it was a wash and it was March and I owed money on taxes. I ended up having a check engine light come on in the new STi on the way home after purchase. I took it back the next day and told them no deal, I wanted the broken one back and I would fix it and they can take the new one back. The told me sorry, I drove it off the lot so it was mine after stalling me for 5 days with excuses so the title transfer would go thru. Then I called another lawyer and he told me I had had a case, but I relinquished all claims when I traded in the car for a new one, and that I should have fixed it and sued SOA for the repair costs. The story gets better, as I am up at the dealership after I purchased new one and they are looking at it to find out the cause of "intermittent" CEL 2 cars are their, one fully race prepped and one mod'ed like mine. Both had the same issue I did, oil starved and throw rods. They both had them covered under warranty! The guy with the mod'ed one took his crap off the car and took it to huffines and the race preped one with full rollcage had it done at SOD cause apparently they knew someone who knew someone kind of deals. So I am bitching to Phil and Neil and Bill while these other cars are getting fixed for free and I got screwed out of another $10,000 for the STi. I finally sold the car and bought a Mercedes-Benz C55 last week. Not to sound snobby, but this whole thing was never about the money it was about the principle. They should have treated me better. I would have done a 50/50 split with them. Phil and Neil never went to bat for me against Bill Davis or SOA. I was one of the first guys to get my car mod'ed by them and helped them spread the word at driving events all over Texas and how do I get repaid the one time I needed their help? By getting a cold shoulder and a stab in the back when I went to leave. The beauty is I ragged the **** out of the new STi I bought. I drove it like I stole it and only changed the oil 1 time in 11,000 miles. And the Merc dealer sold the car back to SOD. So anyone in the market for a used 2005 Silver STi at SOD beware the car has been driven very hard and not treated well. I am going to go their today at lunch in my shiney new expensive car and give them a piece of my mind. I was holding off until I got a new one in case I needed to take it to SOD for service. |
01-25-2006, 11:52 AM | #297 | |
Member#: 94268
TXIC
Vehicle:1995 JDM STi RA ver2 2010 Exige S240 |
wow sad story. At least you had the money for the new benz I think I've always heard good things about Subaru of Dallas... |
01-25-2006, 01:02 PM | #298 | ||
Member#: 25187
Vehicle:2020 Forester 2010 Challenger R/T |
01-25-2006, 05:06 PM | #299 |
Member#: 94268
TXIC
hah ok
01-27-2006, 06:09 PM | #300 |
Member#: 83640
Vehicle:2005 Impreza WRX STi World Rally Blue Pearl |
Sounds like he has had a rough time, I don't blame him one bit for acting out if he did. Not one bit.
If my Subaru dealer tried to screw me I don't know WHAT I would do. |
Trouble/Warranty Denial Report Thread: Body/Exterior of Vehicle | North Ursalia | Warranty Issues & SOA Problems | 148 | 04-05-2023 06:27 PM |
Trouble/Warranty Denial Report Thread: Electrical (Lighting, ECU, Sensors, Etc.) | North Ursalia | Warranty Issues & SOA Problems | 143 | 07-23-2020 06:21 AM |
Trouble/Warranty Denial Report Thread: Suspension | North Ursalia | Warranty Issues & SOA Problems | 58 | 10-19-2019 04:03 PM |
Trouble/Warranty Denial Report Thread: Braking System | North Ursalia | Warranty Issues & SOA Problems | 97 | 09-27-2019 12:46 PM |
Trouble/Warranty Denial Report Thread: Interior | North Ursalia | Warranty Issues & SOA Problems | 71 | 11-14-2018 08:18 AM |
