12-19-2018, 04:00 AM | #1 |
Member#: 495376
Widebody Sealants- HELP
Hey, I've got a project widebody going on, I've had the rears re sealed twice now and it has cracked both times. I'm after some advice on what people have used to seal, Must be able to be painted on and must be able to handle the weather! Thanks
12-19-2018, 10:05 AM | #2 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
I don't know.....but......glass, CF or metal kit?
How are parts attached? Are parts painted, and if so, what kind of paint? Does the sealer also act as a filler between parts? |
12-19-2018, 04:42 PM | #3 |
Member#: 373868
Vehicle:'04 STi WRB |
12-20-2018, 03:17 AM | #4 |
Member#: 495376
Sorry, Fiberglass. And yes it would also act as a filler. I'm unsure of what paint, It wasn't me who painted it- Was a panel shop
12-20-2018, 03:17 AM | #5 | |
Member#: 495376
01-09-2019, 02:55 PM | #6 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
I have fiberglass widened rear quarters grafted to the factory steel quarters on my Fox Mustang. The guy who did the work used one of the Marine-Tex products; I can't tell you which one specifically. That was way back in 2007 and the panels are still in place with no cracking or issues that I can see.
In the years since the work was done I have seen Marine-Tex mentioned in discussions of bonding fiberglass and metal. I'm sure if you search around you can find info about which type is best to use. |
10-01-2019, 09:49 PM | #7 |
Member#: 378156
Vehicle:2008 WRX 16K Dark Grey Met |
This is what I would use after properly prepping both surfaces.
https://www.amazon.com/3M-Adhesive-M...26468864&psc=1 |
10-01-2019, 09:53 PM | #8 | |
Member#: 378156
I don’t think that product would be strong enough. That product is just for sealing folded seams on metal parts so moisture doesn’t creep under. (Door skins) It doesn’t have any bonding strength. OP needs a quality panel bond adhesive. |
10-02-2019, 03:56 PM | #9 |
Member#: 222125
SCIC
Vehicle:2003 2003 wrx black |
What you’re wanting to use is 3M 8115 panel bond. You will have to sand down your cars body to bare metal for the sealant to where properly. Used it on my widebody and worked great. It’s also Sandable once dry.
10-02-2019, 05:10 PM | #10 |
Member#: 79643
Vehicle:2021 STI TE Terminal black pearl |
Harbor Freight mig welder should do it.
10-02-2019, 09:11 PM | #11 |
Member#: 222125
SCIC
fiberglass installed widebody with panel bond 8115
Last edited by pistolpete44; 10-02-2019 at 09:17 PM. Reason: Correcting photo url |
