02-15-2014, 07:52 PM | #1 |
Member#: 334068
Torque plate cad drawings
Looking for some CAD drawing for a ej25. Torque plate. I see guys advertise the plate for sale but want some drawings instead. Don't know if this is in the right spot either. Thx
02-18-2014, 09:06 AM | #2 |
Member#: 154534
MAIC
Vehicle:2018 WRX STI Limited Black |
You might be better off buying a head gasket and taking some dimensions. Not sure if anyonee would give out this information.
02-18-2014, 01:25 PM | #3 |
Member#: 334068
Good idea thx. I have some head gaskets.
02-19-2014, 10:19 PM | #4 |
Member#: 222879
Tri-State
Vehicle:2015 STI ISM |
If you send me the dimensions i can model one in Creo or Solidworks
02-21-2014, 01:17 AM | #5 |
Member#: 237759
TXIC
Vehicle:2003 WRX Wagon Built ej205 478whp 417wtq |
Pm me your email address. I have Mastercam x6 .mcx6 file with Verisurf data, a solid model, and toolpaths for an ej205 torque plate I made.
03-04-2014, 07:25 AM | #6 |
Member#: 334068
Purpose I can send you a old head gasket if you want make up a file.
Tanker I PMed ya Thx |
03-05-2014, 06:45 PM | #7 |
Member#: 222879
Tri-State
That will work. Reach me at [email protected]
04-20-2014, 09:53 PM | #8 |
Member#: 234397
MWSOC
Vehicle:2004 WRX STI WRB 15 DGM FXT |
I'm interested also.I have a 3''6061 12x8 piece alum here to cut.
04-22-2015, 02:06 PM | #9 |
Member#: 418342
I am looking for some cad for a torque plate if anybody has it can you pm me and i'll send you my email address. its for an ej25 though, so im not sure if the hole locations are the same but it will give me a starting point.
thanks |
04-23-2015, 07:49 AM | #10 |
Member#: 195711
MWSOC
Vehicle:PART OUT. PM ME 02-07 Goodies |
Outer holes will be the same, inner diameters will be different but the same center - center dimension.
04-23-2015, 02:10 PM | #11 |
Member#: 418342
thats what I thought. Nobody seems to be around with these drawings, i might end up having to measure them out from my head gasket. once i get my hands on one i'll see about posting it up somewhere so everybody can access it.
04-23-2015, 03:10 PM | #12 |
Member#: 222879
Tri-State
So many people have bs'd me when i asked them for measurements. Its a very easy thing to design.
06-13-2015, 03:06 PM | #13 |
Member#: 103232
Tri-State
Vehicle:GTX 3071R'd 11WRX PPG,4.44,LSD,E85,6spdx3 |
Are you guys making the bore slightly larger or smaller then the ID of the head gasket? I measured the stock sti gasket and got 101.27mm. Im assuming slightly smaller as I cant really see the gasket in "most" pics of them installed on a block. From what Ive seen folk make them from 101-103mm. I think slightly smaller would be the way to go...
10-15-2015, 12:11 AM | #14 |
Member#: 418342
I got my hands on a .dxf for a torque plate. if you want a copy or better yet if you can host a copy for anyone to download just pm me with your email address and i will send it. I made it out of some 1.25 aluminum and made up some bolt spacers from mild steel with a washer under them. worked out fine with my ej251 block. with the 1.25 plate the spacers ended up being 2.6" long minus whatever thickness steel washer you use, if you use one.
10-15-2015, 07:33 PM | #15 |
Member#: 418342
Just emailed the file to someone on here that should be able to host it for everyone :-)
12-28-2019, 01:01 PM | #16 |
Member#: 497403
Knowing that the topic is 4 years old, does anyone has those cad files
I will have to make them myself as the import and delivery cost as much as the plate itself. |
04-01-2020, 01:13 PM | #17 |
Member#: 513066
Following.
10-12-2020, 10:57 AM | #18 |
Member#: 418342
I gave the dxf to someone awhile back who said they would host it, but I guess it never happened. I have had a couple people PM me asking if I could share the file with them but I havn't logged in for years to see the messages, so apalogies for the late response.
so I decided to put the dxf on my google drive and make the link viewable to anyone. https://drive.google.com/file/d/1cw3...ew?usp=sharing I did end up making a torque plate with the file too and it worked perfectly, I still have it. I cut it out of some 1.25" thick aluminum on a waterjet and made some steel sleeves out of some mild steel round stock that the head studs go through to make up for the fact that the torque plate isn't the same thickness as the cylinder head. I put some washers under the sleeves so they wouldn't embed into the torque plate when everything gets torqued down. There is also a template for dowels to pin the head to the block in the dxf, which I didn't personally use. |
