01-26-2017, 04:45 PM | #26 |
Member#: 428511
Vehicle:2016 STI |
oh ok, well I can see the deformations in those lobes now.
01-27-2017, 11:44 AM | #27 |
Member#: 461154
NESIC
I noticed how flimsy the stock piece is when I was rebuilding an fa.. too bad this wasn't available at the time.. bit of a shame that subaru went with a powdered metal rod on this engine. talk about flimsy! that oil pump payed the price!
01-30-2017, 12:02 PM | #28 |
Member#: 424060
Vehicle:2015 WRX crystal white |
Do you guys plan on releasing an Oil PAn and Baffle for the FA in the near future?
01-30-2017, 01:36 PM | #29 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
yes it did
Not in the near future, but it is on our list. Right now we've only seen issues in extreme track conditions. The FA oiling system appears to be a bit more stout than the EJ setup in regards to supplying our under severe corner loads, and it certainly holds a lot more oil. |
02-14-2017, 11:25 AM | #30 |
Member#: 198281
IN STOCK...
02-14-2017, 07:43 PM | #31 |
Member#: 361609
E. Canada
Vehicle:2015 WRX CVT WRB Pearl |
Just noticed on your website, that there is an option to purchase a dual sender adapter. May I ask what that is?
02-14-2017, 08:40 PM | #32 |
Member#: 432452
Vehicle:2016 WRX MT Premium |
02-14-2017, 09:54 PM | #33 |
Member#: 146760
RMIC
Vehicle:2004 WRX Wagon WRB |
02-15-2017, 08:22 AM | #34 | |||
Member#: 198281
There are no post processes besides cleaning and inspection. Heat treating processes are unnecessary cost adders for this type of component. |
02-15-2017, 10:52 PM | #35 |
Member#: 361609
E. Canada
03-20-2017, 10:50 AM | #36 |
Member#: 198281
Have more of this in stock again!
08-02-2017, 10:21 AM | #37 |
Member#: 198281
We have been receiving great feedback about the FA20 WRX pickup! As of right now, they are in stock!
08-02-2017, 11:06 AM | #38 |
Member#: 361609
E. Canada
08-02-2017, 12:05 PM | #39 | |
Member#: 421271
Vehicle:2015 WRX Galaxy Blue Pearl |
You're basically going to need to pull the engine to get to it. You might be able to do it under the car but you have to remove the header and turbo to get the oil pan off and you might still need to lift the engine to get the pan to clear the crossmember and pickup tube. NOT an easy thing to do |
08-02-2017, 02:04 PM | #40 |
Member#: 470648
Vehicle:2016 wrx |
Nice fabrication...
08-02-2017, 02:10 PM | #41 |
Member#: 198281
They do not, but it's fairly straightforward if you have a FSM. Essentially, you pull the turbo/manifold assembly down and it gives you access to the pan. I will look under the car then next time it's on the lift, but I believe the engine does not need to be raised to get to the rear bolts.
08-02-2017, 02:40 PM | #42 |
Member#: 445435
Vehicle:2016 WRX Base MT E85 21Ascent,19XV,17Impreza |
I can't imagine someone doing this mod in isolation, but if you are working on motor mounts, header, turbo, or pulling the engine, it makes more sense.
When I did mine, I noted that you can get to the bolts without lifting the engine, but having that extra 1/2 inch or so that the service manual suggests lifting the engine, makes it much easier to hit the mark when replacing the pan with the fresh RTV. |
08-02-2017, 04:02 PM | #43 | |
Member#: 198281
As far as who is doing what when they buy our FA Pickup, I'd say it's pretty split between those that are building their engine, and those just installing the pickup. |
08-02-2017, 08:40 PM | #44 |
Member#: 361609
E. Canada
Thanks guys! Will look into it, when I place the order for the pickup and then install it for next season.
Would you say its ideal to change it on a stage 2 protune setup? I.e. not pushing more than 320WHP for example? |
08-17-2017, 10:53 AM | #45 |
Member#: 198281
• Larger Inside Diameter Tube provides Increased Flow Capacity.
• No bends for maximum flow potential (OEM unit uses a restrictive punch bend). • Screen area increased over 31% to improve flow and reduce oil pump restriction. • Made from 4130 High Strength Alloy Steel for never fail reliability • Hand TIG welded • Lifetime Warranty • Made in the USA These are in stock! |
08-17-2017, 09:32 PM | #46 |
Member#: 419597
Vehicle:2016 WRX PRM 6MT 2002 Audi A4 |
#groupbuy
08-18-2017, 07:11 AM | #47 |
Member#: 409636
Vehicle:2015 WRX |
11-07-2017, 04:54 PM | #48 |
Member#: 198281
Sorry for the late response, but no can do on the group buy :/
On another note, as some have noted (in this thread and others) customers have been reporting a decent improvement in oil pressure and AVCS sync. We're seeing more builders start to include this on their engines as well |
12-18-2017, 02:22 PM | #49 |
Member#: 450784
Vehicle:2015 WRX Limited DGM |
Dual sender adapter threading?
Could someone tell me what size threading is used on the dual sender adapter? Looking to use the aem 52mm gauge, and the sensor requires a 1/8NPT threading...
12-20-2017, 11:47 AM | #50 |
Member#: 421271
I messaged KBM about this like 6 months ago and they stated it was PT so you'll need to use a PT to NPT adapter.
