05-13-2008, 09:24 PM | #51 |
Member#: 145642
Vehicle:2005 Forester XS Cuz Chicks Dig The Wagon |
As always Ron, well thought and laid out.. and very informative, as all your FAQ's are.... the only piece of info I can't seem to find among them ( or through many searches) is the stock 07 injector CC's..I need a baseline to go from when upgrading...finally decided on a td06/ 20g, and am gathering my arsenal of supporting mods
06-05-2008, 06:32 AM | #52 |
Member#: 120113
International
Vehicle:2002 WRX, full-race, GT35, built engine, etc. |
Do anyone have any idea about how capable the paralell fuelrail-mod (using original rails) is vs Perrin Fuelrails?
I have already done the paralell rail mod on my subaru-rails. But are going to get the car mapped again, having added dual walbro pumps and 1000cc injectors. I have a twin scroll GT35 and I am thinking about E85 fuel. For a 500whp application, would it be a a good thing to upgrade the fuel-rails futher (like Perrin rails), or will the parallell mod be enough? |
06-05-2008, 09:21 AM | #53 |
Big Ron
Super Moderator Member#: 18062
Parallel does nothing. It was designed back in the day when people though there was fueling issue with specific Subaru cylinders. Now that we know it has to do with the exhaust design, there really is no need for the parallel mod except for those that like to modify for modify's sake. Real fuel rails are an upgrade as they have physically bigger hoses, so they will flow more. And by upgrade I mean that only for people who need them AKA the over 500 WHP crowd.
06-05-2008, 11:46 AM | #54 |
Member#: 149174
Vehicle:that 's cool. i have a goldfish. |
06-06-2008, 04:30 AM | #55 |
Member#: 120113
International
Thanks Unabomber! That makes it a bit more clear.
The Satch: Both 341/342 are a walbro 255lph (GSS 342 is the name of the kit that is more plug and play for subarus, 255lhp just means it flows 255 liters (l) per hour at high pressure (hp)). |
06-07-2008, 03:39 AM | #56 | |
Member#: 152932
Vehicle:2002 wrx black |
I agree can anyone confirm this though. |
06-07-2008, 04:26 PM | #57 |
Member#: 6818
Vehicle:2002 NSX 2017 WRX,2016 Outback |
^ I am guessing it will still work but I think most are suggesting not to go with the sti pump since the stock STi's fuel capacity is already being maxed with the stock tune. It is a wise idea to just spend the extra $50 and get the walbro pump.
06-14-2008, 09:35 PM | #58 | |
Member#: 111692
bump for an old question, are the 07 STI injectors the same as 06+ WRX injectors.
Judging from the Cobb maps 06 and 07 injectors can support comparable power levels(VF39 WRX and stage 2 STI, resp.) , thus, they must be flowing pretty close, but I have not seen anyone posting a rate measurement for 07 STI injectors. Quote:
08-16-2008, 10:47 AM | #59 |
Member#: 159243
Vehicle:5/01 bugeye Hakt Ecu is back! |
are PE 510CC's the same injector as sti pink 565cc's? does PE make the sti pinks?
what injector is recommended for a big 18g at stage 2? |
08-16-2008, 06:38 PM | #60 | |
Member#: 138182
Vehicle:2005 WRX Wagon psm |
This is how it was explained to me. I ordered a set of "STIpinks" from a reputable vendor, when I got them they were indeed made by PE. Now when I called them asked them why they were not "subaru" so to speak he said that the JDM "STI Pinks" are made by PE and thats what I got. Hope this clears things up for you. As for the 18G question, I would go at least 650 or 750 to have enough headroom for tuning. I personally think Pinks are to small for an 18G. PS, I think Denso makes the USDM Pinks, someone correct me if I'm wrong. |
08-20-2008, 08:24 AM | #61 |
Member#: 187338
What about this injector http://cgi.ebay.com/ebaymotors/Injec...mZ380055230517 is stated 600cc,same from Denso too.Is this for wrx07 or wrx08 model?
08-20-2008, 02:04 PM | #62 |
Big Ron
This is not the eBay support forum, nor do we have one ASK THE SELLER
09-17-2008, 05:42 PM | #63 |
Member#: 151354
Vehicle:2007 impreza black |
Any info on N/A injectors ? People wanting to upgrade their N/A cars to run straight E85 need to get bigger injectors as well . Thanks
10-13-2008, 03:16 AM | #64 |
Member#: 90951
Vehicle:1998 Impreza GT Silver |
Also for all the GC8 people out there, you can use the std Nissan side feed injectors.
Nismo provides 550s and also excellent 740s than have very similar lag times to the GC8s (if needed I can provide the infos for both injectors) The 740s can be modified up to 1050s and are also sold flowmatched. They are bolt on to MY99/00 GC8s or can be used with some adaptors in pre 99 Imprezas. You can either find some Nissan plugs to fit them or modify slightly your cars one to fit or do complete new plugs. Custom plugs Modified Impreza plugs Pre 99 setup + adaptors Custom billet fuel rails (www.fecker.co.uk) Hope this helps the GC8 people .. |
02-03-2009, 11:20 PM | #65 |
Member#: 185180
TXIC
Vehicle:03 Forester XS PSM |
so 05 sti injectors wont fit an 02 wrx???
02-04-2009, 01:21 AM | #66 |
Member#: 155580
NESIC
Vehicle:04 FXT Awesome |
02-05-2009, 03:37 AM | #67 |
Member#: 195055
E. Canada
Vehicle:2002 WRX PSM |
The info from this post would be usefull to add I think.
http://forums.nasioc.com/forums/show...6&postcount=11 |
03-30-2009, 11:44 PM | #68 | |
Member#: 191491
NESIC
Vehicle:2011 Forester |
Hey thanks for another great faq, I was wondering though about fuel pressure regulators. What are they, what do they do, and at which point should after market ones be used and why?
And another question I have is in regard to this post: Quote:
Also recently you posted in a thread I made in the newbie forums stating that I "would need fuel rails like a second butt hole". As much as I love to hear about my need for a second butt hole, this recommendation seems to be contradictory to what you have recommended in this thread, unless I misread/misunderstood things. Last edited by sburck; 03-30-2009 at 11:58 PM. |
03-31-2009, 03:10 AM | #69 |
Big Ron
Re-read the first post. Two tuners talk about fuel rails being unnecessary. If you want into on the exhaust question, that is answered in the Header FAQ as there are links to the 4 channel EGT testing that shows that a full TBE and to a small degree headers fixes the issue. The only reason for rails is bling, high HP, or getting them to make things easier and cleaner under the hood.
03-31-2009, 11:18 AM | #70 |
Member#: 191491
NESIC
Ah thanks, I thought those 2 links went to manufacturer home pages or user homepages.
04-15-2009, 02:10 AM | #71 |
Member#: 138256
W. Canada
Vehicle:2004 FXT Silver |
It'd be nice to add Foresters to the list. From what I've found out, 04-05 are 500/535, they are yellow side feeds. 06+ are 565cc top feeds.
04-15-2009, 02:43 PM | #72 |
Member#: 183529
Vehicle:i wanna help teh haters ... love life ... |
subscribed
04-15-2009, 10:29 PM | #73 |
Member#: 102730
WhyTF do people do that? Does anybody really need to know?
04-15-2009, 11:45 PM | #74 | |
Member#: 191491
NESIC
04-16-2009, 04:16 AM | #75 |
Member#: 183529
Differential FAQ: Read if you are thinking of upgrading! | Unabomber | Transmission (AT/MT) & Driveline | 164 | 12-25-2022 04:26 PM |
Transmission FAQ: Read if you are thinking of upgrading! | Unabomber | Transmission (AT/MT) & Driveline | 226 | 10-09-2020 07:01 PM |
Turbo FAQ: Read if you are thinking of upgrading! | Unabomber | Newbies & FAQs | 230 | 03-05-2020 02:15 PM |
Turbo FAQ: Read if you are thinking of upgrading! | Unabomber | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 72 | 02-15-2019 10:53 AM |
Suspension & Driveline FAQ: Read if you are thinking about upgrading! | Unabomber | Brakes, Steering & Suspension | 84 | 11-24-2016 02:52 PM |
