08-12-2020, 09:28 PM | #1 |
Member#: 486080
South East
Vehicle:2003 WRX Wagon PSM |
Bugeye JDM headlight question
Looking for some help. I’m in the process of installing the JDM headlights and the only issue I’m running into is that the orange plug that comes off the headlight does not match up with the plug coming off of the hid ballast. All the other JDM bugeye headlights I’ve seen had the white triangle connector the connects to the white triangle connector off the ballast. However for some reason mine is different. Has anyone ran into this issue?
08-13-2020, 01:58 AM | #2 |
Member#: 458809
NESIC
Vehicle:05 blob, 02 bug |
For direct plug n play you need ballast 84965FE010 (A1A4173000)
You can probably depin the wires from the triangle and plug them in directly to the square plug Or you can send those ballasts to me because I could use them |
08-13-2020, 06:11 AM | #3 |
Member#: 486080
South East
08-14-2020, 07:56 PM | #4 |
Member#: 515690
Vehicle:2007 Impreza 2.5I Wagon |
What I did when I encountered this issue is that I disassembled the the old headlight connector and the new jdm connector with a little baby flat head and reffited the jdm headlights with the old connector.
