Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 05-04-2020, 10:19 PM   #1
mrmikeyp
Member#: 296634
Default Romraider Logging cuts out at WOT
Hi all,
Heres some preliminary info:
02 wrx with v8 ej207.
Working with an E-tuner
Log of the time-skip attached
Tactrix OP-2
Windows 10 laptop. 4gig ram.
Romraider states my logging speed is around 3.6 s/sec k-line SLOW
Driving logs are fine as is flashing but the logging seems to stop around the 4k rpm mark in romraider while doing WOT logs. This is 'solved' by reducing my romraider parameters to like 5 or so, which isn't enough to log like I need to. Looking at the log you can compare the time column with the Throttle position column. When throttle position is at 100, the time skips happen shortly after.
Things I've tried
-A **** load of inline ferrite chokes
-Separate body grounds for the 4 and 5 pin on the OBD port
-Pushing pins in on the OBD Port
-Reducing parameters (helps, but etuner states we're at his bare minimum)
-reinstalling romraider/openecu and confirming latest java and definitions
-trying to use sample groups in a new logcfg.txt (attached) Made the issue worse...my fault probably as I'm a bit over my head with all that.
Anything else I'm missing or can try?
Thanks much.
log
http://www.filedropper.com/wot430
config
http://www.filedropper.com/logcfg
mrmikeyp is offline   Reply With Quote
Old 05-09-2020, 08:09 AM   #2
trueno92
Member#: 111755
Try this and let us know.
Ive had similar issues but it just snowed in may... no logging for me
https://www.romraider.com/forum/viewtopic.php?f=5&t=16463
Set the Logger definition file to use, make sure the car_def.xml is in the same dir.
Set the log output location.
SSM K-line needs to be selected.
Make sure everything is connected and the car ignition on or engine running, then start the Logger up.
trueno92 is offline   Reply With Quote
Old 05-28-2020, 02:30 PM   #3
kopele
Member#: 363007
2008 STI
Have you tried a different USB cable? Mine failed once and I had similar issues.
kopele is offline   Reply With Quote
Old 05-28-2020, 03:42 PM   #4
mrmikeyp
Member#: 296634
yea i did.
I just said the hell with it and figured out how to use the tactrix standalone logger. its not great but it works.
Old 08-17-2021, 11:28 AM   #5
iceman.kcmo
Member#: 264683
I had the same problem. Logging would quit after 4k. My problem ended up being a bad spark plug insulation. The porcelain cracked and was arking.
Secondary note: I did a dumb and purchased Iridium plugs from Amazon AND ebay and (big surprise) they turned out to be knock offs. Buy these from reputable parts stores only.
iceman.kcmo is offline   Reply With Quote
Old 08-17-2021, 11:29 AM   #6
iceman.kcmo
Member#: 264683
Old 12-28-2021, 02:25 PM   #7
mosorio29
Member#: 437877
I had a similar problem, a ground by the injectors rail was not connected after changing the injectors, it was reconnected and the problem was solved, check your ground connections
mosorio29 is offline   Reply With Quote
