04-20-2013, 12:54 PM | #26 |
Member#: 353364
Vehicle:2004 WRX Java Black Pearl |
I got it figured out. Switch was burned up, so it wasn't making contact other than when it was in the off position. Ordered a new switch and new harness, but my only concern now is what caused it to burn up in the first place. Ground wire from the harness to ground is pretty burned, too.
04-20-2013, 07:45 PM | #27 |
Member#: 53443
Vehicle:2001 LL Bean Outback Winestone |
If the entire ground wire shows signs of heat damage then too much current was flowing in it. That damage along with the switch damage may mean the blower motor is drawing too much current, but not enough to blow the fuse. You should at least check the current draw when you get it running to see if you need to change out the blower also. You don't want to damage the new parts. If the ground wire is just burnt at the connection to ground then it means the connection point was dirty and had some resistance.
04-21-2013, 01:32 PM | #28 |
Member#: 354123
Vehicle:2008 Impreza Outback |
Same problem with 'lost' power
Yeahoner; I'm having the exact same issue! Have you figured it out?
I checked the blower in a different car & it works, resistor seems fine, 'hotwired' over the relay and the fan spun (on high). I switched the relay, the one to the right of the blower & still nothing. Is there another relay I'm missing? Any advice would be appreciated. Lots of rain and no defrost makes wife unhappy. Also having the same issue with the other buttons not working...rear defrost, ect. |
04-21-2013, 02:55 PM | #29 |
Member#: 353364
The switch was really melted, and both contacts on the harness were charred, so I don't know if a bad contact caused a short, or if the motor is busted. Good idea to check it out, but how much current is too much on the motor?
04-21-2013, 04:55 PM | #30 |
Member#: 53443
Either the switch contact connection had some resistance to it or too much current is being drawn by the motor. I would guess normal draw for the motor at high sped would be around 8 amps but I'm not sure.
Dspacedd: There appears to be a problem with the relay control portion of the circuit that is causing your problem since you bypassed the relay and the blower worked. I think the switch normally makes a ground connection to the relay coil to activate the relay. You may have a blown fuse that provides power to the relay coil, or the switch isn't making the the ground connection to it. The info I have shows fuse 17 in the dash supplies power to the relay coil. If the power light for the AC switch doesn't work then you really need to check that fuse. Last edited by Cougar4; 04-21-2013 at 06:41 PM. |
04-21-2013, 05:43 PM | #31 |
Member#: 354123
Ah!!!!! That was it. Silly me; after taking apart everything in the inside I checked the rest of the fuses & the "A/C IG" fuse was blown. Replaced it and the motor runs fine! Now I just need to find out if my ac compressor is blown. Looked under the hood and the belt is MIA & the ac turns but makes a slight grinding noise when I spin it by hand. Hoping I don't have to replace the entire ac unit now.
Lesson learned...next time check more than just the 2 blower fuses. Anybody know if a grinding ac compressor can be fixed by anything short of replacing the whole unit? |
04-21-2013, 08:37 PM | #32 |
Member#: 53443
Good deal, glad it worked.
The grinding noise doesn't sound good to me at all. I suggest you talk to a good AC repair place about the issue. |
06-03-2013, 03:35 PM | #33 |
Member#: 352936
FIXED: same fuse here "A/C IG" was blown. A/C belt MIA as well, a little melting on the wire where it attaches to the back of the A/C clutch, clutch feels crappy, Might try to replace the bearing. I had to disconnect the wire to the A/C clutch or the fuse would blow again if I hit the A/C button on the dash. I live where it doesn't get that hot so I'm just going to live without A/C for a while.
06-03-2013, 03:36 PM | #34 |
Member#: 352936
thanks for the help BTW hope I don't need more soon.
09-18-2013, 01:01 AM | #35 |
Member#: 368660
Subaru Impreza Blower Fan Not Working
i have a 2006 subaru impreza and has a problem with the blower fan not working, i have powered the fan with 12V and it works but the terminals that supply the blower fan have no voltage, what could be causing this?
09-18-2013, 02:14 AM | #36 |
Member#: 53443
First thing to check is the fuses and verify they are getting power through them using a test light probe. If they are ok then the blower relay needs to be checked. Power passes through it and then to the motor.
09-18-2013, 09:58 AM | #37 |
Member#: 352689
Vehicle:2004 Impreza dark green but looks blak |
You can check the connection to ground by running a heavy cable from the component's ground pin back to the battery negative terminal. If things improve it's probably a bad ground connection.
The cable can be a jumper cable or several feet of stranded #10 AWG copper. The resistance of this wire won't be as low as the resistance of the metal car body but it will be low enough. |
03-29-2018, 01:14 PM | #38 |
Member#: 483982
Hello,
I have a 98 subaru legacy and the blower motor stopped working. I have checked both fuses in the fuse box and have no power. Both fuses are good. I have changed the hvac sensor with new still no power. I have tested the blower motor and it works great. I have changed the switchs still no power at the fuses in the fuse box. Any ideas??? |
03-29-2018, 04:48 PM | #39 | ||
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
Read the next post...... Quote:
06-27-2018, 07:37 PM | #40 |
Member#: 487712
So check blower motor > blower motor resistor > blower motor relay > blower motor fuses.
Do the tests, develop a conclusion and report back here and we can furthermore help you out.[/quote] Im very new to all of this and apologies if I come off as noobish, but i have checked everything you have listed here and still cant figure out what the issue is. I've got a 2012 wrx the ac does not blow anything at all, no cold air or warm air. Being that I live in South Florida in the summer, this has not been a fun ride so far. The background lights turn on when i turn on the lights of course, however the small lights when you press on either of the ac gauges do not turn on, nothing seems like it turns on. Ive replaced the ac resistor since when I had tested it, it had no power. Now I'm just kinda stomped. Checked the fuses, the relay, the resistor, and the blower motor everything is working so what could be the problem? |
06-29-2018, 10:02 AM | #41 | |
Member#: 30669
Using a test light or meter (set on 12 or 20 VDC) put one end of your tester on a ground, the other end on each little tab on the front of the fuse..... Battery volts/light on both, fuse is good No battery volts/light on both, key needs to be on or another circuit dead Battery volt/light only on one tab, fuse is blown, replace it. Have you tried running power and a ground to the motor? No lights sounds like a fuse or bad ground. Last edited by Charlie-III; 06-29-2018 at 10:11 AM. |
07-02-2018, 09:32 AM | #42 |
Member#: 3409
NWIC
Vehicle:98 My FMIC Is bigger than yours. |
I would consult the schematic on that one, and check all fuses listed. There may be more than the obvious ones.
2012 WRX may be an a/c control module instead of just a switch panel, so that could be bad as well. |
03-03-2021, 01:51 AM | #43 |
Member#: 494237
Wanted to say thanks to the people who posted about where in the circuit the resistors were. This was back in 2013. My new-to-me 2009 Outback Sport had a known issue with the fan when I bought it. It only ran on high. Sounds like the resistors issue. Soon after I got it the fan stopped working entirely.
When I went looking I found 'custom' wiring to the terminals on the fan, one of them went to a nearby bolt for ground. The resistors were unplugged. After replacing the resistors and plugging them back in I didn't get any better luck with the fan. It would work if powered directly. I was also getting 12v from one of the wires. Turned out one of the terminals on the motor was bad and making an intermittent connection. Or it was the dodgy terminal the previous owner wired up. I replaced the motor and when using the dodgy wiring it was still intermittent. After replacing the power wire connector with slightly upgraded connections I at least was back to full power on the fan, but only full power. I had read this thread before getting this far, but it took driving the car about 90 minutes before it sunk in that I needed to put the grounded wire back to normal because the resistors were after the motor in this car. After putting the grounded wire back to the wiring harness everything works as expected. Whew. Hopefully that's the worst of the issues with this car. |
Blower motor not working on setting 4 (1993 Impreza) | STi_v4_Wagon | Service & Maintenance | 6 | 01-14-2010 09:41 AM |
AZ, AC Blower not working at all!!! | SpankySuby | Electrical & Lighting | 6 | 07-23-2008 06:13 PM |
I installed a SATA Raptor drive, why does my IDE CDROM run slow/not work at all? | White 2.5rs | Off-Topic | 17 | 06-07-2006 11:46 AM |
lights and blower motor not working | NicEJ25 | Electrical & Lighting | 2 | 09-09-2003 08:10 PM |
Overdoing ground mod will cause it to not work at all! | d4d4d4d4 | Electrical & Lighting | 4 | 07-14-2003 04:25 PM |
