07-03-2015, 08:42 AM | #326 |
Member#: 70395
The big issue is if it repeatable or not and if the knock is clustered around an area and not random.
07-03-2015, 01:06 PM | #327 |
Member#: 174442
Vehicle:2007 SuperWagon I don't spell well |
You should run an analysis of you hour+ log and see if all the reported knocks are clustered around a particular load/rpm. There is a spreadsheet in rr to do this. Then play with timing in that area to see if you can reduce it
07-03-2015, 03:20 PM | #328 |
Member#: 174442
A couple more thoughts:
First make sure the knock is real. The stock sensor can interpret certain engine noise as knock. Easiest way to do this is to make yourself a auditory knock sensor. The. You can listen to the engine and see if you hear it knock when the ecu reports a knock. Make sure you don't have a bolt laying on the block that you dropped in there and that nothing is loose and tapping the block. Finally if you find where your knock is concentrated and verify that it's real, make small adjustments to you timing to see if things get better. |
07-03-2015, 03:54 PM | #329 |
Member#: 414762
Vehicle:06 Wrx sti Blllllack |
Bump so I cAn follow
06-04-2017, 11:55 AM | #330 |
Member#: 468766
Vehicle:1998 impreza wagon green |
So just to clear things up for me as I'm new to the opensource tuning world, would you be able to do an N/A to turbo conversion on the stock ecu (obviously other supporting mods would be needed) so long as you had the knowledge to tune the computer properly?
07-31-2022, 12:05 PM | #331 |
Member#: 530898
This has been real helpful tuning my WRX
04-22-2023, 01:06 PM | #332 |
Member#: 371521
NESIC
Vehicle:2002 WRX PSM :( |
Is this guide still available somewhere?
05-23-2023, 10:41 PM | #333 |
Member#: 534363
It is, I found it here: http://www.clicksoft.ro/A-Subie-Newb...-Guide-1_0.pdf
My Swap: 1999RS to 2002WRX. Complete Wiring Guide Inside | 99 rs | Subaru Conversions | 251 | 09-13-2021 12:01 PM |
A complete n00b's guide to changing the oil in your WRX (with pics!) | perret318 | Service & Maintenance | 153 | 11-28-2013 01:17 AM |
Complete open source tuning guide | shutupnshift04 | Commercial ECU Reflashes | 19 | 05-10-2007 05:16 PM |
Updated StreetTUNER Tuning Guide and Tuning Guide Worksheets... | Christian. | AccessPort | 0 | 04-17-2007 05:24 PM |
Complete Price Guide. | Diabolical1 CC | Canada Region Forum | 0 | 06-20-2006 02:40 AM |
