07-14-2005, 04:55 PM | #1 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
Unofficial FAQ: Bolt Sizes
I think this would be a great resource to have and is long overdue. Everyone share your information with as much accurate detail as possible. I will gather it all in this top post.
Common to WRX or STI regardless of year Front O2 sensor plug = M18 x 1.5 Up-pipe EGT plug = M12 x 1.25 ECU cover plate = M6 x 1.0 Intake manifold to TGV risers = M6 x 1.00 x 40 Sway bar bolts (bushings and endlinks), strut tops, ram intake duct, the spare tire hold-down, plastic splash shield, and jacking plate = M8 x 1.25 Exhaust bolts and a bunch of other stuff under the hood (green brackets for fuel rail, radiator mount) = M10 x 1.25 EGT bung, lug nuts, and shift knob = M12 x 1.25 Gallery threading on the block for oil pressure/temp sensors = M18 x 1.5 Oil drain bolt = M20 x 1.5 Uppipe stud: automotive stud, M10 x 1.25 by 41mm The female fitting on the clutch line is M10x1.00 The banjos on the brake calipers are also M10x1.00 The banjo on the turbo for the oil feed line is M10X1.5 Top-mount intercooler mounting bolts are 8X1.25 Rear seat upper part (3 of them) are 10x1.25 Rear seat lower part (2 of them) are 8x1.25 Front fender attachment inside the engine bay is M6 x 1.0 x 10 Breather lines attaching to TMIC (3) are M6 x 1.0 x 10 Model Year or Make-Specific 2002-2005 WRX: Caliper bracket to HUB bolts are M12 x 1.25 x 30 (Property class 6.6) NOTES If you can find it, grade 8 hardware is the way to go, especially high torque spec ones. Bigger bolts/plugs such as M18 x 1.5 can be found at many automotive parts stores as oil drain bolts either with the oil change supplies or behind the counter. THANKS: tdxflex Unabomber checque specialev ...and everyone else who has replied in this thread with info!
07-14-2005, 06:34 PM | #2 |
Member#: 13634
NESIC
Vehicle:2002 WRX WRB |
02 WRX
m6 x 1.0 ECU cover plate m8 x 1.25 for the sway bar bolts (bushings and endlinks), strut tops, ram intake duct, the spare tire hold-down, plastic splash shield, and jacking plate m10 x 1.25 for the exhaust bolts and a bunch of other stuff under the hood (green brackets for fuel rail, intake manifold, radiator mount) m12 x 1.25 for EGT bung, lug nuts, and shift knob m18 x 1.5 for o2 bung, the gallery threading on the block for oil pressure/temp sensors m20 x 1.5 oil drain bolt unsure of: bov, intercooler mounts - I think are m8 x 1.25, either that or m10 x 1.25 brake caliper bleeder and clutch bleeder - not sure if it's m7 x 1.0, but they're both the same threading rear seat mounting bolts look like they're m10 x 1.25 Last edited by tdxflex; 07-14-2005 at 06:49 PM. |
07-14-2005, 07:54 PM | #3 |
Big Ron
Super Moderator Member#: 18062
Good idea, I started this awhile back and lost interest.
Uppipe stud: automotive stud, m10 x 1.25 by 41mm You may also mention that grade 8 or better is the way to go with bolts. No sense in having someone buy some cheapo Home Depot stuff to just have it break during the tightening sequence. You may also mention that bigger bolts/plugs such as M18 x 1.5 can be found at many automotive parts stores as oil drain bolts either with the oil change supplies or behind the counter. |
07-14-2005, 09:11 PM | #4 |
Member#: 63824
South East
Vehicle:05 WRX WRB pearl Cobb II+ |
joined........................
12-02-2005, 12:48 PM | #5 |
Member#: 68562
Vehicle:RIP Edwin |
There's no way the 8 bolts holding the intake manifold down are M10, I haven't found the right size yet, but when I do I'll edit this post with what they really are.
12-02-2005, 12:52 PM | #6 |
Member#: 8512
South East
I think you're right, checque. In my case (JDM version 8 intake manifold), it bolts right to the heads and has no TGV housings.
Please do let me know what you find for a typical setup (bolts for manifold to TGV housings). |
12-02-2005, 01:39 PM | #7 | |
Member#: 47769
12-02-2005, 04:13 PM | #8 |
Member#: 68562
Vehicle:RIP Edwin |
Alright, I was going to just edit my other post, but I'll keep it less confusing and make this the most recent post on the subject.
The 8 bolts holding down the intake manifold are M6 x 1.00 x 40. Anywhere you can buy bolts you will easily find this size. Edit: Note that I own an 05 WRX at this time. |
12-02-2005, 04:16 PM | #9 |
Member#: 8512
South East
Updated top post.
12-02-2005, 10:29 PM | #10 |
Member#: 82741
NESIC
Vehicle:2007 350Z Silver |
What size are the bolts that attach the engine to transmission case?
12-03-2005, 12:39 AM | #11 |
Member#: 22902
TXIC
Vehicle:2005 STI CGM |
Yes what size are those bolts??? I need to get my new longblock onto the engine stand and I'm going to make a trip to Lowe's tomorrow to buy one of everything until I find it.
12-03-2005, 01:03 AM | #12 |
Member#: 45726
Vehicle:2007 Mazdaspeed3 Cosmic Blue |
I've learned by hard experience that SAE unit fasteners are "grade" and Metric fasteners are "class".
To get "grade 8" equivalent metric fasteners, make sure they are "class 10". To my dismay, "class 8" fasteners are about equivalent to "grade 5"...bleh |
12-03-2005, 05:05 AM | #13 |
Member#: 64974
Vehicle:1995 WRX,APEXi,HKS,$ Faded, Stonechipped Red |
Bell housing bolts are M10X1.25.
There are really only a handful of sizes on a Subaru, (or any jap car really). S/Plugs are std M14, EA82 head bolts are M11X1.0-trying buying that size at hardware!! I'm sure these are listed in a manual somewhere...... Sixpack |
12-03-2005, 01:44 PM | #14 |
Member#: 19057
Vehicle:2002 WRX & Blue Ford & '72 CB350 |
fogdor- you're right, but the class is much more informative than grade.
http://www.marylandmetrics.com/tech/u19e2.htm http://home.jtan.com/~joe/KIAT/kiat_2.htm |
12-03-2005, 08:46 PM | #15 |
Member#: 90156
NWIC
Vehicle:1986 Syncro Vanaru 07 SV650 |
These articles on bolts that Lyve posted are a really good read. I would suggest them to one and all. I speak particularly in reference to the second link. |
12-03-2005, 08:59 PM | #16 |
Member#: 64974
Very Good......note the part about Loctite being a good lube by design....great stuff that Loctite!!LOL.
02-10-2006, 02:32 AM | #17 |
Member#: 90156
NWIC
M6X1.0 on the DP heat shield.
03-06-2006, 09:44 AM | #18 |
Member#: 38425
RMIC
Vehicle:2015 STI CWP |
Are you sure the oil drain plug bolt is M18x1.5? I thought it was an M20...
03-06-2006, 10:09 AM | #19 |
Member#: 19057
The Caliper bracket to front hub on the two pot WRX brakes is an M12x1.25x30...
i would figure this is an alloy steel bolt with a property class better than 8.8, likely its 10.9. However the marking on the head is a 6 with a dot under it. If you brake this bolt off you are going to have a devil of a time finding something the right size and length with a small enough head. Instead you can temporarily use a hardened threaded rod and two nuts. (I went to a midas and asked if they could help me. 15min later the broken bolt was out of the caliper bracket, I had two double nutted studs and only had spent $10.) That will get you by until the dealer is open on monday. Use antisieze on these. The whole length too... (it also seizes to the knuckle, not just in the threads.) |
03-06-2006, 01:04 PM | #20 | |
Member#: 8512
South East
So - reader beware. Updated top post. |
03-20-2006, 10:27 PM | #21 | |
Member#: 90156
NWIC
Sorry for causing any confusion. |
03-21-2006, 11:18 AM | #22 |
Member#: 19057
I also have provided bad information.....
The cliper bracket to HUB bolts are M12x1.25x30.... However they are Property Class 6.6 (so they will bend a lot before they break) not 10.9 in my above post... And also on the larger bolts there are head markings of a number with a dot under it... Those are the property class... |
03-23-2006, 03:18 PM | #23 |
Member#: 92378
Vehicle:2002 Impreza WRX Aspen White |
Bolt size for the rear exhaust hanger?
03-23-2006, 03:26 PM | #24 |
Member#: 8512
South East
Okay, so I have the following now:
Oil pan: M20 Oil galley on top of block near crankcase vent: M18 Correct? |
03-23-2006, 03:32 PM | #25 |
Member#: 38425
RMIC
Thats correct for the oil drain plug...I bought a new one and it has M20 imprinted on the top of it.
PCV line -> Intercooler bolts - Bolt Size? | andrewt461 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 09-14-2011 04:40 PM |
Bolt size for bolt on exh mani heat shields? | djoye | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 11-08-2007 01:24 PM |
Oil Cooler Bolt Bolt Size??? | Drink | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 09-11-2006 12:23 PM |
Bolt size/thread pitch for seat bolts? | anti.team | Interior & Exterior Modification | 1 | 09-30-2004 10:42 AM |
Bolt size for airbox? | blaster88 | General Forum Archive | 3 | 02-13-2001 03:49 PM |
