Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 04-15-2021, 10:22 PM   #1
CallMeF
Member#: 396580
Default Awd light flashing
Awd light still flashing!
2015 sti
Setting on KW V3 -30k miles.
Volk ZE40 18x10 +35 square set up
255 35 18 tires lots of tread
Things I have already done
alignment ***65532;done by Subaru
Bought hub centric rings
Changed front and rear diff fluid by Subaru
Bought new TPMS sensors (they went bad)
Tires are all the same
Tires all have the same tread depth
Tires all have the same psi
1 speed sensor replaced by Subaru
Problem only happens when I use my ZE40.
The car is back at Subaru to check out the wheel bearing. The wheel bearing are not making any grinding noises though.
I have a new set of 255/35/18 I could put on.
Could the coilovers be the problem? if I set them too soft?
Or the camber?
Brake and rotors? (It is time for them to be changed)
I plan going to a alignment and suspension specialist. There is a two week wait list before they can get me in.
If someone has some input that would be great. I feel like I am throwing money at this yet the problem refuses to go away.
Thank you.
CallMeF is offline   Reply With Quote
