03-30-2021, 08:25 PM | #1 |
Member#: 336566
3.9 or 3.54
I have a 2009 wrx. i have a 05 usdm sti rear diff which is 3.9 f.d. i want to swap a 6spd. i am reading different things about the reduction ratio. If a 6spd has a 1.1 t.r. does that make the rear 3.54? if i put in a 1.1 6speed, is it hard to swap pinion and gear in rear diff? can it be done without having to remove diff from car?
03-30-2021, 11:19 PM | #2 |
Member#: 395793
Vehicle:2005 92x Aero Beige |
Probably the easiest option is to sell the diff and just get the GR 6 speed. Going in and swapping stuff to make it work may end up costing more money than you think. Unless you have the proper tools and know how for working on a trans.
03-30-2021, 11:32 PM | #3 | |
Member#: 487057
BAIC
Vehicle:2002 WRX Wagon PSM |
1:1 will need 3.9 The swapping of parts is not hugely difficult, but you will need to set gear lash. If you've never done it before, it might be kinda tricky. I also wouldn't attempt it with the diff in the car. |
