Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 10-21-2020, 06:12 PM   #1
U7TRA_
Member#: 518170
Default 2007 Subaru Impreza 2.5i - Cannot Read ECU
First I tried an FTDI cable with no success, now i have a tactrix cable still nothing.
Green Connector is connected, using latest version of ECU flash.
this is the error i get.
U7TRA_ is offline   Reply With Quote
Old 10-26-2020, 03:06 AM   #2
gabedude
Member#: 10108
1874 Bicycle
You can read without any defs... Something else is wrong...
gabedude is offline   Reply With Quote
Old 10-26-2020, 03:07 AM   #3
gabedude
Member#: 10108
1874 Bicycle
The logs in your screen looks like some short. Try another cable.
Old 10-26-2020, 03:02 PM   #4
zcivic
Member#: 199691
04 Forester XT
I’ve not flashed your particular ecu type but do you have the correct vehicle selected? I noticed it’s using the 05 sti. I had a problem flashing an auto xt because I didn’t select a 512map tried using same settings as my manual xt which was 04sti. What I ended up doing was downloading a stock rom and upload it to see what it selected for read/write.
zcivic is offline   Reply With Quote
Old 10-26-2020, 08:40 PM   #5
U7TRA_
Member#: 518170
I do have the right ECU selected I believe it bundles in '04 '05 '06 '07. It's on texted the cable maker and they're saying they're sending me a new cable that they tested and verified should work so we'll see and I will update the thread once I get it.
Old 10-26-2020, 09:46 PM   #6
benflynn
Member#: 515308
I had the same issue with my 06 forester 2.5x, ended up being bad ecu,
benflynn is offline   Reply With Quote
Old 12-11-2020, 05:57 AM   #7
pcampbell
Member#: 437670
2005 2.5 SC OB
Did you look at the log?
pcampbell is offline   Reply With Quote
Old 02-15-2021, 11:08 PM   #8
U7TRA_
Member#: 518170
Where would it be I checked the drop downs. Besides the one screen logging you see I didn't find anything elsem
Old 05-18-2022, 03:24 PM   #9
Quik55
Member#: 287079
2007 Impreza 2.5I
Are you still having issues or did you get it figured out. Working through the same issues with my '07 2.5i MT .... Just got to read my ROM for the first time today but not defined so I've hit another brick wall ..... Might be able to assist each other
Quik55 is offline   Reply With Quote
Old 05-18-2022, 04:16 PM   #10
benflynn
Member#: 515308
I run a 07 Impreza rom in my undefined 06 forester so I could tune it
Old 05-18-2022, 08:57 PM   #11
Quik55
Member#: 287079
2007 Impreza 2.5I
Appreciate that ... You mean you picked the closest ROM and rolled with it? When I selected the "wizard for developers only" option it did give me a ROM that was close ..... Think that might work? Really looking to tune myself with some custom A/F ratios due to secondary fuel addition.
Old 05-18-2022, 09:20 PM   #12
benflynn
Member#: 515308
Forester and Imprezas should work, something is different with legacies
Old 05-21-2022, 11:23 AM   #13
jon7009
Member#: 394646
2003 WRX Flex Fuel
Pv=nRT
2007 is an odd year sometimes, with some legacy models, but I've not flashed an n/a ecu of that year. 08+ though, you have to do this trick, in my experience.
you may need to set your communication method to canbus, go into options, and change your CAN seed key to SSMk0 and if that doesn't work, try SSMk1.
jon7009 is offline   Reply With Quote
