Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 10-23-2015, 11:08 PM   #26
wv2.5i
Member#: 325693
2015 WRX SOLD
Yeah mine has the sti short throw as well, did you get yours replaced and did it fix the issue?
wv2.5i is offline   Reply With Quote
Old 10-23-2015, 11:37 PM   #27
Annihilator817
Member#: 296742
'16 STI, '11 WRX,
'96 328i DSP
Many, many short throws were port installed incorrectly on these cars, causing cables to bind and even break.
There is a thread on that somewhere.
However, what Ive read in this thread, just sounds like WRX Ive ever driven.
Perhaps you people just are not used to the noisy, clanking, sloppy gearbox that Subaru puts in the WRX.
Annihilator817 is offline   Reply With Quote
Old 10-24-2015, 09:11 AM   #28
wv2.5i
Member#: 325693
2015 WRX SOLD
Good to know about the short throw I'll try and find the thread. I've driven a decent amount of them and the 2015 is a bit more clunky sounding IMO because of the counterweight, but what I'm describing is a bit different. And only from 2nd to 3rd upshift. If we are saying on every 2015 this exists then I just won't worry about it.
Old 10-24-2015, 06:11 PM   #29
Wrx_Blasian
Member#: 424402
2015 WRX
They replaced the bearings after I brought it back a second time for the same issue
Wrx_Blasian is offline   Reply With Quote
Old 10-24-2015, 08:06 PM   #30
wv2.5i
Member#: 325693
2015 WRX SOLD
And how is it doing?
Old 10-25-2015, 01:59 PM   #31
Wrx_Blasian
Member#: 424402
2015 WRX
Good so far, no issues no sound even on cold mornings
Old 10-25-2015, 05:52 PM   #32
wv2.5i
Member#: 325693
2015 WRX SOLD
Hmm...maybe I'll take it in and ask them about the shift.
Old 10-26-2015, 04:14 AM   #33
Wrx_Blasian
Member#: 424402
2015 WRX
It took twice to get them to recreate what happened.... They had the cat for 4 days the first time and 2 days the second time, they said thru drove it everyday, the last day finally the tech was able to recreate the shifter issue. Noise when clutch was depressed went away and the stick has been good ever since. I would say take ut in, tell them under what circumstances the shifter has issues as good as you can so they have the best chance of recreating the issue. Best of luck to you
Old 10-26-2015, 11:03 AM   #34
wv2.5i
Member#: 325693
2015 WRX SOLD
Thanks man.
Old 12-07-2015, 09:04 PM   #35
subaski87
Member#: 434528
2016 WRX
When I had my 06 wrx, I used to "double clutch" and launch that car all the time- well I ended up destroying the 3rd/4th gear syncros cost me 2 grand back in 07 to fix. Sounds like u have the same problem
subaski87 is offline   Reply With Quote
Old 03-18-2021, 02:30 PM   #36
SeenSeenCoCoBean
Member#: 442520
Default Racing stock transmissions will cause gears to grind
No one wants to accept that racing a WRX with stock transmission causes gears to grind. If you don't want your stock transmission to grind then
A. Buy upgraded transmission
B. Drive like you have a stock transmission
SeenSeenCoCoBean is offline   Reply With Quote
