06-02-2012, 11:39 AM | #1 |
Member#: 315875
Vehicle:2007 WRX Dark Silver |
My DAM is at .75.... ): should I be worried.
Ok, I did some logs after getting my accessport. The car has a Perrin TMIC. Cobb downpipe and cbe. 91 gas shell. Should I be worried?
https://docs.google.com/spreadsheet/...TYtUGFpSlNoQWc https://docs.google.com/spreadsheet/...YbUVLY2c#gid=0
06-02-2012, 05:00 PM | #2 |
Member#: 315875
Anybody? btw the car is an 07 wrx. the logs were in 3rd gear at night around 90ish temp.
06-02-2012, 09:16 PM | #3 |
Member#: 267463
yes. that means your timing advance is being reduced majorly because the ecu has seen some major knock. Its not seeing major knock now because the DAM is reduced. If you reset the ecu, the DAM will go back to 1 and the knock will more than likely come back up (assuming you have the same gas in it).
if it was me, i would reset the ecu, and drive with the AP on to monitor the feedback knock. If you see some -2.8 knock during your driving then something aint right. may need to change maps. map you are running would be helpful to know. |
06-02-2012, 10:05 PM | #4 | ||
Member#: 274499
NESIC
Vehicle:1994 5.8T Cobra 755rwhp @ 16psi |
06-02-2012, 11:58 PM | #5 |
Member#: 280912
Vehicle:08 STi Dark Gray Metallic |
I'm new to tuning, so I may be wrong, but in order to get good log data shouldn't logs be taken at WOT from around 2500 rpm to redline in 3rd for a 5 speed and 4th for a 6 speed? I just noticed that he wasn't running WOT.
06-03-2012, 12:06 AM | #6 |
Member#: 280912
how long does it take the ECU to learn up to the max DAM value, which in this case should be 1.
06-03-2012, 02:05 AM | #7 |
Member#: 180748
VIC
Vehicle:2013 Scion FRS Whiteout |
Are you running a Perrin map? Or is it protuned? If it's not tuned for the perrin tmic, I'd start there
06-03-2012, 02:18 AM | #8 |
Member#: 315875
im running cobb's stage 2 acn 91 map. the log was in third gear. I've been driving the car for 100 miles before i did the log. i will try to reset the ecu and see what happens. Is it bad to drive the car regularly with a .75 dam?
06-04-2012, 08:45 AM | #9 | |
Member#: 4803
Bill |
06-04-2012, 11:35 AM | #10 |
Member#: 315875
Ok, thanks Bill. Does my data log look ok though? It seems like im underboosting? I will update with another data log after maybe another 100 miles.
06-04-2012, 12:02 PM | #11 | |
Member#: 4803
Bill |
06-04-2012, 09:36 PM | #12 |
Member#: 267463
didnt know the dam starts at .5 on these cars... my bad. thats why cobb is the expert.
06-04-2012, 11:36 PM | #13 |
Member#: 274499
NESIC
You didn't actually read the responses... Did you?
12-31-2020, 01:10 PM | #14 | |
Member#: 510671
SCIC
Vehicle:2006 WRX Gray |
I was looking at my base map in ecuFlash and the initial value of the IAM (assuming it is the same as DAM) was .75. Stock this value was .5 There is also an Advance Multiplier Step Value which is set to 0.25 on both stock and the base tune from XPT. I am guessing that the step value is reduced by some other multiplier, because there is only one step of 0.25 between 0.75 and 1.0 ? |
02-22-2021, 11:51 PM | #15 |
Member#: 522570
Vehicle:2005 STI WRB |
This happened to me. I won't give details as it wasn't good news.
Moving company is moving my STi: what should I be worried about? | palpullero | General Community | 20 | 01-25-2008 11:56 AM |
spilled some oil on my exhaust wrap, should I be worried? | leonbmx | North West Impreza Club Forum -- NWIC | 12 | 01-22-2008 07:16 PM |
spilled some oil on my exhaust wrap, should I be worried? | leonbmx | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 15 | 01-21-2008 07:11 PM |
My car shoots FIRE!! should I be worried? | imprezive | Normally Aspirated Powertrain | 38 | 06-16-2004 11:18 PM |
Continuous gastric noises are coming from my dog. Should I be worried? | George71 | Off-Topic | 16 | 01-12-2004 12:20 PM |
