10-20-2009, 02:57 PM | #1 |
Member#: 187021
Vehicle:2004 WRX Sedan PSM |
Openport 2.0 Standalone Logging
I just started playing with the openport 2.0 standalone logging beta. It works nicely if you set up your logcfg file correctly....laptop free logging
http://forums.openecu.org/viewtopic....9763b02a18e0d6
10-27-2009, 08:06 PM | #2 |
Member#: 187021
Here's a sample logcfg file that I modified from Colby's sample file for MAF scaling data.
Code:
;uncomment the line below to minimize the information written to logcfg.out ; this will greatly decrease the startup time to begin logging if you already ; have a working logcfg.txt without any problems ;debug=noout ; sample logging configuration file for openport 2.0 ; must be named logcfg.txt and be placed in the root directory of the ; microSD card inserted in the openport in order to work ; this sample logs using the SSM protocol over the K-line, which works ; for both CAN-based and older Subarus ;----------------ssm---------------- ; log channel settings ; we are logging SSM via the K-line type=ssmk ; each parameter gets a name you chose paramname = RPM ; the paramid is used in the SSM request paramid = 0x0E ; how many bits in the returned value (defaults to 8, so you usually don't ;need to specify ;this) databits = 16 ; how to scale the results using a RPN ;(http://en.wikipedia.org/wiki/Reverse_Polish_notation) notation, with data and ; operators seperated by commas ; the operators are as following: ; + : add ; - : subtract ; * : multiply ; / : divide ; ; x : represents the raw (unscaled) parameter ; 123.456 : example of a constant ; ; if no scaling is specified, the raw value will be used ; ; the OP2 has no FPU - it must do floating point calculations in software which can ; create performance issues, so be efficient in your RPN expressions by doing the following: ; ; * minimize the number of operations; e.g. ((x * 2) + 1) * 2 => x * 4 + 2 ; * don't divide by a constant when you can multiply instead; e.g. x / 4 => x * 0.25 ; * don't make constant expressions that can instead be pre-calculated; e.g. x * 3 / 4 => x * 0.75 scalingrpn = x,0.25,* ; commented out here is an example for reading a direct RAM parameter, a 32-bit float in this case ;paramname = load ;paramid = 0xFF6578 ;isfloat = 1 ; the raw data is a 32-bit floating point number (no need to set databits = 32) paramname = IAT paramid = 0x012 scalingrpn = x,40,-,1.8,*,32,+ ;scaled in F paramname = coolant_temp paramid = 0x008 scalingrpn = x,40,-,1.8,*,32,+ ;scaled in F paramname = MAF paramid = 0x013 databits = 16 scalingrpn = x,0.01,* ;g/s paramname = MAFv paramid = 0x01D scalingrpn = x,0.02,* ;v paramname = AFC#1 paramid = 0x009 scalingrpn = x,128,-,0.781,* ;% paramname = AFL#1 paramid = 0x00A scalingrpn = x,128,-,0.781,* ;% ;-------------triggers--------------- ; ; note that parameters must be previously defined ; before defining triggers using them ; ; triggers allow you to control when logging starts and stops ; this example sets up triggers such that logging only occurs ; when the engine is running (RPM > 0) ; ; triggers consist of a condition (a RPN expression using comparison operators) ; and an action. the RPN comparison operators match those in the C language: ; ; > < >= <= == != && || ; ; if the condition evaluates to a non-zero value, that action is taken conditionrpn = RPM,0,>,coolant_temp,180,>,&& action = start conditionrpn = RPM,0,== action = stop Last edited by jarencibia; 11-06-2009 at 10:42 AM. Reason: Load parameter borked |
10-28-2009, 04:53 PM | #3 |
Member#: 70011
NESIC
Cool! Has anyone set it up to control logging with the rear defogger button.
10-28-2009, 07:06 PM | #4 | |
Member#: 187021
; here is a second triggering example using the rear defogger switch ; uncomment it and comment out the sample above to use it ;paramname = defogger_sw ;paramid = 0x64 ;databits = 1 ;offsetbits = 5 ;isvisible = 0 ;conditionrpn = defogger_sw,1,== ;action = start ;conditionrpn = defogger_sw,0,== ;action = stop Last edited by jarencibia; 11-10-2009 at 10:30 AM. |
10-28-2009, 11:30 PM | #5 |
Member#: 165749
makes me wish i had a 2.0... anyone want to trade a 1.3 for a 2.0?
10-31-2009, 09:42 PM | #6 |
Member#: 223239
testers wanted for a beta tool for creating the logcfg.txt file
http://forums.openecu.org/viewtopic.php?f=57&t=4396 |
11-06-2009, 10:40 AM | #7 |
Member#: 187021
Ok I'm down for testing and will DOO EET
11-09-2009, 11:40 AM | #8 |
Member#: 219696
Vehicle:2004 STi PSM |
How big a card do you run?? Does it work off defog??
11-09-2009, 01:07 PM | #9 |
Member#: 229452
I have a few questions and some additional paramids
1. Do I need to read the flag bytes? If not how do I access the bytes? I read the flag byte with the ignition switch. paramname = IGNITIONsw paramid = 0x062 ;bool I used it like this. conditionrpn = IGNITIONsw,8,== action = start conditionrpn = IGNITIONsw,8,!= action = stop I would like to be able to get this data without adding it to the log file. I only need it so that I can make some logic. I would also like to be able to perform logic operations in the scalingrpn. Can you provide some Simple shift left and right operations in the scalingrpn? paramname = Load % paramid = 0x07 scalingrpn = x,0.392157,* ;Load is scaled in percent, multiplier = 100/255 paramname = coolant_temp paramid = 0x008 scalingrpn = x,40,-,1.8,*,32,+ ;scaled in F paramname = AFC#1 paramid = 0x009 scalingrpn = x,128,-,0.781,* ;% paramname = AFL#1 paramid = 0x00A scalingrpn = x,128,-,0.781,* ;% paramname = RPM paramid = 0x0E databits = 16 scalingrpn = x,.25,* paramname = IAT paramid = 0x012 scalingrpn = x,40,-,1.8,*,32,+ ;scaled in F paramname = MAF paramid = 0x013 databits = 16 scalingrpn = x,0.01,* ;g/s paramname = MAFv paramid = 0x01D scalingrpn = x,0.02,* ;v paramname = O2sensor paramid = 0x01A databits = 16 scalingrpn = x,0.005,* ;volts paramname = injector#1width paramid = 0x020 scalingrpn = x,0.256,* ;ms paramname = Roughness paramid = 0x0CE ;unknown scale paramname = Air/fuel%correction paramid = 0x01A scalingrpn = x,1.28,* ;% paramname = IGNITIONsw paramid = 0x062 ;bool Mike |
11-09-2009, 01:10 PM | #10 |
Member#: 229452
I also noticed that the minimum rpm reported was 25. You will need to take this into account if you use rpm to end the log.
Mike |
11-09-2009, 01:20 PM | #11 |
Member#: 229452
To get and test the defogger like I did with the ignition use this.
paramname = Defoggersw paramid = 0x064 ;bool the id is bit 5 or the value 16 conditionrpn = Defoggersw,16,&& action = start conditionrpn = 0,Defoggersw,16,&&,== action = stop |
11-16-2009, 03:30 PM | #12 |
Member#: 207229
NWIC
Vehicle:2006 WRX wagon Graphite |
Use this link to download the config tool for setting up a config file for your sd tactrix. Once downloaded just pick your ecu from the dropdown and then check off the parameters you wish to log, then save the file to the main directory of your SD card.
http://forums.openecu.org/viewforum....e11a45c31f7470 |
03-22-2010, 06:09 PM | #13 |
Member#: 184498
Vehicle:2007 STi Ltd UGM |
Wanted to toss my name in the ring as well. I am still trying to set up my logcfg file for all of the info I want, but right now I am trying to overcome and issue when logging with K-Line. My OP2 shows it is logging during the entire run, but the CSV only contains 5 points of data (up to the timestamp of 1.2). Posted over on the openecu forum and am talking with Colby about it. I have an 07 STI if anyone has any advice...
Also, is there a good resource to find what the paramid (and logical scalingrpn values) are for every piece of data that the ECU sees? Would using the Romraider Logger definitions help guide me to what I can set up to autolog (and all the info for each set of data)? I have not fooled with the autoconfig utility in the above post, that might solve this question... Thanks for any advice, and I apologize if this isn't the most up to date OP2 standalone thread, this is the first one I found... |
03-22-2010, 06:54 PM | #14 |
Member#: 184498
OK, a quick update. My logger now logs using the RPM parameter to intiate and stop the log (and actually captures more the 5 points). Using the defogger switch to trigger is a bit sketchy, it doesn't seem to log properly and when I turn the ignition off, it creates another log that has all kinds of garbage readings.
I set the RPM to start logging > 900 and will post some logs (probably start a new thread). After modifying the script to add in some extra parameters, and remove a couple, the defogger switch also does not log properly (I deleted the paramter with a similar paramid, not sure if that is the problem). Will keep tweaking the log...anyone else still actively playing with the standalone feature on the OP2? |
06-03-2010, 09:34 PM | #15 |
Member#: 115844
Vehicle:2018 WRX CWP |
Anybody using this and an LC-1 Wideband? I am finding it impossible to find any information about this. I ordered a 2.5mm male to male connector from ebay because I couldn't find one anywhere else. I just got it today and it won't plug in to the LC-1 female connector. I'd like to stay away from hacking up connectors and stuff.
06-06-2010, 03:50 AM | #16 |
Member#: 233425
did anyone noticed that this standalone logger is much faster than romraider logger? is this because there is no COM speed limit?
06-06-2010, 08:42 PM | #17 | |
Member#: 187021
06-06-2010, 11:42 PM | #18 |
Member#: 196770
I've been using this OP 2.0 stand-alone logging for a while now with my Innovate LC-1 and it has been great! I've had a few hiccups trying to figure out how to log certain things like FLKC, but overall it works very well and logs over 25 samples per second! Not bad.
06-07-2010, 10:57 AM | #19 |
Member#: 233425
working with LC-1 is a problem, my defogger(08STi) turns off itself suddenly is another bothersome problem.
06-07-2010, 11:54 AM | #20 |
Member#: 219676
International
Vehicle:09 Forester XT Steel Silver |
IN romraider, you can log switches such as rad fan. How do you do this via OP2?
Freakin, can you update your app to include this? To ensure you guys get logs working properly, make sure paramname you use wont exceed 512 characters. Currently, there's a bug that will make logger stop or not work at all when this has been exceeded. I just rename my parameters and have it at around 450 total for around 24 parameters. |
06-21-2010, 03:48 PM | #21 |
Member#: 115844
I'm not getting more than 10 samples per second. How are you guys getting more?
06-30-2010, 03:52 PM | #22 |
Member#: 174930
Vehicle:2002 WRX Silver |
Your getting 10 samples per second with the new openport stand-alone logger? how many parameters are you logging? Trying to get a feel for the speed vs. romraider to see if it's worth the cost. I have an '02 as well. Thanks.
06-30-2010, 03:58 PM | #23 |
Member#: 115844
That was with 20 parameters. Looking at my logs I'm not sure it's updating every parameter each .1 second.
10-30-2010, 07:40 PM | #24 |
Member#: 250044
Vehicle:2002 WRX |
Bump from the dead.
Has anyone tried using the AEM UEGO output with this? I've looked and haven't really found any solid directions for connections. My serial out works fine with RR via USB adapter. Any insight would help. |
10-31-2010, 09:16 AM | #25 |
Member#: 110160
Vehicle:2005 STI+JDM V7 Swap WRB |
I used the Innvoate LC-1 and it worked nicely.
Tactrix Openport 2.0 Coming Soon! 07-08+ compatible. | fujiillin | Open Source Reflashes | 388 | 02-21-2009 01:56 AM |
Trying to log with Openport 2.0 and not getting far help please. | Deserted1 | Engine Management & Tuning | 2 | 01-30-2009 03:33 PM |
Romraider Openport 2.0 How to Datalog? & Which Parameters I should Log? | V8 GTFO Lesbic WGN | Open Source Reflashes | 4 | 11-24-2008 11:13 PM |
FS: Tactrix Openport 2.0 $160 shipped | scoobysti05 | Engine/Power/Exhaust | 7 | 10-20-2008 12:30 PM |
Anyone have an OpenPort 2.0 in AZ? | jblackwell | South West Impreza Club Forum -- SWIC | 3 | 10-03-2008 12:20 AM |
