11-13-2020, 11:42 AM | #1 |
Member#: 498822
Vehicle:2006 Impreza WRX Black |
Ver8 05 STi 6Speed - short block compatibility questions
Hi guys,
Been lurking for a while and can't quite put this info together so I wanted to reach out and see if any of you swappers have some info here. I have a 2005 ver8 STI transmission from an ej207 that I am going to mate to my 06 wrx to get rid of the busted 5mt. I have the driveshaft on the way and all the other trans bits I need. Here's my question: I had also planned to get an EJ257 short block with internals so that I could crank up the power a bit at the flywheel and keep my 255 heads since they're still good and can save a little money here. The question is will this combo work (EJ257sb + ver8 ej207 6MT)? Must I get a newer 6MT from a 2.5L STi (6+)? If not, I suppose I can look at the IAG or Crawford EJ255s. Thanks in advance.
11-13-2020, 01:57 PM | #2 |
Member#: 395793
Vehicle:2005 92x Aero Beige |
Yes it will bolt right up. All EJ short blocks will bolt to all EJ based transmissions. The issues are whether you have a push or pull type clutch and if the speedo is in the trans or not.
11-13-2020, 02:00 PM | #3 |
Member#: 498822
Thanks a bunch for the info.
I was aware of the push/pull issues but what about the speedo in the trans? I believe VSS is not an issue here as it didn't switch to the hub units until 2008 i believe? |
