Welcome to the North American Subaru Impreza Owners Club Wednesday August 12, 2020
Old Yesterday, 10:52 AM   #2226
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Dusty
Swapping to spherical bearings will actually add to the wear on other systems in the car because it directly transfers forces. Poly acts like a spring and can bind, so it effectively ups the spring rate of whatever system it's in. It can deflect for sure, but I would bet that going spherical (which reduces overall spring rate) will have the same, if not more tire wear. Wheel bearings go out on those cars on r-comps. Swap to the 5x114 knuckles to solve this. It's not the poly that's hurting those.
I have run sphericals in the rear suspension for years without wallowing out any holes. I recently sphericaled the OEM arms up front but expect the same results of "I need a tad more spring rate".
Like Ham said, there's a lot of common issues in SM, and until you spend some time massaging the inner and outer fenders you'll rub, and even then you'll want more grip so you'll go to a bigger tire, which will rub again, so you'll modify again
Old Yesterday, 06:15 PM   #2227
tsrapophis
Member#: 434904
2002 Impreza WRX
Thanks for the help guys! To be clear, my tires have about 1/2" clearance from the inside edge of the tire to the unibody at the height of the center of the axle, but it is flexing the lateral link bushings enough that I'm rubbing pretty aggressively there. Also, due to budget concerns I'm running a 255/40/17 BFG Rival (yes, 200TW) and having these issues. Can't imagine how it would be with some purple crack of modest size.
5x114.3 knuckle conversion is in the plans, but it will be a big expenditure so for now I'm getting good at pressing wheelbearings. haha.
tsrapophis is offline   Reply With Quote
Old Yesterday, 10:03 PM   #2228
subydude
Member#: 80649
Dusty
I run a 335 on a 18x12 +20 wheel with a 5mm spacer our back and don’t rub on the inner unibody. That’s what’s possible in SM.
Old Yesterday, 11:56 PM   #2229
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Originally Posted by subydude View Post
I run a 335 on a 18x12 +20 wheel with a 5mm spacer our back and donít rub on the inner unibody. Thatís whatís possible in SM.
Yeah! I love the crazy.
Will my trans swap put me automatically in Street Mod? RebelINS Autocross 6 07-22-2013 05:24 PM
I'm still legal for Street Mod right?(list inside) Davenow Motorsports 4 05-24-2003 03:21 AM
street mod tire question Jaxx Motorsports 2 02-20-2003 07:59 PM
Autocross class... Street Mod? Motohead1 South East Region Forum 11 06-26-2001 10:11 AM
Street Mod news Eric Technical Forum Archive 5 05-31-2000 02:33 PM
