07-25-2011, 02:16 PM | #26 |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
There is more going on here than just the way they drive. It's a combination of the clutch and flywheel.
There was an issue similar to this back in '02. OEM clutches were acting exactly the same way. Don't remember the exact cause, although I "heard" it was the wrong clutch disk, but Subaru did a factory recall onthe affected cars. Complete replacement of the clutch, pilot bearing and flywheel and the problem went away.
03-29-2019, 09:21 AM | #27 |
Member#: 473969
Vehicle:2006 WRX World Rally Blue |
I recently installed an ACT 6 puck sprung race clutch and I have extreme chatter trying to slip the clutch from a stop in 1st gear. The whole car shakes violently and sounds like a jackhammer under the hood.
I have always rev matched downshifting, but a time or 2 I didn't and re-engaging the clutch makes the car buck from the harsh engagement. Seems like this extreme chatter is normal for harsh engaging clutches. |
04-01-2019, 08:09 AM | #28 |
Member#: 495329
Vehicle:2014 WRX ISM |
I'm glad this mystery was solved 8 years later, thank you.
12-24-2020, 06:17 PM | #29 |
Member#: 473969
Update:
Just replaced my 6 puck sprung clutch. I was surprised it only lasted 45K miles, but speaking on the phone with one of the friendly techs at ACT, he said I got a lot more miles than most. I bought their Prolight flywheel this time and threw in an OEM clutch. As for the clutch chatter, after several thousand miles, the clutch chatter was less and less, unless I was slipping the clutch on a hill. Then it was very violent. But for those who have never experienced a 6 puck clutch, don't be alarmed that the whole car shakes. They aren't meant to be slipped. |
How bad is clutch chatter with puck clutches? | Need4Boost | Transmission (AT/MT) & Driveline | 8 | 03-29-2019 09:10 AM |
Do I have both clutch chatter and the clutch decel noise? | Kostamojen | Transmission (AT/MT) & Driveline | 9 | 01-26-2003 04:20 AM |
Clutch chatter on ACT clutch? | DoomEquation | Transmission (AT/MT) & Driveline | 0 | 05-30-2002 10:38 PM |
MY98 RS Clutch chatter and engine rattle | Bronco | Normally Aspirated Powertrain | 8 | 05-29-2001 04:46 PM |
