12-26-2020, 10:09 AM | #1 |
Member#: 518804
Throw out bearing question
So I am re-using the stock clutch, pressure plate and flywheel (had it surfaced) on my 2019 STI engine rebuild project as there was only 13k miles on this vehicle when the engine had to be pulled out. The throw out bearing looks a little rusty/rough considering the fact that my buddy whom I got the car from decided to turn it into a sailing vessel (it went through some water which hydro locked the engine and bent/twisted a rod). I figured it would be a good idea to replaced the bearing to avoid any additional complications. My question is does anyone know if an aftermarket ACT release (throw out) bearing will work with the stock pressure plate/clutch? If not does anyone have happen to have the factory revised part number for the OEM bearing?
Any info is greatly appreciated. Thanks! -Rob-
12-26-2020, 11:59 AM | #2 |
Big Ron
Super Moderator Member#: 18062
Vehicle:on car parts so PM me b4 j00 buy |
https://parts.subaru.com/ has the part number, look it up yourself for the right answer.
Protip: Zero aftermarket clutch makers make their own throw out bearings, they use the OEM or equivalent ones. |
