Welcome to the North American Subaru Impreza Owners Club Sunday July 21, 2024
Old 10-18-2012, 03:35 PM   #126
impreza_GC8
Member#: 123295
2001 2.5RS w/ EJ257,
6-speed, Brembos
That was some mild sarcasm on my part. It is useless to most people who have never messed with the older motors. Especially those who jumped on the newer Subaru bandwagon.
impreza_GC8 is offline   Reply With Quote
Old 10-18-2012, 06:04 PM   #127
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Originally Posted by impreza_GC8 View Post
I absolutely love threads like these, I have a soft spot for pre-2002 factory turbo power train useless knowledge. Keep the info flowing, ya'll are my kinda people.
What I'm always floored by is when people have languagefail over the english prefix "PRE" which I as a lay person understand to mean before or prior to.
Yet somehow on regular basis people pop up asking about engines or problems specifically with 02's
At first I thought I was misunderstanding what PRE means
So then I looked it up and apparently pre-2002 still doesn't mean if you have an 02 come here with dumb questions.
1
a (1) : earlier than : prior to : before <Precambrian> <prehistoric> (2) : preparatory or prerequisite to <premedical>
b : in advance : beforehand <precancel> <prepay>
2
: in front of : anterior to <preaxial> <premolar>
TommyAtomic is offline   Reply With Quote
Old 05-30-2014, 02:49 PM   #128
Davidboisvert
Member#: 392229
I got an EJ20G in a 1999 Impreza and am looking for a decent intake tube or even a complete cold air intake setup?
Davidboisvert is offline   Reply With Quote
Old 06-29-2014, 12:12 PM   #129
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
THe apexi intake seems to be the most recommended if you truly have an ej20g and not an ej20k
fxt05 is offline   Reply With Quote
Old 07-31-2014, 05:14 PM   #130
02RS25
Member#: 293773
2003 Impreza 2.5RS
BRP
Does anyone know if i can run 206 intake,ECU,wiring on a 205 longblock? may run a 20G 22 bottom end with forged internals. 206 is non AVCS with DBC. 208 is AVCS with DBW IIRC. with 205 being DBW and non AVCS, could i use those heads with 206 intake and ECU?
02RS25 is offline   Reply With Quote
Old 07-31-2014, 08:35 PM   #131
i_c_the_light
Member#: 88618
206 and 208 are also twin turbo engines. Wiring and ecu are a no go.
i_c_the_light is offline   Reply With Quote
Old 08-02-2014, 02:41 AM   #132
CRX7
Member#: 31639
99 Impreza
Apexi is a short ram and prone to heat soak, I made more power with the stock airbox. However, I do not have the stock intake piping.
Additionally, I had a lot of problems with my MAF getting dirty really fast with the Apexi, no issue with the stock airbox.
CRX7 is offline   Reply With Quote
Old 11-27-2014, 04:24 AM   #133
USLiberty
Member#: 294466
1993 Legacy SS
white
I picked up my 2nd early ej20g(both FCD, liberty rs), have been driving my old one for 12 years and it's still strong. I believe my old one was an 8.0:1 CR(liberty rs auto) and new one is a 8.5:1 CR(liberty rs5spd w/4.11fd) I just needed a 5 speed and found both ej20g/5speed for 1000$,it's really clean. 5speed is already in and now I'm swapping the motors. Ive been running a Link Plus standalone since 2001, ported the xhaust ports all the way to the stock turbo, which is a RHB52 and is slightly larger than a usdm 03wrx td05L. I can almost get historic plates on my car
USLiberty is offline   Reply With Quote
Old 12-26-2014, 03:52 PM   #134
no694terry
Member#: 220816
2018 Exotruck
didnt the liberty (legacy) 20g's have different heads than the impreza 20g's. As far as the hydraulic lifters. Its been something i been researching so i can get 20g heads for a 2.2L. I'd like the heads with the hydraulic buckets, not the seesaw things
no694terry is offline   Reply With Quote
Old 12-26-2014, 04:49 PM   #135
69subaru360
Member#: 159682
1995 WRX
2015 F150
The really early legacy ones had the rocker arms. Like 90-92 or so.
Old 02-28-2024, 09:31 AM   #136
ikaa.
Member#: 537003
I've got a ej20g, turbo inlet is not under manifold, cross hatching where the alternator is got the ribbed rocker covers, single bolt coils, all indicators of a closed deck. I bought the car recently and was told it was a 93 type ra reshelled into a impreza as the prev owner crashed the ra. oil cap says its a 93 too. I'm wondering if the internals are forged and how much power i can get out of the stock bottom end. was planning on getting shimless heads for it not sure on which exactly and possibly a higher flowing manifold. I will be using a standalone ecu like a link or haltech.
ikaa. is offline   Reply With Quote
what is an acessport and what is turbo pressure meter for? lasercombo Newbies & FAQs 43 02-13-2006 10:56 PM
WHAT IS AN ALK???? Frey Bone Newbies & FAQs 9 06-01-2001 05:51 PM
What is an Air Assist Solenoid? KeithRS Normally Aspirated Powertrain 8 05-08-2001 10:22 PM
What is an S-AFC? datpnoy2nv Normally Aspirated Powertrain 5 05-03-2001 03:25 AM
('93-'01) What is an Impreza C-21???? TurboRX Impreza Forum 0 04-12-2001 10:07 AM
