Old 07-07-2020, 08:14 AM   #1
forkandbowl
Member#: 516442
Default 2017 wrx need stock clutch recommendation
I am at about 60k on my 2017 wrx. It is the wife's car and she drives it gently. The stock clutch went out at about 30k and was replaced under warranty. Now the replacement has gone out, out of warranty of course. I will be doing the labor myself since I don't have 2k to drop on this. It is bone stock. I do not want to put another stock clutch in. I have heard that exedy makes the stock one for subaru, and they sell an OEM replacement. So I am guessing I need to avoid that one like the plague. Are there any recommendations you can make on what to go with? Once again it is stock. My wife drives it occasionally in traffic and the stock clutch after a few thousand miles became heavy as crap which wears on you after a bit.
Thanks for any input on this.
forkandbowl is offline   Reply With Quote
Old 07-07-2020, 09:06 AM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Please don't double/cross forum post. You also posted in the Newbie Forum.
Exedy makes very good clutches.
If you have gone through 2 clutches in 60K miles, then you might want to consider either your and/or your wife's driving style.
Sounds like someone is riding the clutch, causing faster than normal wear.
I ran my original OEM Exedy 5MT clutch for close to 150K before I replaced it because I installed a 6MT, and it was still useable.
Old 07-07-2020, 10:01 AM   #3
forkandbowl
Member#: 516442
I was hoping it might be related to the throw out bearing problem, but I'm assuming confused about all of that. My wife has only driven a stick her whole life and got 160k out of her civic si clutch. I've been driving a stick for twenty years also. Not ruling anything out at this point, but it seems like these cars have some persistent clutch issues.
Wasnt trying to double post, just thought I was supposed to say hi in the newbie forum.
Old 07-07-2020, 10:06 AM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Have you asked the Dealer why the clutch was replaced, ie; was there a recall or something?
What was the actual issue that caused the clutch to fail / be replaced?
- Worn out clutch disk?
- Failed clutch pressure plate?
- Something else?
I'm wondering if there is a quality issue for the pressure plate or clutch disk
Old 07-07-2020, 10:59 AM   #5
f22boy
Member#: 464019
2017 Wrx
ISM
30k out of a a stock clutch is insane. My 2017 lasted until 118k when it started to slip, but that was after 2 years of autocross and road course racing sprinkled in. I would say its driver error for sure. You dont have too many options, act is probably your best/most readily available clutch kit. The stage 1 is good for more torque than the rods are so no need to go crazy.
f22boy is offline   Reply With Quote
Old 07-07-2020, 12:41 PM   #6
forkandbowl
Member#: 516442
- Something else?
I just checked the paper work. It was replaced at 26k miles. Said it was worn down past the rivets and had destroyed the flywheel also. It said the throwout bearing was destroyed also. It was all replaced under warranty. My wife drives it 70 miles each day basically and it is almost all highway.
I know the clutch started out heavier than the civic si, and got progressively heavier as it aged, leading to it becoming very heavy then going out. After replacement it was as light as the civic, then became progressively heavier. I know it is a performance car, but the clutch shouldn't be this heavy imo. No mention of a recall or tsb when it was replaced originally. Wasn't there an upgrade to a larger throwout bearing tsb at some point?
Old 07-07-2020, 01:17 PM   #7
forkandbowl
Member#: 516442
Should I just get this and run with it? Any issues converting to a single mass flywheel?
https://shop.exedyusa.com/exedy-oem/exedy-oem-replacement-clutch-kit/fjk1001fw/i-392930.aspx
Old 07-07-2020, 01:24 PM   #8
Samurai Jack
Member#: 21145
2002 Enemy of Aku
If the clutch disk wore down to / below the rivets, then is sounds like the clutch disk was too soft BUT, if the throwout bearing was failing, I could see the other issues.
Having a light feel progressing to a heavy feel isn't right. If anything, it would be the other way around when the springs on the pressure plate wear, so it would go heavy to light.
There is a Service Bulletin on the 2015 - 18 WRX clutches:https://static.nhtsa.gov/odi/tsbs/20...50946-9999.pdf
There is also a Service Bulletin on the Throwout Bearing itself: https://static.nhtsa.gov/odi/tsbs/20...50949-9999.pdf
Sounds like the issue may be directly related to the TSB, as you mentioned.
If it was me, I would still not exclude a new Exedy clutch. I would check into the throwout bearing that comes with the kit to be sure it has the updated version.
Most replacement clutches are heavy-duty types and up.
The only other brand clutch I have used is ACT, which was an HD unit for 525 ft/lbs TQ. I never had an issue.
Old 07-07-2020, 01:50 PM   #9
forkandbowl
Member#: 516442
Thanks for the links. Going to follow up with that. It looks like the parts were replaced after the tsb came out but they didn't replaced the parts with the ones posted in the tsb. Might be able to get them to throw me a bone...
Old 07-10-2020, 12:19 PM   #10
evilWagon
Member#: 128739
Where are you located? There was a total clutch change mid 2018 model going with an increased diameter clutch/flywheel and new pedal assembly to address exactly what you described, from the paperwork I saw it discussed premature wear in hot climates.
In the USA clutch replacement under warranty they note to use the new clutch design (obviously once it was out). When was your clutch replaced?
evilWagon is offline   Reply With Quote
Old 07-10-2020, 03:30 PM   #11
forkandbowl
Member#: 516442
I'm in the southeast us. It was replaced 6 most after the service bulletin came out and they replaced everything with the original factory parts. I called Subaru USA and I'm hoping they will throw me a bone on this, but I have to get it inspected by a dealer first.
