11-13-2013, 02:48 PM | #2501 |
Member#: 360019
Vehicle:2013 Wrx |
Cuz the stock sway bars made it feel like a boat . Even just cruising around a turn.
11-13-2013, 04:09 PM | #2502 |
Member#: 244231
NESIC
Vehicle:2018 Crosstrek CVT DGM |
You could have saved yourself some cash and just bought a stock Impreza if you drive like a grandpa.
11-13-2013, 07:30 PM | #2503 |
Member#: 41730
Vehicle:1415 Legacy/Forester D.Grey/White |
LOL- because you think people post when their warranty takes care of the problem, right? FWIW- I've never had warranty denied, nor has any of my fellow-Suby friends and family.
11-13-2013, 07:49 PM | #2504 |
Member#: 209987
Vehicle:2009 Slow WRX Slower Prius |
All this complaining about warranty denial is bs. I blew an engine, covered by warranty. Blew power steering pump, covered by warranty (at stage 2). Even had rotors replaced under warranty. Be calm with the dealer, and 99% of the time they'll take care of you.
12-14-2013, 06:57 AM | #2505 |
Member#: 354023
Make: 08 WRX Mileage: 74,900 Time Out Of Use: Owned for 8 months. No issues in summer. Problem And Likely Cause: Possibly - smaller o-rings from 2007 model put into 2008 models causing more airflow and causing the car to run lean when cold outside. Modifications: None Submitted For Warranty Work (Yes/No): Yes Reason Given For Denial: No issues found Your Story: Engine shake after cold start under 35 degree weather. Leaving it sit for 15min (without moving it out of the garage or touching the gas pedal) seems to run fine after that. I've had it almost to the point to where it seems like it is going to stall out so, i rev it up a bit so it won't. I let it sit at the Subaru dealer from Friday to Monday and they could not replicate the issue nor find any air leaks or anything like that. I mentioned the o-rings but nothing else was said after that and it might not be covered under warranty? |
12-14-2013, 07:37 AM | #2506 | |
Member#: 287534
12-14-2013, 01:10 PM | #2507 |
Member#: 41730
I'm assuming you have an extended warranty? If so, what's the name of it? Also, where are you coming up with the 07 rings in an 08?
12-14-2013, 11:09 PM | #2508 | |
Member#: 354023
o-rings from this page http://forums.nasioc.com/forums/show....php?t=2299482 |
12-15-2013, 07:42 AM | #2509 |
Member#: 41730
I don't know who backs that warranty but even under the original, I guess if they can't duplicate it , how can they get it approved for repair? Also - check that warranty to see if it covers wear in the engine. A lot don't cover lack of compression, etc.
01-12-2014, 04:16 PM | #2510 |
Member#: 235203
South East
Vehicle:2011 STi Limited DGM |
Removed.
01-13-2014, 09:30 AM | #2511 |
Member#: 229848
Center Diff Problem
Make: 2010 WRX Limited Mileage: 29187 Time Out Of Use: Bought new Problem And Likely Cause: Center Diff Replacement Needed Modifications: Tower Struct Bar, Lower Chassis Brace, AP Stg 1, SPT Exhaust Submitted For Warranty Work (Yes/No): Yes Reason Given For Denial: Being Covered Your Story: Loud clunk felt in front drivetrain when wheel is fully turned. |
01-13-2014, 06:09 PM | #2512 | |
Member#: 41730
01-13-2014, 09:57 PM | #2513 |
Member#: 235203
South East
Removed.
01-14-2014, 06:52 AM | #2514 |
Member#: 41730
Why would you let a guy with a shop who happened by you and your broken car do anything vs getting a tow right to the dealer while under warranty?
01-14-2014, 04:29 PM | #2515 |
Member#: 235203
South East
Removed.
01-15-2014, 01:48 AM | #2516 |
Member#: 331611
Vehicle:2013 Wrx 5dr DGM |
Make: 2013 Impreza WRX Mileage: 4500 miles Time Out Of Use: 2 days Problem And Likely Cause: Tumble Generator Valve stuck closed. Defect in part Modifications: Cobb Cat Back Exhaust (at the time) aftermarket stereo equipment Submitted For Warranty Work (Yes/No): yes Reason Given For Denial: None Your Story: Brought it in to have tpms sensor reset after a blow out. Took almost a week to get the parts in because the guy ordered the wrong part. Ended up replacing the entire Intake Manifold. Was told I could drive around but wont have any boost. After they fixed it it never came back again |
01-20-2014, 11:58 AM | #2517 | |
Member#: 369799
TXIC
Vehicle:2010 997 Turbo Carrera White |
01-28-2014, 12:45 PM | #2518 |
Member#: 37033
Vehicle:11 wrx silver |
Make: 2011 wrx Mileage: 39000 Time Out Of Use: ~10 days Problem And Likely Cause: center differential broke Modifications: none Submitted For Warranty Work (Yes/No): yes Reason Given For Denial: approved Your Story: backing out of driveway, car jumped like I hit something. got out, nothing there. when i got above 20mph in any gear, loud clicking sound that corresponded with road speed. sound got mildly better and worse on the drive to the dealer, where they found broken center differential gear(s) in the transfer case. repaired under powertrain warranty |
01-30-2014, 06:14 PM | #2519 |
Member#: 235203
South East
Removed.
01-30-2014, 06:54 PM | #2520 |
Member#: 41730
Where'd you get the info about what the prev. owner had done? Did you buy it from a dealer or private sale?
01-31-2014, 04:20 PM | #2521 |
Member#: 235203
South East
Removed.
01-31-2014, 04:20 PM | #2522 |
Member#: 235203
South East
Removed.
01-31-2014, 04:38 PM | #2523 |
Member#: 41730
Did you buy it private, from a Subaru dealer or a diff. dealer. Having only had it for 4k miles, I'm wondering if there's help for you with the seller?
01-31-2014, 04:44 PM | #2524 |
Member#: 235203
South East
Removed.
01-31-2014, 04:53 PM | #2525 |
Member#: 322385
Was it a certified pre-owned?
Trouble/Warranty Denial Report Thread: Body/Exterior of Vehicle | North Ursalia | Warranty Issues & SOA Problems | 148 | 04-05-2023 06:27 PM |
Trouble/Warranty Denial Report Thread: Electrical (Lighting, ECU, Sensors, Etc.) | North Ursalia | Warranty Issues & SOA Problems | 143 | 07-23-2020 06:21 AM |
Trouble/Warranty Denial Report Thread: Suspension | North Ursalia | Warranty Issues & SOA Problems | 58 | 10-19-2019 04:03 PM |
Trouble/Warranty Denial Report Thread: Braking System | North Ursalia | Warranty Issues & SOA Problems | 97 | 09-27-2019 12:46 PM |
Trouble/Warranty Denial Report Thread: Interior | North Ursalia | Warranty Issues & SOA Problems | 71 | 11-14-2018 08:18 AM |
