Old 05-15-2021, 04:52 PM   #1
undyjr
Member#: 459692
2019 WRX STI
silica black
Default valve lash
I appreciate everyone taking the time to read this. I had a machine shop that has a Subaru head specialist install Manley valves into my EJ257 heads. I checked the valve lash after the heads had been torqued to my stage 2 IAG short block and all were right at the tightest tolerance and just below. As I recall most of them were right at max tightness. Whether or not it was the right decision I sent it.
Fast forward 1100 miles to my pre-dyno inspection and I failed the leak down and the compression (mainly due to a cylinder imbalance) I'd like to add that although I was on a break in map the car ran great. I even snuck in some waste gate pressure boost with no knock. Here are the numbers:
Compression
#1 141psi
#2 157psi
#3 150psi
#4 146psi
Leakdown (hot)
#1 14%
#2 8%
#3 13%
#4 15%
Leakdown (cold)
#1 12%
#2 9%
#3 11%
#4 14%
I pulled the valve covers and checked the valve lash on a cold motor.
According to the FSM the tolerances are:
Intake .20mm +/- .01 Exhaust .35mm +/- .02
Cylinder #1 Intake .15 and .15 Exhaust .30 and .30
#2 .15 and .13 .30 and .28
#3 .20 and .20 .30 and .33
#4 .18 and .16 .30 and .30
Here are my questions. Do these lash measurements require new buckets? Do they explain the leakdown results? I'm confident I'll be able to change buckets with the motor in the car. Why did the lash change so much between assembly and now? I'm expecting responses to range from "send it" to "pull the motor and send the heads back to the machine shop". Ultimately I'll have to decide what to do. I can say there are a select few that I highly respect and I look forward to their input. Thanks again for reading.
undyjr is offline   Reply With Quote
Old 05-15-2021, 07:30 PM   #2
junebugfareast
Member#: 167468
2004 STI
White-ish
The leakdown test might allow you to understand where the air was being lost to. Either out the intake manifold/inlet, block/oil filler cap, or exhaust manifold.
However, those stated lash clearances will not impact a cold leakdown test. Bets are off on a warm motor. Losing that much lash in 1000 miles is suspicious. Valves or cam lobes are wearing? Valve seats being driven into the head? Spring binding?
If you want the lash to be at spec, you will have to buy buckets or possibly exchange at least some of them between valves to get the desired clearances. Life is like a box of chocolates on the buckets you have - you never know what you will find until you remove them and turn them over.
Whoa on changing the buckets in the car. Consider that there is very little clearance between the frame rail and the cylinder heads. The cams must be removed to change buckets. I've never done it in the car, but I suppose some have. Just a lot of work.
I suspect you have some sealing issues on the rings. However IAG states something like 3000 miles until the engine is as tight as it is going to get. I can't comment whether that is more a marketing number or an experience based number.
I wouldn't pull the motor until you had a better idea what is going on it.
I don't know if you intend to make a warranty claim at IAG. I guess asking them first what they will want to have done before you ship the block would be a good place to start.
junebugfareast is offline   Reply With Quote
Old 05-16-2021, 11:43 AM   #3
undyjr
Member#: 459692
2019 WRX STI
silica black
Update:
I decided to do my own compression and leakdown test. The tests were performed on a 71 degree engine. Cylinder to cylinder variance was my primary concern during the compression test and as far as the leakdown numbers I will defer to more experienced members for input.
Compression test:
#1 115#s
#2 121#s
#3 115#s
#4 119#s
Leakdown test at 80psi :all were between 10 and 11%
At this point I'm inclined to put another 500-1000 miles on the motor and perform the tests again.
