Brakes & Suspension Forum sponsored by The Tire Rack |
05-19-2022, 02:06 AM | #1 |
Member#: 464372
2020 WRX Perrin sway bar and endlinks clunking noises
Hey guys
I fixed this issues last week when I followed all the torque specs on sway bar, endlinks and lower control members here were recommending for aftermarket parts . I have a 24mm Perrin sway bar on hard setting and Perrin endlinks. Car drive perfect not one single noise for a week and yesterday I had the car lifted up to install splash guards and after that I started hearing some clunking noises again in any body twist motion. It's not as bad as before but I'm wondering if there is a fix to this? Thanks for reading
05-19-2022, 02:28 AM | #2 |
Member#: 530093
https://forums.nasioc.com/forums/register.php?do=register
Sunresin is an innovation oriented high-tech enterprise, specialized in supplying Ion exchange resins***12304;https://forums.nasioc.com/forums/reg...ister***12305;, adsorption & separation resins, equipment solutions and relevant technical services. With almost 20 years of manufacturing experience, it is the listed company in the IER industry (Shenzhen Stock code 300487) which provides a high level of transparency to its customers. Sunresin manufactures about 50,000M³ of ion exchange resins and adsorbers annually, supplying furthermore customers with tens of adsorption and separation equipment. Sunresin's resin portfolio include about 25 product categories and more than 200 different resin types which are broadly used in industries such as: Water and Waste water treatment, Food Processing, Biotech, Pharmaceuticals, Plant Extraction, Membrane Caustic Soda, Hydrometallurgy, as well as Municipal Water Treatment among others.
05-19-2022, 02:30 AM | #3 |
Member#: 530093
https://www.seplite.com/Ion-Exchange-Resins.html
Sunresin is an innovation oriented high-tech enterprise, specialized in supplying Ion exchange resins***12304;https://www.seplite.com/Ion-Exchange....html***12305;, adsorption & separation resins, equipment solutions and relevant technical services. With almost 20 years of manufacturing experience, it is the listed company in the IER industry (Shenzhen Stock code 300487) which provides a high level of transparency to its customers. Sunresin manufactures about 50,000M³ of ion exchange resins and adsorbers annually, supplying furthermore customers with tens of adsorption and separation equipment. Sunresin's resin portfolio include about 25 product categories and more than 200 different resin types which are broadly used in industries such as: Water and Waste water treatment, Food Processing, Biotech, Pharmaceuticals, Plant Extraction, Membrane Caustic Soda, Hydrometallurgy, as well as Municipal Water Treatment among others.
05-19-2022, 02:36 AM | #4 |
Member#: 530093
Sunresin is an innovation oriented high-tech enterprise, specialized in supplying Ion exchange resinshttps://www.seplite.com/Ion-Exchange-Resins.html, adsorption & separation resins, equipment solutions and relevant technical services. With almost 20 years of manufacturing experience, it is the listed company in the IER industry (Shenzhen Stock code 300487) which provides a high level of transparency to its customers. Sunresin manufactures about 50,000M³ of ion exchange resins and adsorbers annually, supplying furthermore customers with tens of adsorption and separation equipment. Sunresin's resin portfolio include about 25 product categories and more than 200 different resin types which are broadly used in industries such as: Water and Waste water treatment, Food Processing, Biotech, Pharmaceuticals, Plant Extraction, Membrane Caustic Soda, Hydrometallurgy, as well as Municipal Water Treatment among others.
05-19-2022, 02:37 AM | #5 |
Member#: 530093
05-19-2022, 02:38 AM | #6 |
Member#: 530093
05-19-2022, 03:40 AM | #7 |
Member#: 530093
Sunresin is an innovation oriented high-tech enterprise, specialized in supplying Ion exchange resins< a href="https://www.seplite.com/Ion-Exchange-Resins.html">, adsorption & separation resins, equipment solutions and relevant technical services. With almost 20 years of manufacturing experience, it is the listed company in the IER industry (Shenzhen Stock code 300487) which provides a high level of transparency to its customers. Sunresin manufactures about 50,000M³ of ion exchange resins and adsorbers annually, supplying furthermore customers with tens of adsorption and separation equipment. Sunresin's resin portfolio include about 25 product categories and more than 200 different resin types which are broadly used in industries such as: Water and Waste water treatment, Food Processing, Biotech, Pharmaceuticals, Plant Extraction, Membrane Caustic Soda, Hydrometallurgy, as well as Municipal Water Treatment among others.
05-19-2022, 04:04 AM | #8 |
Member#: 530093
<a target="_blank" href=" https://www.seplite.com/Ion-Exchange-Resins.html ">
05-19-2022, 10:49 AM | #9 | |
Member#: 107618
Vehicle:06 GG WRX / 09 FXT @florencedestinedfxt |
I would get it up on ramps and re-torque everything. Then, if you have the time and patience, I would start with the endlink-to-rear lower control arms connections and tighten another 3-5 ft-lbs to see if it helps make a difference. If it still clunks then try the endlink-to-swaybar for another 3-5 ft-lbs over spec. |
05-19-2022, 10:50 AM | #10 | ||
Member#: 107618
05-20-2022, 01:05 AM | #11 | |
Member#: 464372
06-02-2022, 05:00 PM | #12 |
Member#: 464372
Seems like the noise just went away on its own. Just drove the car around for few days.
06-14-2022, 01:20 PM | #13 |
Member#: 530394
With mine the noise went away after a few weeks. If yours continues, I would check the grease on the bushings and see if that helps.
