06-16-2022, 01:53 PM | #1 |
Member#: 499185
6 cylinders on wrx/sti ecu
I've heard people say you can swap a h6 motor like eg33 and use the oem wrx/sti ecu. Instead of piggy backing the svx ecu or a standalone. I'm talking about the GD 06 07. How do you trick the ecu into firing the other cylinders? Is this a real thing? Because then you could retain the OBD2 and drive by wire. I would like someone with experience to confirm this and then explain how. Thanks
06-16-2022, 02:05 PM | #2 |
Member#: 179775
South East
Vehicle:03 WRX/15 FXT 14 BRZ/ 92 SVX |
Try the 'Six Swapped Subarus' group on Facebook, probably get much more info there.
06-16-2022, 02:33 PM | #3 |
Member#: 515308
I’d be amazed. If it was batch injection and single water coil maybe.
