Brakes & Suspension Forum sponsored by The Tire Rack |
06-26-2021, 08:44 PM | #651 |
Member#: 511126
BAIC
Vehicle:2003 Impreza Outback silver and gold |
I would say get the tires and have the outer CV joints checked for binding while the wheels are off. I know there have been reports of vibration coming from worn or aftermarket axles/CVs. The angles are going to be higher in the front, that's where I would focus on since you have rear spacers. How much lift did you get in the front?
07-04-2021, 08:00 PM | #652 |
Member#: 443213
Vehicle:2005 Saab 9-2x |
I've lifted my 05 Saabaru with Forester struts and have been having what I think is axle binding issues only with the front driver axle. The car also has sedan front control arms with factory sedan axles, rear trailing arm brackets, and running 205/70/15 tires. I've tried multiple axles with the same results always on the driver side mostly from a stop, with the binding mostly going away as everything warms up.
I'm at a loss for what to do. If I did the Forester subframe spacers with the steering knuckle do I have to use all of the other drivetrain parts from a Forester? Or even could I slightly space the subframe with one or two washers? |
08-01-2021, 07:28 PM | #653 |
Member#: 511126
BAIC
03 OBS lift
So here's my lift setup, just completed:
Front: Koni inserts, WRX springs, WL end links Interestingly, it's a palm width from the wheel arch to the top of the tire, no lift Rear: Subtle Solutions 1" aluminum spacers with 3/8 spacers stacked, '99 Outback wagon trailing arm brackets. Non-lift upgrades: WL end links, 22mm sway bar and brackets. I was able to bolt up the links on the middle setting without any problems. Big thanks to the OP, I was able to do this on the cheap because of the info posted. I still have the front 1" spacers and two additional sets of 3/8" poly spacers, I'm not sure if I will run these yet. I may run the STi springs on the front and see how it sits before I add spacers. This is a pretty good compromise for a street setup: it's a little wallowy in the back but it hooks up great thanks to the progressive rate STis in the back. I think I will add the last 3/8" poly spacer in the back because it's just shy of a palm width in the back. Edit: I put the last spacer (1/4", not 3/8) in, it's a perfect square on the lift right now, 2 1/2" from top of the tire to the wheel arch all the way round! I will post pics later... Last edited by Zabnorg; 08-06-2021 at 11:22 AM. |
06-08-2022, 11:47 PM | #654 |
Member#: 530314
Hi folks!
Trying to help a friend with their '13 Impreza Sport Limited lift. Standard story applies - rides too low and rough. They were looking to buy a Crosstrek. I'm selling them on upgrading the suspension instead. Part 2 involves upgrading the tires on their 17" wheels. The mighty internet has pointed me towards '09-'13 Forester struts and a Subtle Solutions rear alignment kit. This is probably the way we'll go... Remaining questions are:
12-03-2023, 10:23 PM | #655 | |
Member#: 536271
12-03-2023, 10:29 PM | #656 | |
Member#: 536271
Similar Threads | ||||
The Official "How old are you?" thread | wrxpeed | Off-Topic | 53 | 07-03-2019 11:11 AM |
The "How to spend your 4-day weekend w/o your girlfriend" thread | MK19_ | Off-Topic | 44 | 04-16-2007 01:18 PM |
The official "How much of your bumper did you have to cut for your FMIC" thread. | lawn boy | Interior & Exterior Modification | 0 | 04-17-2005 11:56 AM |
The The Unofficial What front lip is that? Thread. post and tell.... | mmmprza | Member's Car Gallery | 3 | 04-11-2004 02:14 AM |
re-reading "how to make your car handle" last night | jmott | Texas Impreza Club Forum -- TXIC | 18 | 08-18-2002 06:02 PM |
