Welcome to the North American Subaru Impreza Owners Club Wednesday August 5, 2020
Old 07-11-2020, 02:28 AM   #1
ians19832
Member#: 516619
Default Scoobie noobie with a call for help... 2011 impreza 1.5
Hi everyone. Need help.. Please.
Recently bought a 2011 impreza with a 1.5 litre engine and with 78000 kilometers on it.
Car runs great, except for LTFT around 9 to 10, 15 ignition timing and worst part is I get around 10mpg / 5.5 kmpl. A full tank of fuel only gets around 300 kilometers. LTFT at idle is close to 10 and goes down to about 7 when AC is turned on. When driving, LTFT is around 2 to 4, goes to 0 when accelerated to around 2000rpm at idle.
Checked for codes, none found except for an old ABS code which was cleared subsequently. Checked for vacuum leaks, (found none) smoke tested it too. checked and clean EGR valve, cleaned MAF Sensor, (which reads around 2.2 to 2.5 at idle with ac off, around 3 with ac on. Rpm at idle is smooth and around 650 with ac off and around 850 with ac turned on. Fuel flow shows around 0.8 liters per hour with ac off at idle and around 1.7 liters per hour with ac on. Reset ecu (removed negative terminal and left off for about an hour, 10 mins run, switch off, run 5 mins, switch off, etc) lambda sensor shows value of 1.0 at idle and voltage of around 2.2
Please help guys.. At wits end and have no clue what's going on.
There is a slight hesitation off the line when accelerating but starts pulling hard around 2000 to 3000 Rpm. Strong exhaust smell, not necessarily a fuel smell but a stinging kind of smell.
Any ideas anyone?
Any advice would be very helpful and very highly appreciated.
Thanks in advance
ians19832 is offline   Reply With Quote
Old 07-11-2020, 04:01 PM   #2
ckata22
Member#: 479071
2005 Impreza
I had high LTFT on an 06 forester and it turned out to be the O2 sensors, fwiw
ckata22 is offline   Reply With Quote
Old 07-12-2020, 04:17 AM   #3
ians19832
Member#: 516619
Default Update:
After cleaning the EGR, now the lean condition is permanent at around +9 LTFT. Doesn’t go down under throttle. 🙁 goes down to around +4 at load when driving. EGR valve gasket was replaced after cleaning and also added some high temp RTV sealant just to be sure. Please anyone, any ideas?
No error codes, scanned at a garage with a proper scanner as well. Thanks…
