07-05-2021, 04:57 AM | #1 |
Member#: 506873
Vehicle:2001 WRX Sedona Pearl Red |
Should I buy this STI??
Hey guys
Looking at buying an STI from a dealer a nice 2001 STI exactly what I am after as the EJ207 come forged from factory and the gearbox obviously . However been in contact with the dealer and he says it is getting a worn synchro repaired. Is that a red flag? I know that the STI gearboxes are stupid strong and can easily handle 600hp so to hear them having issues makes me think it has had the living daylights thrashed out of it and that the entire gearbox might go boom. I'd hate to buy an STI only for it to have an expensive gearbox replacement. So should I avoid this vehicle? Any checks I could get done professionally without having them rip apart the box or if I decide to buy it just have to have faith in the box?
07-06-2021, 08:15 AM | #2 |
Big Ron
Super Moderator Member#: 18062
STI gearboxes are not stupid strong and they cannot easily handle 600HP. When you go online and read about how Carl and Tim are running 600HP, you cannot take those two data points and draw a trend line to the moon. That's not how logic or data analytics works. The 6MT is stronger than the 5MT. Yes. The 6MT can and does break, so don't think you have a "racing transmission".
Synchros fail. You take apart the case, you remove the gearset, you reinstall new synchros, you reassemble, then you smoke cigarettes. I literally did this last summer on my gearbox for no good reason. All my synchros were perfectly fine and they went into the trash and were replaced for new ones. Synchro failure does not mean the transmission is "bad". You, as an end user, can do nothing to figure out if a transmission will fail. You or a mechanic can tell if there are clutch issues, synchro issues or differential issues. Failure is not something you can predict as gearbox failures come from shockload which is a formula of power*applications of power*severity of application=gearbox asspload. You should have a pre-purchase inspection to include a compression check prior to purchasing ANY used vehicle. Mechanics love these as they are a refreshing break and they can give you general and specific advice on whether to or not to buy the car. |
07-06-2021, 08:48 AM | #3 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
Everything Ron just said is 100% correct.
In addition, remember that this is an ancient car. Rubber bushings, boots, hoses, vacuum lines, brake hoses will very likely need replacement at this point. Your pre-purchase inspection can pay particular attention to these. Very few owners replace suspension bushings, ever. Look over Youtube videos on how to remove and install all of these bushings. While you're in there, look for string alignment videos. If you're willing to do some work, this can be done for a small price with lots of your own sweat equity. If you have to pay someone to do all of this, you'd better have found a one of 3 rare cars owned by Elton John as it's a crap ton of time to properly do this. The alternative (which I will admit I do) is to skip over this-old-car and buy something new. And to be redundant, absolutely get a pre-purchase inspection. |
07-06-2021, 03:12 PM | #4 |
Member#: 428511
Vehicle:2016 STI |
you're concerned about a worn synchro and you didn't even state the mileage?
I mean, a synchro is a wear part, meant to be consumed to do it's job, so if there's decent mileage on this thing that is to be expected. |
07-07-2021, 12:06 PM | #5 |
Member#: 125887
NWIC
Vehicle:2001 EJ207 V7 RSTi, Mica Blue |
+1 for Unabomber, but not only that I'm a hands on person I rarely ever buy a car sight unseen
07-08-2021, 10:02 AM | #6 |
Member#: 525409
be aware my friend, this car is really old...
07-08-2021, 10:37 AM | #7 |
Member#: 131304
Vehicle:20 WRX PB Blue 19 Mustang Vert - GG |
Be wary of anything used. I had posted my horror story a few months ago regarding a used WRX I bought from a dealer. Be warned, even no glaring issues on a used performance car is a giant red flag.
07-08-2021, 11:10 AM | #8 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
also forged means maybe a little stronger but it also means it wears faster... you are dealing with a 2 0 year old car... my rule of thumb is keep at a minimum of 5000 USD on the side for incidentals
07-14-2021, 11:51 AM | #9 |
Member#: 208672
TXIC
Vehicle:2013 WRX STI Limited Obsidian Black |
Avoid
07-14-2021, 09:02 PM | #10 |
Member#: 507011
Better to decide if you can get it cheap and you have the resources to keep her in good condition.
07-25-2021, 10:05 AM | #11 |
Member#: 525722
Add me to the avoid camp. There are so many good used WRXs out there.
