08-19-2013, 07:55 AM | #126 |
Vendor Sales Rating: (43)
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
PM us if you want your pan powder coated. Typically only used with show cars and track cars trying to bend the rules It costs $35 and adds 4-5 days to the order.
There is no benefit to powder coating except the appearance.
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. vs. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
10-07-2013, 09:22 AM | #127 |
Member#: 198281
No wait on these, many in stock
__________________
11-11-2013, 09:15 AM | #128 |
Member#: 198281
Welding High Performance Suby pans...
__________________
12-02-2013, 09:28 AM | #129 |
Member#: 198281
Happy Cyber Monday!
__________________
12-09-2013, 09:33 AM | #130 |
Member#: 198281
In Stock!
__________________
12-26-2013, 08:52 AM | #131 |
Member#: 198281
Thanks for the X-Mas orders!!
__________________
02-10-2014, 09:32 AM | #132 |
Member#: 198281
Almost in stock
__________________
05-09-2014, 04:34 PM | #134 |
Member#: 198281
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. vs. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by KillerBMotorsport; 05-09-2014 at 04:57 PM. |
05-22-2016, 03:15 PM | #135 |
Member Sales Rating: (1)
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
I bought one of these a while back, and now I'm getting ready to put in the oil temperature sender. How clean/dry do the threads need to be when I put the 1/2 NPT adapter back in?
I mean, are we talking "remove pan, degrease, brake cleaner..." or is it enough to wipe the threads with a paper towel after draining the oil? Thanks! EDIT: I have Teflon tape and will be using it unless there's some reason not to. |
05-22-2016, 03:42 PM | #136 | |
Member#: 198281
__________________
05-04-2017, 01:39 PM | #138 |
Member#: 198281
__________________
11-07-2017, 07:37 PM | #139 |
Member#: 198281
So the cast pan has been up and rolling for a while now. The feedback has been great, which has been good to hear.
We are still going to be taking order for the fabricated oil pans, but they are made to order only. Let me know if you have any questions
__________________
06-03-2021, 08:35 AM | #140 |
Member#: 198281
To all of you who have purchased our new Super G Pan and High Flow Pickup.
We are interested in your feedback and data. We would love to get some plots that include telemetry, oil pressure, oil temperature, and crankcase pressure. We have sold a lot of these pans and our customers have been generous with feedback, but more is always better.
Learn More
__________________
06-08-2021, 05:00 PM | #141 |
Member#: 198281
Have questions? Get answers
Fun fact, we use a proprietary casting process that allows thinner walls with no draft required. A benefit of using this process technology is that it allows pan geometry that can hold more oil. More oil means more 'residence time' (the time oil spends in the sump before it gets sucked back into the engine). Any increase is residence time will decrease aeration. Improved oil residence time has been shown to de-aerate oil better than 'de-aeration baffles'. Improvements in de-aeration increase oil pressure, reduce heat, and improve overall lubrication system function.
__________________
Lightly used Killer B Performance Oil Pan and New Pickup $450 | KillerBMotorsport | Engine/Power/Exhaust | 3 | 10-27-2010 08:23 AM |
FS apexi turbo timer , blue injectors , TMIC , oil pan , fuel pump more MAKE OFFER!! | calweezy | SCIC Private Classifieds | 27 | 10-10-2009 04:30 PM |
FS-Cosworth Hi/Capacity Oil Pan Kit, Cos. Rod/Main Bearings, BC Valves/Spring/Ret | blackacres | Engine/Power/Exhaust | 22 | 02-14-2009 03:16 AM |
High Capacity Oil pan for EJ25? | Ultimate Racing | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 09-03-2006 12:06 AM |
Is version 5 oil pan same as US WRX pan ? | zaidallas | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 08-27-2002 02:58 PM |
