Brakes & Suspension Forum sponsored by The Tire Rack |
08-24-2022, 10:29 AM | #1 |
Member#: 114371
Order of Operations to change subframe + crossmember
Hey guys,
I've got 05 impreza RS 2.5 auto that has some rust issues. I'm going to swap in a clean crossmember/subframe. Does anyone know the sequence of parts removal that I need to follow? Just a high level list would be helpful. I'm working on the ground if that matters. Thanks
08-24-2022, 07:17 PM | #2 |
Member#: 107618
Vehicle:06 GG WRX / 09 FXT @florencedestinedfxt |
Front or rear, best to reference the service manual that's readily available on the internet.
08-24-2022, 07:57 PM | #3 |
Member#: 114371
Front.
08-25-2022, 08:55 AM | #4 |
Member#: 107618
U subframe, center jackplate, control arms, swaybar, steering rack, loosen pitch stop, slightly lift the engine so it's weight is off the subframe and then remove subframe. Pretty much anything mounted to the underside of the subframe. Be careful loosening the 4 bolts so you don't break the welds of the nuts inside the chassis.
08-25-2022, 09:55 AM | #5 |
Member#: 114371
Thanks, I appreciate it.
Only thing I'm not clear on is the first item....what is the "U subframe". |
08-25-2022, 10:15 AM | #6 |
Member#: 193940
Vehicle:2004 WRX STI Black RalliSpec Shortblock |
This is a U Subfram |
08-25-2022, 12:19 PM | #7 |
Member#: 114371
Awesome. Thanks so much. This was exactly what I was looking for.
