04-09-2021, 07:22 PM | #1 |
Member#: 519868
Vehicle:2010 Impreza WRX Satin White Pearl |
Anyone Install a Cobb Turbo Inlet Recently?
Looking to upgrade my 2010 WRX stock unit because I suspect it’s leaking. Anyone install the Cobb turbo inlet recently? According to them it’s been updated so no more trimming required.
Another thing I noticed is the PCV hose port (nearest turbo) faces up on the stock hose as well as the Perrin, but not the Cobb. It faces the engine. Initially liked this idea because easier to access in future but there must be some technical reason Subaru put it on top right? Some physics behind how air/fluid flow through it?
04-11-2021, 04:21 PM | #2 |
Member#: 50072
South East
Vehicle:2017 STI Blue |
I had the pleasure of fighting with the Cobb v1 inlet and then going to a Perrin inlet. Since the v2 no longer requires trimming, that's a major issue that is supposedly resolved, but those inlets are still bulky. As you've noticed, the Perrin is more of a direct OEM replacement because the connections are similar to the OEM inlet. If you want an easier install, go with the Perrin. My Perrin fit super easy, was very easy to clamp to the turbo, and has stayed clamped to the turbo for ~10 months. I think that, because the Cobb inlet is so bulky, it would shift when tightening the intake manifold during installation and bind up at the TGV and it just wouldn't stay securely clamped to the turbo, so I had a post-MAF leak. With the Cobb, power during pulls felt inconsistent until I switched to the Perrin, that's why I'm convinced that I had a post-MAF leak.
I hate to whine, but Cobb must have received enough complaints to convince them to revise the inlet and I'm mad that I wasted $200 on that. Do yourself a favor and buy the Perrin. |
04-11-2021, 04:38 PM | #3 | |
Member#: 519868
Sucks to hear of your issues. Not whining, it’s a poorly designed product. The fact the V1 needed trimming is ridiculous. Doesn’t give much confidence they “remedied” this in the V2. It’s already a PITA install to have a leak on top of that afterwards. I don’t know if it’d be worth contacting them to see what they might say. Yes I like the Perrin for keeping all the factory locations. I don’t know why Cobb moves the crankcase breather hose not only to the side, but all the way to the front. Also, only realized today after finally going on Perrin’s site and seeing the correct product image. You’re right, it’s basically a silicone version of the factory tube. It’s not as big as I thought. It’s a 2.4”. Should be much easier to install given the limited amount of space. Hopefully this will not be too bad an install, and also solve a Feedback Knock issue I’ve been chasing since December. Thanks again for your input |
04-11-2021, 04:44 PM | #4 |
Member#: 492422
Vehicle:2011 STI |
I was going to go with the Cobb piece myself a couple a months ago but herd so many complaints about it. I ended up with the perrin piece and its been great. Install was straight forward and fitment was exactly as described. Id recommend going with the Perrin inlet.
04-11-2021, 05:07 PM | #5 | |
Member#: 519868
04-12-2021, 12:43 AM | #6 |
Member#: 522840
I did an AVO hose, and it was a pain in the butt.
If I had to do it again I would go Perrin in hopes that would be easier. Literally took all day to get the fitment right, and im fairly handy mechanically. I did not have to take off the intake manifold but probably shouldve. Afterwards I had to buy another avo hose to go from the factory airbox to the inlet because the stock one wouldnt fit. I had to trim that AVO hose and even so its kinda kinked in there. I didnt want to trim the inlet on the airbox side, while it was already mounted, and I wasnt going to take it out again. I wasnt aware they needed to be trimmed anyways, and I dont think trimming it on the turbo side would have helped regardless. |
04-12-2021, 01:14 AM | #7 | |
Member#: 519868
I keep seeing Perrin mentioned as easy to install. Based on the experiences shared here I’m confident that’ll be the case. Surprised to hear another hose that requires trimming. What kind of designs are these |
04-12-2021, 01:44 AM | #8 |
Member#: 522840
ya i had no idea they needed to be trimmed at all until after i had it in, and i couldnt put my factory airbox back.
i dont think there was anything about that in the instructions either. figured im paying $200-ish for a hose. the material is not expensive, so a chunk of that change should be in R&D. if i paid $50 i wouldnt complain about it not being a direct fitment :P haha. |
04-12-2021, 02:07 AM | #9 |
Member#: 519868
Haha my thoughts exactly. If a piece of silicone costs that much it better fit like a glove. Even for $50 I think I’d complain
