12-28-2011, 01:00 PM | #101 |
Member#: 26368
South East
Vehicle:2001 2.5RS-N BRP |
Got a bunch of new and near new parts for a Honda 450R and a Suzuki LTZ400. It was for a friends RC51 powered go cart that never came to be. It's being stored at my house and I would like to get rid of it. Lot's of parts from Durablue, Galfer, and some stock parts.
Durablue Anti roll sway bar (new) - $300obo fits Honda 450R 2006-2011 p/n- 56-2382 Durablue X-33 Eliminator rear axle (new)- $600obo fits LTZ-400 2003-2008 p/n DB20-2137EX Durablue sprocket hub (new)- $125obo LTZ-400 2003-2008 p/n-56-2596 Galfer Wave rotors (2) front (new)- $125obo TRX450R p/n 17-3712 Galfer Wave rotor (1) rear (new)- $125obo LTZ-400 p/n-17-3731 Galfer brake pads front(2 pair) (new)- $30obo TRX450R p/n-17-164H Rad Manufacturing Dual Row bearing carrier (new) - $250obo LTZ-400 Honda 450R front shocks (used) - $200obo Honda TRX450R front spindles (used) $75obo Honda TRX450R front calipers (used) - $50obo
12-28-2011, 01:18 PM | #102 |
Member#: 50002
W. Canada
Vehicle:2013 red Raptor |
This isn't mine personally, but I use it from time to time.
No we don't run with the giant flag all the time.. this was Canada Day celebrations and the public/official introduction of the ATV/UTV. Polaris Ranger 6x6 - can shift from 6WD to 4WD (rear wheels) to 1WD (only one rear wheel propelled, for travel on turf or pavement). We've added radios, lights & siren, windshield, and department markings. We use it for backcountry rescues (up mountain trails, etc) and off-road firefighting, with a skid unit that goes in the back with a couple dozen gallons of water, a little 10-ish HP pump, and some fire hose - along with a place to put a Stokes rescue basket. |
12-30-2011, 08:50 AM | #103 |
Member#: 74041
Vehicle:2006 2012 Weee-strom 14 Hyundai Borenata |
I swear I'm 95% done asking questions about this damned axle
I have the bearing and dust seals installed. Gooped all to hell inside the carrier, put about 1lb. of extra grease between the carrier and the spacer bearing, greased every surface that didn't have grease as well. Slapped all together, rotated the axle and it seems like it is fine. Butter smooth if not a bit stiff feeling, which i attribute to it being 32 degrees outside. All I have to do is tighten up the axle nuts. Do I want them against the sprocket carrier tight or should there be a little play? I read having them too tight will wreck the bearings. |
12-31-2011, 09:45 AM | #104 |
Member#: 74041
God I hope the bearings don't roll out of it when we get the thing back together and running. Pics of the Warrior being pulled from the barn for the first time in years to follow. |
12-31-2011, 10:31 AM | #105 |
Member#: 176940
TXIC
Vehicle:2004 FXT, 06 wrx |
I ride my buddies raptor 700 every once and a while and that's just a little too much. I want a 4x4 nothing crazy just something to go thru some trails.
12-31-2011, 08:53 PM | #106 |
Member#: 74041
I do have a video as well but it ist showing up on the iPhone app or accessing via safari. I'm impressed it even ran after sitting that log, we just put some gas in it, rigged up a battery since the one on it is dead, and that bastard started up in 20 turns! Needs a carb cleaning bad but it runs. |
01-03-2012, 12:31 PM | #107 |
Member#: 74041
Victory is mine!
Ordered a bunch of new parts to get it going. New brakes, battery, oil, oil filter, front wheel bearings chain rollers and some odds and ends. I'd like to see this puppy be rideable by the weekends but depends on whether or not the shipping gods shine on me. EDIT: Or not? Video not working with Nasioc? |
01-03-2012, 05:53 PM | #108 |
Member#: 73937
Vehicle:2008 Jeep Patriot beater silver |
My friend is moving to NC and gave me his ATV, a old yamaha 250 that doesnt run and has sat ouside uncovered for the past 4-5 years.. At least I got another project/junk...
01-03-2012, 07:28 PM | #109 |
Member#: 74041
01-08-2012, 11:37 AM | #110 |
Member#: 74041
Woot! Got to ride the Warrior yesterday. Needs a carb cleaning and a clutch as well as clutch cable, but it was nice to tear around on it. It runs like a champ WOT but the idle jet is gunked up as it won't idle and it backfires if you back off the gas at all.
I had forgotten how SHORT the gears were setup on Warrior. The first 3 gears almost feel exactly the same! I think I might mess with the sprockets to get a little more out of each gear when it is up, but besides the chain, it looks like both the front and rear are in like-new condition. |
01-08-2012, 04:05 PM | #111 |
Member#: 34682
Vehicle:2013 Jetta TDi Black |
So I got a 2003 Polaris Predator 500 yesterday for 1700 bucks. Has HMF pipe(slipon), jet kit, K&N filter, and a rev limiter device of some sort?. Seems to have low hours (is there a way to check???) and is really clean. Tires are almost new up front and 3/4 in the rear.
Needs some small body work that epoxy should easily take care of Any things to look out for? This is my first quad. I know I want some nerf bars and something that extends the foot controls would be awesome. Also are there aftermarket fender extenders or atleast a way to limit the amount of mud this thing throws up??? I got covered yesterday. Pics: Last edited by djt81185; 01-08-2012 at 05:00 PM. |
05-25-2012, 11:32 AM | #112 | |
Member#: 92634
RMIC
carted around in the bed of something like this (cheap ol' 2WD, V6 long bed model would do): to ride these trails: |
05-25-2012, 11:54 AM | #113 | |
Member#: 74041
04-21-2021, 12:07 AM | #114 |
Member#: 107150
TXIC
Headed out to Arizona on Sunday to check out three 1989 Honda pilots; two appear to be in pristine condition that have been garaged their entire life and the third is a parts Pilot. I've wanted one of these ever since I was a little kid. Hopefully I don't jinx myself by posting here. If all goes well they'll be home before mid-May.
04-21-2021, 12:29 AM | #115 |
Member#: 90804
SCIC
Vehicle:2021 Ascent 2012 Accord |
Why mid-May?
04-21-2021, 12:31 AM | #116 |
Member#: 107150
TXIC
I'll probably end up using uship.com to ship them. It sometimes takes a few weeks to get onto someone's scheduled pickup route. I've had decent luck with them in the past...just have to be willing to wait sometimes for the right price.
04-21-2021, 12:58 AM | #117 |
Member#: 90804
SCIC
Don't want to just trailer them home?
04-21-2021, 01:21 AM | #118 |
Member#: 107150
TXIC
Going to try and explore that route as well. Not sure if I have a big enough trailer for all three. My dad is in North Texas and is taking some measurements of some of his trailers. Should know more in a day or two.
04-21-2021, 02:07 AM | #119 |
Member#: 90804
SCIC
Maybe the parts one could go in the bed of the truck.
04-22-2021, 11:56 AM | #120 |
Member#: 107150
TXIC
04-22-2021, 01:15 PM | #121 |
Member#: 203905
You could always rent a trailer from a local resource or find a buddy with one? I don't keep a 24' trailer around but I know 2-3 guys that have one for their toys that would very likely let me borrow one.
This thread is about hardcore music | boosted84wagonmonster | Off-Topic | 634 | 02-18-2012 02:05 PM |
This thread is about "This thread is about" threads... | DrDRum | Off-Topic | 27 | 12-14-2011 04:34 PM |
This thread is about your thought process when chosing a title for your new threads | Asinine | Off-Topic | 29 | 09-30-2008 10:16 AM |
ATTN: CandyO - This thread is about my butt again. | gongzero | Off-Topic | 25 | 03-08-2004 11:16 AM |
