05-01-2020, 12:50 PM | #851 | ||
Member#: 447898
BAIC
Vehicle:2022 Tesla M3P 2019 STI CWP |
The Legacy STI S402 used the very rare VF51. This turbo isn't even documented on most of the common online Subaru IHI turbo lists. The VF51 was exclusive to the S402 with only 402 units made. It has a 9 blade turbine wheel and 6+6 straight blade profile compressor wheel. VF51 RHF5H 14411AA790 The VF42 (144114S000) was used exclusively on the S203 & S204 (~1155 units). This turbo featured a larger diameter (48.5mm) 6+6 compressor wheel, 9 blade turbine wheel (instead of 11), twin scroll P25 turbine housing, and RHF5HB ball bearing CHRA. The VF56 was exclusively used on the R205 (400 units). The VF58 was used on the S206, S207, S208 & Type RA-R. This is the best turbo that IHI ever made for Subaru. It may not be the rarest, but it's the most sought after and nearly impossible to purchase a replacement.. even with proof of ownership. Giorgio @ Advanced Sports Engineering Lab has the only VF58 that IHI ever sold to the public. It was used on his 01/01 Forester STI concept car that was built in collaboration with STI allowing him exclusive access to all of their rarest parts.. even those discontinued and unavailable to the public. https://www.facebook.com/advancedspo...7374465019605/ Let me know if you're interested in obtaining any of these rare turbochargers or would like additional information on them. I'm happy to help.
05-01-2020, 06:54 PM | #852 | |
Member#: 463777
05-06-2020, 09:36 PM | #853 |
Member#: 512837
Spool / HP Numbers
Are these HP numbers based on pump gas? ie 91.
06-17-2020, 11:51 PM | #854 |
Member#: 247519
Vehicle:2012 STI OBP |
There’s a s209 turbo on eBay. $5,000
Thanks for all this info. Great reading. |
06-24-2020, 08:28 PM | #855 |
Member#: 447898
BAIC
I thought some may find this comparison interesting. I extracted the data from the OEM power charts (provided by Subaru/STI) to create a torque curve comparison for various OEM EJ & FA engine/turbo setups.
Battle of the OEM Twin Scroll Subarus & the USDM STI EJ257.
Unfortunately, I wasn't able to find an OEM power chart for the S209 to include in this comparison. However, peak torque from the larger HKS turbo comes on ~1,000 RPM later than the VF48 equipped EJ257 (~4,700 RPM in the S209 vs ~3,700 RPM with the VF48). |
06-25-2020, 08:40 AM | #856 |
Member#: 513220
Vehicle:2005 2005 WRX WRB |
WRXnick16 you are going to make a perfect ej257, I really love your ideas, much different than make horsepower. This is like tune a great piano, but modify that for make that good piano to sound perfect. With the VF58 you will gain all beneficial from the twinscroll, with the Tial you will have a beneficial of one big wheel to spin like a smaller one, so less backpressure at hight rpm and great response at low rpm, a ball bearing that help a lot the spool and make solid and durable one turbo and a bigger inducer great for your engine. Wow!
06-25-2020, 12:08 PM | #857 | |
Member#: 447898
BAIC
My goal is to maximize efficiency, responsiveness and area under the curve. I have no desire for crazy peak power, but rather creating the ultimate OEM-ish EJ257 that Subaru of Japan never made for the US.. the setup that the S209 should have received. I also have an obsession for the OEM+ theme (S-series, Group N, etc.). Previously owning a very responsive, E85 flex fuel tuned, twin scroll FA20DIT was also part of the inspiration for my build. I've never seen a documented build of anyone performing a similar setup. Many will think that I'm crazy for spending the time & money when I could have just went with a [INSERT Brand] ELH & turbo. The only setup that I believe could provide comparable levels of power & responsiveness would be a Killer B ELH & EFR 6258. Advanced Sports Engineering Lab is in the process of rebuilding my VF58 and are one of the only companies in the world that I trust with such a rare turbo. I contacted at least 10 of the most well known turbo re-builders in the US and all said they couldn't and/or wouldn't rebuild it.. I'm not sure if they had even heard of this turbo before. ASEL is rebuilding the turbo with ceramic dual ball bearings, a forged billet aluminum compressor wheel with extended tips (reducing rotational mass while also improving strength & flow), porting the compressor inlet & turbine housing inlet scrolls, ceramic coating the turbine housing, and most importantly, retaining the rare, lightweight TiAL (aka Gamma-Ti) turbine wheel & shaft. Essentially modernizing the turbo with similar features as EFR turbos and the IHI turbos supplied to Ferrari. I'm hoping that this will make for a virtually zero lag setup when combined with the EJ257's extra displacement, longer stroke, and slight compression bump.. just trying to keep up with the FA platform and future FA24DIT STI. I fear it will be quite a torque monster when combined with a flex fuel tune ASEL has been amazing to work with.. sending pictures & videos of the entire process with balancing on their Schenck machine and machining/assembly on the TurboClinic workbench. They clean the parts via sandblasting, ultrasound & solvents.. finishing with a protective coating to prevent rusting. They X-ray, laser & pressure check the components to verify their integrity prior to reusing anything. The compressor housing is currently in their 5 axis CAD/CNC lab awaiting machining to match the extended tip wing profile of the new billet aluminium compressor wheel. Unfortunately, the lab is busy working on some billet racing short blocks at the moment. ASEL primarily specialize in S-series, RA-R & WRC cars and has a direct relationship to STI. They are a true engineering company.. that happens to also have a strong passion for Subaru Motorsports I will receive final pictures, balancing report, etc. once the work is complete. Some teasers in the meantime... An example of their twin scroll conversion "wake up kit" (not my turbo pictured): I'll continue to post updates and other Subaru content like this on my Instagram for anyone interested in following me @STINickTuned. I love the forums and will continue to post here (and on IWSTI) in order to support them.. but unfortunately forums are a dying breed compared to social media. |
06-25-2020, 01:06 PM | #858 |
Member#: 513220
Oh, for sure if you are in the Giorgio's hands you are in good hands!!! You are in my same optic, unfortunately I bought my subaru ej207 with the "wrong" turbo, is a efr7163, also with the usdm sti heather single scroll and unequal. I don't really understand what the people think when put together parts random without even think. Only goal is HP.... I'm sure that also in this discussion there is many people that think, oh my gosh you have an amazing turbo and you spit on it. I'm not, I'm doing that on the whole setup. I dream a 6758 or a 6258 because make more sense. But I don't have the money right now to change everything from scratch, so I'm going to do a twinscroll setup with the t4 housing with the equal length twin scroll setup completely thermal shielded. See the results, if I don't like, sell everything and go with the 6758.
WRXnick16 are you going to change also your cams with a slightly longer durations as you will use a twin scroll? |
06-25-2020, 01:53 PM | #859 | |
Member#: 447898
BAIC
Long term I do plan to change the camshafts in order to take full advantage of the twin scroll setup & AVCS tuning. My dream is to have Giorgio's team to build a blueprinted & balanced "hybrid" with the EJ257 block and S-grade EJ207 heads Obviously the combustion chamber will need to be CNC machined for the proper bore size, chamber volume & compression ratio. But this is all a dream for the distant future. |
06-25-2020, 03:04 PM | #860 |
Member#: 513220
Remember to keep that car forever, because you will be the only one that will appreciate what are you doing!
09-30-2020, 05:20 PM | #861 |
Member#: 447898
BAIC
A huge thanks to Giorgio @ Advanced Sports Engineering for this rare, beautiful, engineering masterpiece.. I almost feel that it better belongs in a museum glass case rather than under the hood of my STI.
JDM STI S208 IHI VF58 turbocharger.. twin scroll, ceramic ball bearing, billet compressor wheel, TiAl (titanium aluminide aka Gamma-Ti) turbine wheel & shaft, and custom CAD/CNC machining & porting. The legendary VF58 that few know exists.. let alone have ever seen. Custom profile 6+6 billet compressor wheel w/ extended tips: The TiAl (titanium aluminide) 9-blade turbine wheel & shaft: More OEM S208 goodness: |
10-18-2020, 11:27 PM | #862 |
Member#: 519501
10-27-2020, 06:02 AM | #863 |
Member#: 519694
10-27-2020, 10:08 AM | #864 | |
Member#: 447898
BAIC
The VF58 was only equipped on the S206, S207, S208 & VAB Type RA-R. Last edited by WRXnick16; 10-27-2020 at 10:24 AM. |
10-27-2020, 10:25 AM | #865 |
Member#: 513220
VF42 wired trottle body, same specs as the vf36 but with a slidly larger compressor.
VF58 should be similar but for sure for what I know is with a different angle in the cold side outlet. Some people here can explain better the differences. Why are you taking out from your subaru a vf42??? |
10-27-2020, 10:37 AM | #866 |
Member#: 519694
Thanks, I hear annoying vee vee noise when start engine, or reving up throttle. noise becomes lower when throttle is released. while I have ordered part with check of part no. from region agent, and given me
ST14411ZR010 turbo, which is VF58,so it does not fit.... OMG. Thanks for confirm VF42 is correct. |
10-27-2020, 10:45 AM | #867 |
Member#: 513220
Sounds like the bearing. All turbocharger that use bearings around 0-3psi are just spinning in one area where them make a lot of noise, that are nothing bad. But depend than your vee vee, there is a vee vee noise and vee vee noise!
10-27-2020, 11:13 AM | #868 | |
Member#: 447898
BAIC
Just a few of the upgrades that the VF58 received:
11-02-2020, 03:48 PM | #869 |
Member#: 447898
BAIC
Another recent release from IHI Turbo Performance!
https://www.ihi.co.jp/ctj/cloverturb...formance/vf49/ VF49 HF (Hi Flow) Twin Scroll IHI Part # F56CAC-SP017 ~$1,000 Rated at ~400 HP with supporting modifications
11-03-2020, 08:12 AM | #870 |
Member#: 513220
The compressor side could be used in the vf36 CHRA
12-08-2020, 11:02 PM | #871 | |
Member#: 369934
Vehicle:2018 STI Limited Heritage Blue |
12-12-2020, 01:45 AM | #872 | |
Member#: 199558
WRXnick16 said ~$1000? I wish. Even if I had to pay $1500 + shipping on the VF49 (high flow) turbo, it would still be more cost effective than compared to the VF48 (high flow) + a proper set of EL Header (especially the best, KillerB). I got my JDM Twin Scroll header for $200. I can find some used regular VF49 turbo's on Yahoo Japan auctions for around $550 + Shipping. I may have to go this route momentarily if I can't secure the VF49HF. |
12-13-2020, 01:23 AM | #873 | |
Member#: 309465
E. Canada
Vehicle:1999 GC + ver 9 swap Feather White |
12-14-2020, 12:18 AM | #874 | |
Member#: 199558
12-19-2020, 05:58 AM | #875 |
Member#: 479502
International
Vehicle:2005 JDM LGT 6MT Gray |
Vf47
IHI VF47
This is the standard equipment turbocharger used on the JDM Subaru WRX S-GT MY07-08.(GH8) This turbocharger is similar to the VF44. |
Similar Threads | ||||
Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever | pepperjack | News & Rumors | 74 | 07-14-2015 07:07 AM |
is there a Subaru turbo list? | housedj | General Community | 8 | 03-18-2009 12:48 PM |
subaru forum list | 949 | General Community | 10 | 11-01-2005 11:32 PM |
Subaru wish list | carrera | News & Rumors | 9 | 06-19-2002 08:45 PM |
('93-'01) Subaru Mailing List | rubadub | Impreza Forum | 3 | 08-18-2001 02:40 PM |
