Tire & Wheel Forum sponsored by The Tire Rack |
10-12-2019, 08:00 AM | #5826 |
Member#: 498642
Vehicle:'19 WRX Ltd 6M dgm '08 Mustang GT (the toy) |
Did you try the "Search This Thread" option with a couple of terms to narrow what the search would be looking for down a bit?
Norm
10-13-2019, 03:11 PM | #5827 |
Member#: 507304
Hey guys! I have a 2020 WRX Premium with the 4pot brembo brakes. Are there any 17" wheels that will work with this? I live in a heavy winter area and would like to downsize from my 18"s.
10-13-2019, 08:06 PM | #5828 | |
Member#: 447898
BAIC
Vehicle:2022 Tesla M3P 2019 STI CWP |
The narrower '04 BBS wheels (17x7.5") will not fit. |
10-16-2019, 09:28 AM | #5829 |
Member#: 367980
Vehicle:2017 WRX / HUQ-22 Lapis Blue Pearl |
My car is a 2017 WRX Limited. The original wheels (Premium / Limited) have summer tires (first pic), have no issues, as expected.
For winter tires I have a set of 2015+ Base wheels (second pic). When I mount the Base wheels there is a considerable clunk, from at least both front but it seems all four, when I hit bumps / potholes on the road. I use the original lug nuts on both wheel sets, torqued to 85 foot pounds. The only things I can think of are the original lug nuts are not compatible with the Base wheels or the rotors are different in some way, between Base and Limited. Both of these theories seem unlikely. Help me out knowledge base. Thanks to Joe Spitz, for the pics! Last edited by pizza_pablo; 10-16-2019 at 09:35 AM. |
10-18-2019, 04:17 AM | #5830 |
Member#: 507515
Vehicle:2019 WRX Red |
year: 2019
model: wrx wheel model: Aspire JNC wheel size/offset: 18x8.5 +34 tire brand/model: tire size: suspension: stock alignment: stock fender mods: none spacers: yes/no? size? No wanted to get these wheels. Wasn't sure if they would fit my car. |
10-25-2019, 11:35 AM | #5831 |
Member#: 168946
Vehicle:2019 Subaru WRX Crystal White Pearl |
Wheel Noob
year: 2019
model: WRX wheel model: N/A wheel size/offset: 18x9.5 +34 or 18x10.5 +22 tire brand/model: N/A tire size: N/A suspension: Stock alignment: Stock fender mods: None, but willing to roll if necessary. spacers: yes/no? size? Yes, if necessary. TheShaddix on youtube has a very nice and aggressive setup. I would love to do something similar. I'm just a total wheel noob. Any advice/help is greatly appreciated! |
11-16-2019, 09:57 PM | #5832 |
Member#: 495057
11-20-2019, 06:09 PM | #5833 |
Member#: 506844
Vehicle:98 Legacy OBW |
11-21-2019, 07:11 AM | #5834 |
Member#: 498642
11-26-2019, 02:51 PM | #5835 |
Member#: 508442
Vehicle:2013 Impreza HB |
2013 Impreza Wagon upgrade
Bought my first Subaru last week, and am already thinking about a tires and wheels upgrade. It's a 2013 Impreza sport premium wagon, with OEM 17x7 wheels and 205/50R17 tires. Looking at 17x8 wheels with +45 offset. A 225/45R17 tire is slightly smaller in diameter, and lowers the effective final gear ratio and spins the speedometer/odometer just a bit faster. If I go to a 235/45R17, it would be a slightly larger diameter than OEM. Suggestion?
The other consideration is fitment. It looks like the 225's will have plenty of clearance.(?) Am I pushing it with 235's, with everything else being stock? Thanks! |
12-02-2019, 01:44 PM | #5836 |
Member#: 501363
Vehicle:2018 Wrx Premium WR Blue |
the wheel fitment thread: keep it drama free
Hello all, I have a little bit of a dilemma on my hands. Right now I’m running an 18x9 +30 offset 245/40/18 for the summer and the same size wheel but a 33 offset and same size tire for the winter on my 2018 Wrx. I want to throw some coilovers on and I’ve looked on fitment industries and looked around for someone throwing the same sizes(mostly 30 offset) to see how low they go and the degree of camber they use. Sadly not too many people post their coilover adjustment specs. Some people ran these sizes but rolled the fenders or rubbed but I’m not looking to touch the fenders. Because of this, I haven’t found any help to my issue.
Any help would be greatly appreciated, thank you |
12-10-2019, 02:14 AM | #5837 | |
Member#: 362877
NWIC
Vehicle:2014 WRX Hatch Blurple |
01-09-2020, 09:49 PM | #5838 |
Member#: 509846
2003 Subaru Impreza 2.5 RS Best Tire for Rim?
I was wondering what tires that are mid-price range, but offer good grip? I have brz rims on my Subaru. So I was wondering what would be a good fit. I also have BC coil overs and adjustable rear end links if that is more useful information as to what tires I can fit.
01-10-2020, 07:55 AM | #5839 | |
Member#: 498642
Never did get a notice of your reply . . . just another of those things I have no idea what to fix or where to look. Sorry for the off-topic. Norm |
01-10-2020, 08:12 AM | #5840 | |
Member#: 498642
I can provide a plot comparing the two wheel/tire combinations that's more realistic than any of the online calculators. On edit, thanks for your question, as I found a useful OE wheel reference as a result of doing a little research. Norm Last edited by Norm Peterson; 01-10-2020 at 08:18 AM. |
01-18-2020, 09:05 PM | #5841 |
Member#: 416175
I have a set of TE37RT in 18x10 +44 with 265/35/18 tyres and they are hitting my coilovers on the 2013 wrx. Is there a way to fit them beside getting spacers? will the STI alloy lower control arm, adjustable whiteline bush and anti lift kit help to fit these wheels? Guards rolled. Thanks
01-19-2020, 08:21 AM | #5842 | ||
Member#: 498642
I don't know anything about the 2013, but clearly +44 is the wrong offset for using 18x10's on it. Your best bet really is to use spacers that are no thicker than just barely enough to cure the problem, and install longer and stronger wheel studs so that you'll have enough lug nut thread engagement (one stud diameter's worth). Think ARP, for starters. FWIW, removing and replacing wheel studs is not a difficult job at all (tip - you don't need an impact gun and shouldn't use one for installing wheel studs anyway). I realize that spacing the wheel outward to clear takes away from whatever sheetmetal clearance that you have. So would the approach that affects camber. If your car is lowered, you might have to raise it back up a bit to gain a little clearance to the fender sheetmetal. What I do know is that strut suspensions can tolerate a noticeable amount of wheel and tire 'poke' without rubbing if the car isn't lowered too much. Not a Subie, but it does have a strut suspension and it does not rub at all even when driven hard on a road course. As shown, there's a very thin DIY-fabbed spacer cut from 0.025" thick aluminum sheet. Still doesn't rub after the front of the car was lowered about half an inch. The fenders are not modified at all, and there is less than 1/16" clearance to the strut. Norm Last edited by Norm Peterson; 01-19-2020 at 09:02 AM. |
01-19-2020, 08:19 PM | #5843 |
Member#: 416175
The inner lip of the front wheels touched the the ring locker of the coilovers. I maxed out the coilovers' camber and camber bolt but they still hit the coilovers. As you said using spacers is the only way for these wheels to fit the car or sell them . I love the red color on white car. Thanks for your help mate!
02-01-2020, 06:39 PM | #5844 |
Member#: 472751
NESIC
Vehicle:2018 WRX WRB |
wondering what size tire to go with.
Year: 2018 Model: WRX Wheel model: Rota Grid Wheel size: 18x9.5 (5x114.3/e38/73) Tire brand: Hankook Ventus V12 Evo 255/35/18 or can I run 245/40/18? Suspension: Swift Spec-R lowering springs. Drop is 1 inch. |
03-05-2020, 04:52 PM | #5845 |
Member#: 511746
Vehicle:2012 WRX |
Year: 2012
Model: WRX Wheel model: Enkei Raijin Wheel size: 18x8.5 +45mm 5x100 Tire brand: Michelin Pilot Sport a/s 3+ 255/45/R18 Suspension: Stock Will this set up fit? |
04-04-2020, 08:18 AM | #5846 |
Member#: 429771
have just done sedan fenders and sti alloy LCAs on an 04 wagon. very uneducated when it comes to wheels.
The track is now 10mm wider at the front on each side. I would like to use a wider (or different offset) in the rear so the tracks match. I also want to fill out the guards, the front guards are wider than the rears obviously so am just a bit confused where to start any tips? |
04-04-2020, 10:01 PM | #5847 |
Member#: 513182
year: 2013
model: WRX Wagon wheel model: Rotiforms wheel size/offset: 18x8.5 +35 tire brand/model: N/A tire size: 235/35/18 suspension: Stock alignment: Stock fender: no adjustment spacers: no. |
04-19-2020, 12:18 AM | #5848 |
Member#: 494063
I've been reading through the forum for over an hour and cannot find a straight answer online anywhere. Looking for the best set up for a 2010 STI hatch with stock suspension and without rolling or pull fenders. Im looking at 18x9.5 +30 on 240/35 (if i cant use my current 245/40). Can anyone chime in on this ?
According to other sources 08-10 is different from 11+ in regard to fitment and i have not been able to find anything on 2010 specifically |
04-19-2020, 07:38 AM | #5849 |
Member#: 498642
I don't think a 245/35-18 is a big enough tire in terms of load capacity . . . too many load index numbers smaller than the OE 245/40-18 to realistically recover by inflating them higher than the pressure shown on the car's tire inflation placard.
9.5" is within the tire industry's acceptable range of wheel widths for either of those sizes, so the 245/40 would be OK in that respect. But I don't know anything about how much room there is in a 2010's wheel well, so I'm afraid I'm not able to be of much help as far as fitment & offset is concerned. Norm |
04-24-2020, 12:40 AM | #5850 |
Member#: 492997
SCIC
Vehicle:2018 WRX Limited black |
2018 Wrx Limited. Would 18x9.5 et 38 with 255/40 tires on swift springs fit without rolling or pulling fenders? Any input pls. Thank you
the motorsport fitment thread: because race car! | nhat | Tire & Wheel | 45 | 11-20-2011 03:21 PM |
the official wheel/tire fitment thread: all fitment questions go here! | nhat | Tire & Wheel | 1086 | 06-15-2011 01:02 AM |
where did the wheel fitment chart go? | PoopRSkupe | Brakes, Steering & Suspension | 0 | 01-26-2004 01:36 PM |
A thread in the STi forum to keep it alive (because STi forum is closing) | Eric SS | Off-Topic | 6 | 09-10-2003 03:54 PM |
