10-24-2019, 06:37 PM | #1 |
Member#: 507713
New to the Forum and new to the Subaru
Hello everyone, I'm new to the forum and Subaru, had some nice cars in the past like Lexus IS-F, BMW M3 etc., and always wanted to try Subaru so i just bought one for project, its an 05 STI with 135k miles that i just bought from auction (hope there is still a lot of life left), hit in the front, so i want to convert it to an 06 Hawkeye right away because i need whole frond end anyways so why not...Let me know what you think
10-25-2019, 02:23 AM | #2 |
Member#: 479135
135k is a lot of miles. Hope you got it cheap man. Plus sti's just get abysmal gas mileage. Nice car though.
10-25-2019, 04:16 AM | #3 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
We think you shouldn't use Photobucket.
Use a hosting site like Imgur that lets you link to your pics without blocking them. |
10-25-2019, 09:10 AM | #4 |
Member#: 395793
Vehicle:2005 92x Aero Beige |
135k isn't a lot of miles if it wasn't abused. If it was abused 40k could be a lot of miles. Many of us have had well over 200k without many issues or headaches. Make sure you do your do diligence; compression and leak down test, timing belt and associated items including water pump, trans and rear diff fluids, use a quality 5w-40 oil, Subaru green coolant, etc. These will help you get the most mileage and life out of it. Adding modifications can reduce that life depending on what you add and how aggressive it's tuned. Do your homework, don't cheap out and you'll have a good car. If it was treated well before you that is.
10-25-2019, 09:18 PM | #5 |
Member#: 507713
10-25-2019, 09:19 PM | #6 |
Member#: 507713
10-25-2019, 09:23 PM | #7 | |
Member#: 507713
Valve cover gasket(s) replaced Oil and filter changed Fuel line/hose replaced Exhaust pipe seal replaced Timing belt replaced Spark plug(s) replaced Spark plug tubes/seals replaced Camshaft seal(s) replaced So i think its a good start? i know the mileage is not low but im just hoping i can still make a nice build out of it... |
10-25-2019, 09:29 PM | #8 |
Member#: 507713
Here are some more pictures of the STI
11-03-2019, 06:54 PM | #9 |
Member#: 507713
STi is home
Hey folks the STi is in, got it last week, didnt get to it yet but quickly checked it out to see how much work i have, also have a few questions. So it looks like i have these mods so far
1. Kinugawa TD06SL2-20G Turbo 2. Some afretmarket injectors??? 3. Infidia Full exhaust 4. Perring Headers this is what i was able to see right away, will look for more stuff this week I was wondering if its possible somehow to tell if the motor was swapped? (because the engine looks too clean for the year and mileage of my STi). I dont know how to look for the VIN on the block or maybe there are some visible differences between the EJ25s in certain years? Also have some black aftermarket injectors Im assuming if the stock should be yellow? Last edited by A_COOL_OFF; 11-03-2019 at 06:59 PM. Reason: picture not showing |
11-06-2019, 06:30 AM | #10 |
Member#: 329186
nice project
11-06-2019, 09:06 PM | #11 | |
Member#: 34368
how does aution work? can it be bought by a normal person or does it have to be a shop? can it be registered? |
11-06-2019, 10:21 PM | #12 |
Member#: 507713
11-06-2019, 10:22 PM | #13 |
Member#: 507713
I got this one through my friend he is a dealer, but some auctions are open for public like Copart, you can bid in ur state i think...
11-06-2019, 10:31 PM | #14 |
Member#: 507713
So far i know this STi is already a beast, looks like someone swapped a newer EJ25 in it i just have to find out what year and hopefully the mileage of this motor, but it should make a lot of HP already, just need to figure some other things and jump in to a project
Plans are: Hawk eye conversion ( maybe WRC version) Rocket Bunny wide body kit some Flow Formed wheels 18 x 10.5 or similar coilovers front mount intercooler so far this is everything that i could think of right now.....maybe some other little things |
11-07-2019, 08:24 AM | #15 |
Member#: 501134
Vehicle:2004 STI JBP |
Rocket Bunny STI??
11-07-2019, 11:10 AM | #16 |
Member#: 507713
11-09-2019, 12:36 AM | #17 |
Member#: 507713
Some info about my STi
Some good news here, was able to find a previous owner of my STi so, The motor was just built and has about 10k miles on it (2017 STi short block)
11-11-2019, 10:35 PM | #18 |
Member#: 507713
Before it begins
I will just post a pic of the STi here before the build starts...
11-13-2019, 03:58 PM | #19 |
Member#: 508327
Funny enough, just wanted to say I saw that I got into Subaru because Cars was on the Dutch Netflix and I really found the one looking like one
11-13-2019, 04:20 PM | #20 |
Member#: 439586
Vehicle:2015 WRX ISM |
Oh man this is going to be sweet. Please post as you go!
Unfortunately Rocket Bunny doesn't make a kit but there are a few good ones from other manufactures. |
11-13-2019, 08:35 PM | #21 |
Member#: 507713
12-04-2019, 12:26 AM | #22 |
Member#: 507713
Suspension work
Front suspension completely stripped down to just axles, all the new parts and bushings are coming in the mail...
[IMG][/IMG] |
12-04-2019, 12:37 AM | #23 |
Member#: 507713
Building a motor
Hey guys, just wanted to post the mods that i currently have/ will have on my motor within a month or two, and if anyone knows how much power am i looking to get out of it? Going to be weekend car only...
Freshly built 2017 sti block New TD06-20G turbo Front mount intercooler Turbo Inlet pipe Cold air intake Upgraded Aluminum radiator 1000CC injectors Upgraded fuel lines Perrin uppipe invidia downpipe with invidia exhaust (catless) |
12-04-2019, 01:05 AM | #24 | |
Member#: 130990
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
12-04-2019, 01:11 AM | #25 |
Member#: 507713
would i need a bigger turbo to make more power? what turbo would i need? i already have bigger fuel pump just didnt get to check what kind it is. Previous owner made 325whp and he had a bad td06 20g (a lot of shaft play), stock airbox with stock turbo inlet and stock TMIC
