05-17-2022, 09:25 PM | #51 | |
Member#: 508105
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
I've heard conflicting reports on what you are describing. With emissions/smog being more difficult or impossible to pass with current OS implementations, which obviously varies based on MY. Not to mention open source sucks to tune. Hence why no good tuners really support it.
05-17-2022, 09:54 PM | #52 | |
Member#: 306422
Vehicle:2005 Impreza 2.5RS Dark Blue |
Anyway, we will see ... Open source was the only option before things like AcessTuner and Ecutec. Now that this speed bump was introduced, I have no doubt that people will perfect the open source route. Or everyone will just move to tesla swapping everyting |
05-18-2022, 04:41 PM | #53 |
Member#: 406087
Vehicle:06 GGB 6sp Wagon WRB |
i meant, i don't know why folks don't realize they can go OS tuned (which still has the capability to turn off CELs for emissions/smog), then just use the AP they have for monitoring as most of us already do with the AP.
05-18-2022, 08:05 PM | #54 |
Member#: 73932
RMIC
Vehicle:2005 STi EFR 6758 04 S2000 EFR 7064 |
You'd have to have the AP married to use it to monitor.
05-20-2022, 03:51 PM | #55 |
Member#: 406087
05-20-2022, 05:53 PM | #56 |
Member#: 73932
RMIC
If you use the AP, nothing from OS will be applied. To log a "stock" car with the AP, you still marry it and run their "stock" tune.
05-22-2022, 03:20 PM | #57 |
Member#: 526000
Vehicle:2006 WRX STI WRB |
Rotated Setup on Cobb Still Possible?
Is it still possible to go with a rotated build using Cobb tuning software? I have heard speed density is still an option, but I’m not sure how much emissions things like the cats, tgv deletes, etc. hold the car back at say 500 + hp. Currently I can’t touch the tune on my car because Im running a catless DP, but I’m considering switching to a catted one in the future.
05-26-2022, 11:21 AM | #58 | ||
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
You guys realize there's a whole bunch of sub-forums on NASIOC, right, and that those sub-forums are tailored to different areas of discussion, right? Why are you posting these questions in the non-technical forum that is devoted to dress-up mods? |
05-27-2022, 02:36 AM | #59 | |
Member#: 526000
05-27-2022, 02:48 AM | #60 |
Member#: 508105
There's like 4 threads kicking around on this topic ATM
06-16-2022, 08:40 AM | #61 |
Member#: 379208
Vehicle:2018 Wrx WRB |
So did it works for you? I needed to download a Base map onto the AP but my AP hasn't be updated since 2017. I'm afraid that after the update I would not be able to flash the ecu with a old map that was not "compliant" before the green speed. could you or someone confirm it will still work.
06-16-2022, 04:42 PM | #62 |
Member#: 50902
RMIC
Vehicle:98 $$$ Green |
Has anyone figured out yet how to use the AP to make their wing go up and down?
Nooo? Then what the farg is this doing in here. |
06-16-2022, 05:27 PM | #63 |
Member#: 530321
Your "good tuners" only like the AP so they can lock the tunes so you can't share them with anyone else, or open it to see what's actually in it..
With open source I could "buy a tune" and then give it to you, or even sell it to you.. Piracy.. Kinda.. Otherwise Opensource will do everything an AP can as far as tuning and flashing.. Tuning is not some kind of magic.. The biggest part is UNDERSTANDING how an engine works, how boost works, how sensors work, etc.. Oh yeah.. Opensource does flex fuel too.. Nothin special about the sensor used.. Heck you could use basically any flex fuel sensor from ford to Honda and it would work.. Understand how the sensor works, understand how sensor scaling works, understand how alcohol carries less specific energy but is higher octane***8230; Tune it in.. |
08-04-2022, 07:03 PM | #64 |
Member#: 334345
Vehicle:2008 Impreza WRX STi Charcoal |
Can a tune that was written by a tuner before the Cobb green speed update be altered if it has things like cat deletes? Or does the green speed update apply to all tune revisions too?
08-06-2022, 11:45 AM | #65 |
Member#: 222494
Vehicle:17 STi WHITE |
Tune revision equals new tune so the green speed update will apply to the revisions. If you have since removed a cat and are trying to tune for it you will get a CEL
Sent from my iPhone using NASIOC |
