Old 04-26-2022, 08:17 PM   #1
newbie123
Member#: 326377
2006 WRX Wagon
Default 2005 LGT EZ30R Turbo kit
Building a custom turbo kit for my 2005 lgt
Header built out of 1.5” sch10 321ss primaries, and 2” secondaries. Using a Garrett gtx3584rsii. I plan on doing a front mounted turbo, and awic with a rotated custom aluminum intake manifold. I will keep this thread updated with my progress.
Sent from my iPhone using Tapatalk
newbie123 is offline   Reply With Quote
Old 04-26-2022, 08:28 PM   #2
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
02' EJ205 20G 6MT wagon
Very nice stuff.
What's your power goal?
K3rm1tth3fr0g is offline   Reply With Quote
Old 04-26-2022, 08:33 PM   #3
newbie123
Member#: 326377
2006 WRX Wagon
Originally Posted by K3rm1tth3fr0g View Post
Very nice stuff.
It would be cool to make 500whp on the bone stock long block before dropping in a built motor. If I can make 750whp when it’s done, I’ll be happy.
Old 04-29-2022, 06:01 AM   #4
SoCoNoHa
Member#: 478524
1995 EZ30 Coupe
Green
Holy gorgeous manifolds!
I would think 500 on the stock block is doable, but she ain't gonna like it. It would probably survive if driven conservatively and ALL the supporting mods are done. 750 on a built one some be no problem.
Idk if you're interested, but this dude has a turbo ez30 in his LGT.
https://youtu.be/OyWe1_sxEE4
SoCoNoHa is offline   Reply With Quote
Old 04-29-2022, 10:11 PM   #5
newbie123
Member#: 326377
2006 WRX Wagon
Yeah I don’t have to high of expectations out of a stock block.
Brandon is the man! He’s actually helping me out with my wiring. Super cool dude!
Old 04-30-2022, 08:35 AM   #6
SoCoNoHa
Member#: 478524
1995 EZ30 Coupe
Green
That's awesome! Can't wait to see the progress!
Old 05-09-2022, 09:21 PM   #7
newbie123
Member#: 326377
2006 WRX Wagon
Turbo is hanging in its new home. Talking with turbosmart and haltech about possibly using the new electronic straight gate.
Old 06-02-2022, 10:43 PM   #8
newbie123
Member#: 326377
2006 WRX Wagon
Got the “up-pipe” fit and welded. Left it long so I can cut it to fit. Working on the wastegate
Old 06-16-2022, 11:33 PM   #9
newbie123
Member#: 326377
2006 WRX Wagon
Finally got something done. A lot of work goes into this stuff
Old 06-19-2022, 08:17 PM   #10
newbie123
Member#: 326377
2006 WRX Wagon
Old 06-24-2022, 01:42 AM   #11
newbie123
Member#: 326377
2006 WRX Wagon
Added a small bend to move the turbo closer to the engine. Much happier with the placement now! Time to finish the last couple welds on the header
Old 07-23-2022, 07:28 PM   #12
benflynn
Member#: 515308
Room under there for for twins bolted as close to the ex flange as possible? And oil sump/pump
benflynn is offline   Reply With Quote
Old 07-25-2022, 11:55 PM   #13
newbie123
Member#: 326377
2006 WRX Wagon
I’ve seen it done before. I considered twins, but the way my bank account is setup …
Old 08-06-2022, 12:34 AM   #14
newbie123
Member#: 326377
2006 WRX Wagon
So close. Just need some free time!
Old 09-19-2022, 10:35 PM   #15
newbie123
Member#: 326377
2006 WRX Wagon
Had some time to work on the car this past couple weeks. Header just needs the vband for the wastegate welded (need to machine a heat sink before welding it). Welded the oil return bung in the front cover (welded from the inside). Fuel lines complete up to the firewall. Can’t wait to drop the motor in and keep rolling!
Old 11-10-2022, 09:01 PM   #16
newbie123
Member#: 326377
2006 WRX Wagon
Downpipe ready to finish weld
Old 11-16-2022, 09:31 PM   #17
newbie123
Member#: 326377
2006 WRX Wagon
Just need to add a hanger and she’s done. Deciding if I want to recirc the wastegate into the downpipe or just make a straight dump for it.
Old 11-18-2022, 11:47 PM   #18
newbie123
Member#: 326377
2006 WRX Wagon
I need to talk to some professionals in the cooling department. I need to decide what size radiator is needed and if I should do awic or not. Any recommendations?
Old 12-11-2022, 11:54 PM   #19
newbie123
Member#: 326377
2006 WRX Wagon
Fuel lines are complete
Old 12-21-2022, 07:36 AM   #20
scubaboo
Member#: 464859
Very nicely done!
scubaboo is offline   Reply With Quote
Old 03-19-2023, 04:08 PM   #21
newbie123
Member#: 326377
2006 WRX Wagon
Old 07-06-2023, 12:13 AM   #22
newbie123
Member#: 326377
2006 WRX Wagon
Making some progress on the intake manifold. Would anyone be interested if I started making these?
Old 07-14-2023, 05:38 AM   #23
RiceBuster
Member#: 124809
04 FXT, 07 STI
JBP, SWP
Awesome progress!! Do you have an IG to follow?
RiceBuster is offline   Reply With Quote
Old 07-14-2023, 10:11 AM   #24
newbie123
Member#: 326377
2006 WRX Wagon
I don’t have social media, but I was considering starting a YouTube channel. Maybe I will
Old 11-05-2023, 01:52 PM   #25
Bambi-Legacy-turbo
Member#: 536026
Default Alternator bracket/AC delete
Did you custom make that alternator bracket? Have you deleted the AC pump and pulley?
Can you not use the stock composite plastic intake?
I like the front mounted turbo, I am currently pulling an ez30 and 6 speed MT to out in my JDM legacy twinscroll, and plan to do turbo setup like MCM boys in Australia, up pipe between the brake booster and steering rack location.
Wish I had your welding skills!
Bambi-Legacy-turbo is offline   Reply With Quote
