02-01-2021, 06:23 PM | #11301 | |
Member#: 229105
MWSOC
02-12-2021, 01:26 PM | #11302 |
Member#: 292403
Tri-State
Vehicle:2012 Legacy Graphite |
02-12-2021, 01:29 PM | #11303 |
Lord of the Gif
Member#: 1703
NWIC
Vehicle:2020 Giulia TI Sport Black |
your linky no worky
02-12-2021, 01:33 PM | #11304 |
Member#: 292403
Tri-State
https://www.facebook.com/groups/1687...97938393794662
Would it not work if the group is private? It's these: Vandersteen 1C with Sound Anchor Stands. Excellent Condition. |
02-12-2021, 01:34 PM | #11305 |
Member#: 21356
NESIC
Vehicle:2017 Subaru Corolla STI Limited SE-R Type (R) |
still doesn't work
Private group. Why not screenshot? |
02-12-2021, 01:37 PM | #11306 |
Member#: 292403
Tri-State
I did
02-12-2021, 01:40 PM | #11307 |
Member#: 21356
NESIC
ah, it finally showed up
02-12-2021, 01:49 PM | #11308 |
Member#: 292403
Tri-State
Ok, so are they great/ good/ bad?
02-12-2021, 02:24 PM | #11309 |
Member#: 103474
MWSOC
Vehicle:My other ride is your mom |
Decently regarded speakers, just depends on the price and if you like the sound.
02-12-2021, 02:26 PM | #11310 |
Member#: 292403
Tri-State
$300 for the pair
02-12-2021, 02:34 PM | #11311 |
Member#: 103474
MWSOC
Doesn't seem like a horrible price if condition is good.
Tried searching ebay for comparables sold and I think I found 1 that sold for $400, lost the page and can't seem to find it now. But I'm not an ebay pro by any means, ha. |
02-12-2021, 03:04 PM | #11312 |
Member#: 30733
TXIC
Vehicle:2007 tiny car striped |
Vandersteen are good speakers. You can probably get more accurate standmount modern speakers for similar monies. Something well engineered with modern methods but cheaply built.
However for nicely built floor standers made in the USA, 300$ seems reasonable. The socks come off so you can see the driveres. Make sure the surrounds and tweeters are in good shape. You can find similar vintage klipsch KG series for about the same money if you like something a bit more lively. Hadnt heard any vandersteens in many years but they have a reputation for being a bit laid back (not a bad thing in my mind). |
02-14-2021, 03:43 PM | #11313 |
Member#: 229105
MWSOC
02-21-2021, 10:39 AM | #11314 |
Member#: 2973
MWSOC
Vehicle:2018 Camaro ZL1 1LE Red |
Picked up the Starke Sound AD4.320 and got it added to my setup running my fronts in bridged mode. Pretty happy with it, definitely cleaned things up when pursuing higher volumes. Downside is I've now got a ground loop hum where I've ordered a bunch of stuff to resolve.
AVR is "double insulated" so has no actual ground, amplifier has a ground. Even with all inputs removed from the AVR I still get the hum. I've got a jensen isolation transformer on order that I plan to utilize between the AVR and the amplifier which should resolve things but I guess I'll find out. |
02-22-2021, 10:54 PM | #11315 | |
Member#: 265783
RMIC
Vehicle:2017 Forester XT Niner ROS 9 |
02-23-2021, 08:00 AM | #11316 | |
Member#: 2973
MWSOC
Hum persists if I use different outlets and bypass the PDU. Hum persists if I remove all sources but does quiet from 40db to 30db or so if I remove the cable box. Hum goes away if I unplug the AVR from power. Hum goes away if I use a cheater plug on the new amplifier. (this is unsafe, but I'm currently running like this until the rest of the possible fixes are delivered.) Hum persists if I ground the amp chassis to the receiver chassis with some spare 12awg copper speaker wire. I have on order:
02-23-2021, 09:20 AM | #11317 |
Member#: 13772
RMIC
Vehicle:16 Frontier Red |
A Humx plug solved my ground loop hum.
https://www.amazon.com/Ebtech-Hum-Pl...s%2C240&sr=8-2 Was $25 cheaper 4 years ago when I got mine. And it's only good for devices up to 6A. |
02-23-2021, 09:50 AM | #11318 | |
Member#: 2973
MWSOC
https://centralindianaaes.files.word...notes-v1-0.pdf |
02-23-2021, 11:05 AM | #11319 |
Visiting NASIOC Timeout
Member#: 2197
Tri-State
Vehicle:an inconvenience, properly considered. |
I don't play this often because it's 2 discs at 45rpm, which means getting up to flip sides or change records every 10 minutes. Worth it though. |
02-23-2021, 11:41 AM | #11320 |
Member#: 2973
MWSOC
02-23-2021, 12:26 PM | #11321 |
Member#: 7121
MWSOC
For anyone who has a wired whole house audio setup, this is worth checking out:
https://www.kickstarter.com/projects...em/description I jumped on backing one along with a zone extender because I have 8 zones in my house. This is something I've been looking for since I moved in here. Right now there is just the typical zone switch and its an all or nothing kinda deal as far as audio source. It will be nice to be able to pick a different source per zone or group of zones (up to 4 different sources). Also having a dedicated amp per zone will be nice as well. |
02-23-2021, 06:11 PM | #11322 |
Member#: 2197
Tri-State
02-25-2021, 09:31 AM | #11323 | |
Member#: 265783
RMIC
Hopefully your new stuffs will solve it. A buddy of mine runs one of these to solve a hum issue he had: https://www.psaudio.com/products/noise-harvester/ |
02-25-2021, 09:32 AM | #11324 |
Member#: 265783
RMIC
02-25-2021, 09:59 AM | #11325 |
Member#: 2197
Tri-State
Picked up those Monitor Audio Silver 500's a few months ago, they're ridiculous. Got a copy of Moby - Play on vinyl the other day and Body Rock has some ass rumbling bass in it. Can't play that one without the neighbors getting pissed.
Gave my old standmount Deftechs and 8" sub to a friend for his basement/office turntable system. |
Similar Threads | ||||
The official Post pics of your Home Audio/Video setup? V2.0 | GRUMPY514 | Off-Topic | 74 | 07-30-2008 09:50 AM |
VA: Home Audio/Video/Game | AspenWhite | Non-Subaru Stuff | 5 | 03-06-2007 09:43 AM |
WRX parts, home Audio/Video stuff, and more... | NicFunkadelic | NESIC Private Classifieds | 6 | 02-15-2007 10:38 AM |
Home audio/video wiring gurus, need a bit of help. | trail*of*dead | Off-Topic | 16 | 12-23-2006 02:25 AM |
Home audio/video goodies for sale! Tivo! Replay! Pronto! | BiggSean | Private 'For Sale' Classifieds | 7 | 02-26-2006 11:15 PM |
