Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 12-29-2020, 03:05 PM   #11126
NutBucket
Member#: 90804
2021 Ascent
2012 Accord
Nice. Definitely a rewarding endeavour. I'm currently listening to my dad's Kenwood 5150 reciever...also mid 70's era. I also have a Sansui similar to the one I posted that belonged to my wife's grandfather. That one I refurbished.
NutBucket is offline   Reply With Quote
Old 12-29-2020, 03:10 PM   #11127
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
Originally Posted by NutBucket View Post
you guys are doing this analog thing all wrong:
That’s quite handsome!
Old 12-29-2020, 03:20 PM   #11128
tbert
Member#: 43357
2004 Smug 46MPG
2016 Clown Car also zoom3
Oooh...Nice Sansui.
My Luxman R117 R channel gave up the ghost. I looked at info to repair it but I am not good with electronics or PCB, and this thing is a beast to work on and not a novice project. Not all the capacitors or resistors are even available to fix it. I'll park that for a bit and look for another vintage receiver. My requirement on these is to have the VU Meters on the face, like yours. That limits me somehow, along with my budget. I'll probably settle for a Pioneer SX-580 or 680 (780 is too rich for my taste).
tbert is offline   Reply With Quote
Old 12-29-2020, 03:33 PM   #11129
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
It is from 1972 (so is 6 years older than me...)
I started using it back in the mid 2000s. Great warm sound. I prefer the accuracy of modern equipment but the older sound is nice and relaxed.
Akirasoft is offline   Reply With Quote
Old 12-29-2020, 07:00 PM   #11130
aschen
Member#: 30733
2007 tiny car
striped
Originally Posted by Akirasoft View Post
yeah at that point im trading one cycle in the receiver for one in the minidsp, and it looks like the minidsp 2x4 has only 2 RCA inputs?
Yes 2, was thinking just running your analog pre outs to it and then the summed output to the sub. Then you could listen in pure direct mode with your mains never re entering digital domain. Not 100% sure what the avr does with the lfe channel when in direct mode, If it leaves it open you should be able to leave it connected to the sub, if it actively mutes (shorts) the inputs I'm not sure what the sub how the sub will deal with it.
There are other minidsp with more inputs and you can get quite creative with all the plug ins available and configure them to do just about anything reallly.
aschen is offline   Reply With Quote
Old 12-29-2020, 07:04 PM   #11131
aschen
Member#: 30733
2007 tiny car
striped
Very lovely, even if it has those new fangled transistors
Would pair nicely with an omega seamaster constellation or I guess king seiko would be more appropriate
Old 12-29-2020, 07:13 PM   #11132
NutBucket
Member#: 90804
2021 Ascent
2012 Accord
I have a tube receiver that needs a recap. Haven't had time to start it. Don't want to leave it half done or it'll never go back together!
Old 12-29-2020, 10:02 PM   #11133
bcblues
Member#: 17256
18 Outback
on the road....
Sansui 881?
I had one of those in the 70s. It sounded awesome. Wish I still had it.
bcblues is offline   Reply With Quote
Old 12-29-2020, 11:06 PM   #11134
NutBucket
Member#: 90804
2021 Ascent
2012 Accord
That's a 9090DB. I have a "plain" 9090. I'm good with that since the dolby circuit is known to be problematic and nontrivial to repair.
Old 12-30-2020, 01:31 AM   #11135
340Duster
Member#: 52314
... 02 and 04 WRXs!
2020 G70 3.3T RWD
My parents tossed a fantastic analog receiver and 8 track tape deck years back, and it kills me. I now have two consoles, one fully tube and one solid state. The SS one needs a driver replaced but plays vinyl well. I'm sad that I can't easily fix the other, from what I've tested, something in the amp seems to only power one channel (it alternates) at a time.
340Duster is online now   Reply With Quote
Old 12-30-2020, 07:16 AM   #11136
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
my initial thoughts at the moment is I'm chasing after fleeting gains. My receiver is already one of the better models out there (Anthem MRX720) and it is not like I'm dealing with a treated listening space. I'm just trying to get the cleanest possible signal in before amplification because I have been detecting some distortion at louder volumes. I'm now attributing it to lack of power. Even then, doubling the power will only get me 3db more output but at the previous output level there will be less distortion and it will be safer on the mains.
*shrug*
Old 12-30-2020, 10:26 AM   #11137
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
*shrug*
Seems like decent power, unless your speakers are super power hungry, but maybe you should try a cleaner amp for your mains? That MRX is spec’ed at 1% THD with 2 channels driven. Not that hot... I run separates, and my 5 channel system has a 5x140 watt Marantz MM7055 power amp, which sounds very good imo. They make a 2 channel variant, the MM7025 that is 2x140 watt with .08% THD. Or you just use the MRX as a pre and could go with the Marantz MM8077, which is 7x150 watts at .08% THD.
Old 12-30-2020, 11:21 AM   #11138
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
MRX720 is 140 wpc, I'm looking at either a Starke Sound AD4.320 (430w*2 when bridged) or ATI AT542NC (500w*2). Intention being it is far safer to overdrive than underdrive a speaker, and the BP9060s are good for 300W.
Old 12-30-2020, 11:44 AM   #11139
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
Nice looking amps. I wasn’t familiar with Starke Sound. Interesting looking “hybrid” amp. I’m sure the increased power and much cleaner signal with either of those amps will help tremendously. Separates are the way to go, imo.
I had noticed the MRX’s power, but was mentioning the Marantz as having the same power, but with significantly better THD specs. I see the Starke and ATI are even cleaner!
Old 12-30-2020, 12:04 PM   #11140
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
yeah, at the time I wasn't going to roll with separates for budgetary reasons (since I was starting from scratch and buying EVERYTHING all in one go) and the Anthem was one of the best reviewed AVRs in the $2500 or so price range. Now I'm gradually updating things piece by piece... The limit now is power as I only have a single 15A circuit available to my rack in the living room and the breaker panels are already oversubscribed by 3x(!!!).
Old 12-30-2020, 12:11 PM   #11141
Kalle_
Member#: 521316
Indeed
Kalle_ is offline   Reply With Quote
Old 12-30-2020, 12:19 PM   #11142
Reflex-Arc
Lord of the Gif
Member#: 1703
2020 Giulia TI Sport
I've got some new stuff on the way.
After nearly a decade of enjoying the hell out of the sound of my 7 channels of Hsu Research horn bookshelf speakers, I've decided to switch it up while downsizing much of my setup. I've enjoyed the warm sound of the SVS satellites in my office 5.2.2 so much that I've decided to swap out the sides and rears in my main viewing/listening space with a couple pairs of these, while swapping out the from stage with SVS's Ultra bookshelves and center. I'm excited to demo these in my space and try something new.
Reflex-Arc is online now   Reply With Quote
Old 12-30-2020, 12:55 PM   #11143
Badler
Member#: 133597
My Dad had this as well. Brings back some feels.
Old 12-30-2020, 06:59 PM   #11144
vapore0n
Member#: 21356
2017 Subaru Corolla
STI Limited SE-R Type (R)
Step one: pass all cables through the wall
Step 2: go to Amazon and purchase the Banana plugs, because you forgot
vapore0n is offline   Reply With Quote
Old 01-03-2021, 02:22 PM   #11145
BigWrecKs
Member#: 93830
Hey guys, looking for some suggestions. Recently got a new XBOX and looking into replacing my existing 50" 1080 LED with a modern 55". Went to Best Buy yesterday and almost walked out with a Samsung Q70T as it was rated pretty well for the price, however it was out of stock. The salesman pointed me to an LG CX series, which was significantly more expensive (1,450ish) but had great ratings and it was OLED--also out of stock.
He mentioned the TV manufacturers are gearing up to release this year's new sets. I saw Samsung is releasing its new Quantum Dot technology, which as I understand, is essentially its version of OLED. Thoughts on this? I'm not in a huge rush, but don't mind spending some $ on a nice TV. My use case is Xbox gaming, and Netflix movie/show watching in the bedroom, which is generally dark. I'll hang up and listen, thanks
BigWrecKs is offline   Reply With Quote
Old 01-03-2021, 02:52 PM   #11146
thechickencow
Member#: 16840
17 4Runner
Default The Home Audio/Video Thread
I have the Samsung Q70 and it’s great. I really like the interface of the smart features too. Buy it online?
There should be sales coming up pre-super bowl.
thechickencow is offline   Reply With Quote
Old 01-03-2021, 02:52 PM   #11147
Indocti Discant
Member#: 138000
Buy Nate's coffee
west coast roasting
Wait. Not many tvs are doing VRR and 4k 120hz well.
I think Reflex is enjoying his CX series - but I'd wait for the 2021 tvs to take full advantage of all that the Xbox offers. Did you get the series X?
Otherwise I'd consider Sony's 900h series, which are at costco
https://www.costco.com/televisions.h...2522Sony%2522|
Indocti Discant is offline   Reply With Quote
Old 01-03-2021, 03:43 PM   #11148
BigWrecKs
Member#: 93830
Yeah, series X
Old 01-03-2021, 04:20 PM   #11149
Psychoreo
Member#: 79643
2021 STI TE
Terminal black pearl
I have the LG C9. The CX uses the same panel and are both amazing. Absolutely don't regurt the purchase.
Related gripe: streaming services that don't support 5.1 through their browsers. Easy enough to download their app to the TV, but it's annoying.
Old 01-03-2021, 05:50 PM   #11150
vapore0n
Member#: 21356
2017 Subaru Corolla
Welp, so I did this
This is my weird rear speaker arrangement.
Moved all speaker wires inside wall
Surprisingly, the rear speakers sound really good once calibration is done.
Played some movies and the Polk sound very nice. Much nicer than the Sony Core they replaced.
Now to facespace to try and sell the old bookshelf speakers
The official Post pics of your Home Audio/Video setup? V2.0 GRUMPY514 Off-Topic 74 07-30-2008 09:50 AM
VA: Home Audio/Video/Game AspenWhite Non-Subaru Stuff 5 03-06-2007 09:43 AM
WRX parts, home Audio/Video stuff, and more... NicFunkadelic NESIC Private Classifieds 6 02-15-2007 10:38 AM
Home audio/video wiring gurus, need a bit of help. trail*of*dead Off-Topic 16 12-23-2006 02:25 AM
Home audio/video goodies for sale! Tivo! Replay! Pronto! BiggSean Private 'For Sale' Classifieds 7 02-26-2006 11:15 PM
