12-22-2020, 07:49 PM | #11101 |
Member#: 265783
RMIC
Vehicle:2017 Forester XT Niner ROS 9 |
Well in my research into a Bluetooth receiver for my 2 channel system, I learned two things: iPhones only use the lower quality AAC codec, vs the much higher quality aptX codec available on Android devices. Secondly, my “ancient” Airport Express’s 1/8” analog jack ALSO functions as a 1/8” optical toslink port. So I’m now streaming Youtube via AirPlay to the AE and going through my Topping D30 DAC optically, instead of using the crappy AE onboard DAC. Sounds awesome, has better resolution than BT, and I only had to buy a 1/8” toslink adapter and dust off my 12 year old AE to setup streaming on my 80’s preamp. This analog luddite is gettin’ fancy!
12-22-2020, 09:45 PM | #11102 |
Member#: 156229
MAIC
Decided to finally get a nice pair of headphones. I picked up some Hifiman Sundara with a Liquid spark amp.
This will be my first nice pair of headphones. Hopefully they are worth the hype. |
12-23-2020, 07:36 AM | #11103 |
Member#: 2973
MWSOC
Vehicle:2018 Camaro ZL1 1LE Red |
after just over 6 weeks my deftech BP9060 was repaired again yesterday. The shop kept it running overnight to ensure that it is still working this morning to avoid the situation last time where it died 2 hours after being repaired.
Once I get it back I have to make the decision to possible sell them and replace them with a pair of Monitor Audio Silver 500s or not (I don't think I can spring for the Gold 300s at this point in time.) If I do upgrade I'm going to need to pair them with a better amp for the output levels I tend to enjoy yet the amp I want is backordered until February https://www.starkesound.com/detail.html?id=47 |
12-23-2020, 09:15 AM | #11104 | |
Member#: 15934
MWSOC
Vehicle:2021 GTI Cornflower Blue |
Man, that store is impressive! They have a theater room display that's insane. There was a paper with all the components in the room, yeah it was a 480k room. |
12-23-2020, 09:56 AM | #11105 |
Member#: 15934
MWSOC
The 480k room:
12-23-2020, 12:23 PM | #11106 |
Member#: 138000
BAIC
Vehicle:Buy Nate's coffee west coast roasting |
those pixels are HUGE.
12-23-2020, 12:25 PM | #11107 |
Member#: 126425
SWIC
Vehicle:2021 Forester Sport Grey |
The mid-2000s called
12-23-2020, 01:39 PM | #11108 |
Member#: 157348
Vehicle:I Thlammed My Penith in the Car Door |
12-23-2020, 01:53 PM | #11109 |
Member#: 15934
MWSOC
That lumpy grid, I believe, is the optional Planar Video Matrix TV Display for 80k more!
12-23-2020, 03:45 PM | #11110 |
Member#: 6030
Tri-State
Vehicle:04 Gold FXT 07 WRB FXT Sport |
With a $699 Sony 4k blu-ray player feeding it all!!
LET'S GO!!!!! |
12-23-2020, 04:01 PM | #11111 |
Member#: 15934
MWSOC
12-24-2020, 09:43 AM | #11112 |
Member#: 2973
MWSOC
curious for other folks out there running either external DACs or other form of analog input to a modern AVR:
When I disable processing on the analog input (bypassing room correction and also bypassing an analog to digital and then back to analog processing chain, basically just amplifying the unmolested analog input) I get no output to my subwoofer. Curious if anyone else has seen similar behavior on other AVRs with a "pure" mode for analog inputs? |
12-24-2020, 10:49 AM | #11113 |
Member#: 2973
MWSOC
and after a little bit of research, I find this is all by design since an AVRs bass management is done exclusively in the digital domain, in order to get a signal on the LFE output, the source signal has to be converted to digital, processed, then converted back to analog again. I guess I'm sunk unless I employ a splitter on the source and a switch on the sink significantly complicating the wiring. Interesting.
12-24-2020, 11:06 AM | #11114 |
Member#: 21356
NESIC
Vehicle:2017 Subaru Corolla STI Limited SE-R Type (R) |
Maybe your AVR sets front speaker audio only when you set "pure" mode. Expecting you to have proper large speakers as fronts.
Ive seen my Sony 1080 do something like that, but I just use the normal 2.1 speaker setup for audio. 5.1.2 for classical music though. edit: late reply I was purchasing in wall speakers to use as rear surround. The bookshelves I had on stands occupy too much space of my small and weird living room. I promised the Ms Id put in wall to make it look much nicer, plus wire inside wall the fronts too. Clean up that wire mess behind the TV. Incoming Polk RC85i to replace my Sony Core bookshelf |
12-24-2020, 11:50 AM | #11115 | |
Member#: 2973
MWSOC
I do have full range fronts but it is annoying to have my $2300 sub just sitting there doing nothing but enjoying the ambiance. :-P |
12-24-2020, 01:06 PM | #11116 |
Member#: 90804
SCIC
Vehicle:2021 Ascent 2012 Accord |
That's the point of "pure" mode?
12-24-2020, 01:11 PM | #11117 |
Member#: 2973
MWSOC
12-28-2020, 06:00 PM | #11118 |
Member#: 21356
NESIC
I just received the Polk Audio RC85i in wall speakers to replace my rear surrounds that were in stands.
Jesus, I should have measured prior to purchasing. I went from 5" to 8" (woofer) Will report on how the aim-able tweeter works for my case. Left speaker will be in a rear wall parallel to the seating area, right speaker on a wall perpendicular to the seating area. I got no other place to put them. The current ones I got sounded great in those positions though. |
12-28-2020, 07:56 PM | #11119 |
Member#: 138000
BAIC
12-28-2020, 10:22 PM | #11120 |
Member#: 30733
TXIC
Vehicle:2007 tiny car striped |
Its actually kinda hard to do high pass on fronts with delicate audiophile sensibilities in tact. Almost everything will do this in dsp, which means an extra cycle of ADC to DAC. I am happy doing this with a minidsp for my sub but apprehensive on mains so run them full range.
Comercial subs should have the low pass filter and phase adjustment built in so you can run a pre out right to it, but I could see it getting tricky if you want 2.1 with room correction enabled and are unwilling to let the avr convert analog sources or perform primarily music dac functionality. I have used mini dsp nanodigi as well where you can implement a crossover) in line with the digital coax and then use 2 decent dacs (one for mains and one . Works well but too many boxes for me. Not really a home theater guy. I thought the common solution was to use an integrated or pre with a home theater bypass but can this hand over the sub channel to the avr along with the mains? |
12-29-2020, 08:48 AM | #11121 | |
Member#: 2973
MWSOC
what I'm thinking I can do is run some sort of RCA signal replicator (1 into 2) so I can have a pair of cables out to the sub and to the receiver, then run LFE to the sub as well, with 3 RCA cables into a switch before the sub, (L+R, LFE). Problem is there aren't many 2 input RCA switches with RF control these days. Seems almost more trouble than it is worth. Signal quality gains of bypassing the ADC->DAC of the receiver is sort of offset by losing room correction since uncorrected I have some 10-12db peaks. Cabling will get a bit easier when i get a new amp for L+R since I can run XLR from the DAC into the Amp, and RCA From the DAC into the sub. (DAC outputs simultaneously on XLR and RCA.) I spose the definition of "more trouble than it is worth" is pretty much the tagline of audiophile BS. |
12-29-2020, 12:41 PM | #11122 |
Member#: 30733
TXIC
Mini dsp 2x4hd will do exactly what you want if you dont mind the extra ADA cycle for the sub on 2.1
Use it to sum l and r pre outs to mono, apply eq to get rid of peaks if you want, and then plug analog out to other sub input. You can switch it in or out with IR remote. |
12-29-2020, 12:47 PM | #11123 | |
Member#: 2973
MWSOC
12-29-2020, 02:40 PM | #11124 |
Member#: 90804
SCIC
you guys are doing this analog thing all wrong:
12-29-2020, 02:57 PM | #11125 |
Member#: 2973
MWSOC
Similar Threads | ||||
The official Post pics of your Home Audio/Video setup? V2.0 | GRUMPY514 | Off-Topic | 74 | 07-30-2008 09:50 AM |
VA: Home Audio/Video/Game | AspenWhite | Non-Subaru Stuff | 5 | 03-06-2007 09:43 AM |
WRX parts, home Audio/Video stuff, and more... | NicFunkadelic | NESIC Private Classifieds | 6 | 02-15-2007 10:38 AM |
Home audio/video wiring gurus, need a bit of help. | trail*of*dead | Off-Topic | 16 | 12-23-2006 02:25 AM |
Home audio/video goodies for sale! Tivo! Replay! Pronto! | BiggSean | Private 'For Sale' Classifieds | 7 | 02-26-2006 11:15 PM |
