05-22-2020, 05:01 PM | #1 |
Member#: 490225
Ceramic Coating WRX Process
video showing how she ceramic coated her Subaru.
https://youtu.be/8iL8l-2tpXo
05-25-2020, 07:24 PM | #2 |
Member#: 514651
How much does it cost for the material?
05-26-2020, 08:02 AM | #3 |
Member#: 138957
MAIC
Vehicle:2016 WRX STI Limited DGM |
Costs vary depending what you already have, need and desired outcome vs current condition. If you have nothing, I would say average is ~$500 for DIY. A good chunk of that is stuff you can reuse though (microfiber towels, wash materials. buffer).
05-29-2020, 04:28 PM | #4 |
Member#: 514651
Thanks for the info. Where do you usually get the ceramic coating from?
05-29-2020, 05:16 PM | #5 |
Member#: 138957
MAIC
I usually purchase my stuff from Sky's the Limit (CarPro USA) and DetailedImage. They both have amazing customer service and prices are pretty good.
05-30-2020, 08:35 PM | #6 |
Member#: 204966
Vehicle:2021 Quadrifoglio |
Now lemme tell ya somethin' boys, just s'more snake oil. No true' coat is gonna keep ur car from the real abuse that she deserves!
Get urself' a patina' goin. Some wear n tear as they say, I don't believe in that garagin' stuff. Get er' out there and smack er' around a bit ! |
06-05-2020, 10:14 AM | #7 |
Member#: 461015
Vehicle:2017 WRX |
I bought 100ml of CQuartz UK and a bottle of Reload for $150 shipped from Autogeek, plus a $20 gallon of wax and grease remover. I had all the other materials and equipment for detailing already, but if you dont you are looking at probably $300 more at least to do it right. So far the Cquartz has done a single coat on my 350z and a full coat on the WRX plus windows and second coat over most of the car, and I should have enough left to coat my truck as well (at least I hope so). If you have the materials and know the process you can coat your car for fairly cheap. It is definitely worth it.
07-03-2020, 11:03 AM | #8 |
Member#: 516337
thanks for sharing! I ceramic coated my car a few months ago, and the water beading and all that is great, but I also have to street park it in an area with a ton of street trees.
Warning! When it rains, all of those trees block the wind and none of the water sheets off, so it just sits there and collects pollen and particles. By the time the waters evaporated, you can literally see green pollen outlines of where those water beads were sitting!!!!! |
07-07-2020, 02:30 AM | #9 |
Member#: 490225
did anyone try ceramic coating their car all on your own?
07-07-2020, 01:15 PM | #10 |
Member#: 138957
MAIC
07-07-2020, 01:47 PM | #11 |
Member#: 512654
Vehicle:2019 wrx red |
ive done it. not difficult, but as mentioned above tedious if you want to make sure you dont have any issues. if you are a fairly methodical person, you can handle it. if you are not methodical or well organized, id probably take a pass on trying it.
07-21-2020, 08:24 AM | #12 |
Member#: 516299
Vehicle:2019 STI ISM |
11-10-2020, 02:50 AM | #13 |
Member#: 520180
Vehicle:2016 Toyota |
12-30-2020, 12:14 PM | #14 |
Member#: 521316
How is the coating holding up?
12-30-2020, 01:01 PM | #15 |
Member#: 504432
Tri-State
Old thread but you should never reuse microfiber towels used for a ceramic coating application. The ceramic binds to the fibers and scratches the paint.
12-30-2020, 01:43 PM | #16 |
Member#: 138957
MAIC
??? I didn't say to reuse the towels used to level the actual coating. You will need towels for drying, polish removal, ipa wipedown, topcoat (sacrificial layer) leveling, etc etc etc that can be reused.
12-30-2020, 01:49 PM | #17 |
Member#: 504432
Tri-State
Of course you didn’t. You also didn’t specify either way, in a thread that seems to be a noob magnet. You clearly know what’s up, but some of these other guys don’t.
01-01-2021, 10:06 AM | #18 |
Member#: 516299
01-01-2021, 11:16 PM | #19 |
Member#: 512869
I wonder how often you should ceramic coat a carbon fiber hood? I have one in Chicago and I feel scared its gonna get messed up somehow with this crazy weather.
01-02-2021, 12:42 AM | #20 |
Member#: 138957
MAIC
It depends, there's too many variables to give you a straight answer. If you already have it coated, then just wash it using a good shampoo with no additives (Carpro Reset) and it should last 2 years or more. Don't need to overthink it or worry too much.
01-03-2021, 11:32 AM | #21 |
Member#: 516299
I agree with sebhockey, proper prep and then maintaining the coating afterwards and it will last a few years. Worst case do it again, the hood is a relatively small flat surface and wouldn't take alot of time like doing the whole car.
01-05-2021, 10:21 AM | #22 |
Member#: 516724
Ceramic Coating
01-07-2021, 05:53 PM | #23 |
Member#: 521515
I haven't heard about ceramic coating before
Even though I hadn't heard about ceramic coating, it sounds interesting. Not what I imagined once I looked it up. Wonder if/how it wears off.
01-12-2021, 10:45 AM | #24 |
Member#: 521623
wears off like any other coating over time. It bonds with the paint and fills the voids but it is just a coating and eventually wears off. Think of it like a better bonding wax over time the layers rub away.
01-12-2021, 11:15 AM | #25 |
Member#: 481754
Vehicle:2017 STi Base Black |
For those that did it themselves did you do it in a garage? I looked into it and some said you have to let it sit overnight without water sitting on it. Not sure how to pull that off given the trees over my driveway and the dew every morning.
