06-01-2020, 09:08 PM | #426 |
Member#: 211294
I don't have the 2019 amp so I'll see if I can make it work with the 2018.
06-02-2020, 12:42 AM | #427 |
Member#: 265148
Vehicle:2016 WRX White |
06-02-2020, 08:59 AM | #428 |
Member#: 211294
I did source one out but he was not selling it but was nice enough to provide me with pictures.
06-02-2020, 10:16 AM | #429 |
Member#: 265148
06-06-2020, 12:57 PM | #430 |
Member#: 490337
I wired the harness and installed the headunit and it seems to be working.
This is my setup: 2016 WRX with OEM HK/NAV New HU: 2019 "PHONE" headunit (nomn-hk/nav) Axxess TYTO-2 Custom harness from Autoharnesshouse 2019 USB hub Working: - Audio (front, rear, fade, balance) - Radio, XM, Bluetooth - Apple Carplay - Bright signal (dims with headlights) - OTA firmware update - Radio turns on and off with car turning on and off - OEM microphone - Back-up cam (however does not have lines) - Steering wheel controls* *I have not yet installed the 2019 steering wheel buttons, but the current buttons work but just do the wrong thing, so I am assuming there will not be an issue here Not tested: - Android Auto (don't have android phone) - Speed responsive volume Not working/issue/caveat: - the dimmer dial does not change the display brightness, the headlights on and off work for dimming the screen, but the fine tune adjustments doesn't work, but you can adjust it in the software, so no big deal - you will lose OEM nav - when the radio is on but muted there is a very slight hum from speakers, I did not notice this wth the engine on, I only noticed it when the engine off in the garage, so I do not think it will be noticeable while driving - i have a 2016 which was pre-telematics module, I do not know how that would work with this Installation notes: - overall pretty easy - had to soldier/crimp wires from the Axxess harness to the harness from Brian - no splicing on the car, easily can return to 100% stock I will report back after testing it for a week or so and see if any issues pop up. As far as detailed instructions, let me know if anyone is interested and I can go into more detail on how to make the harness. |
06-06-2020, 08:58 PM | #431 | |
Member#: 211294
Great news. Glad to hear. Waiting on my harness from Brian to start my testing. |
06-07-2020, 12:10 AM | #432 |
Member#: 265148
06-07-2020, 03:27 PM | #433 |
Member#: 507139
Turns out my Android Auto issues were (are) phone related, swapped back for a couple days to my Pixel 2 and not a once have I had the "connectivity"issue, works correctly every single time I plug it in. As far as the sound difference, yes I had to "retune" it for the new head unit software, this one seems "flatter" which is actually a good thing. Thanks again for providing the update for my head unit. Only thing left stock in my car, audio wise, is the radio itself, no speakers or wiring were reused for the system I installed. May in the future replace the radio but gonna have to wait a bit for that.
06-08-2020, 10:27 AM | #434 |
Member#: 211294
06-09-2020, 12:37 PM | #435 | |
Member#: 265148
I was able to source a 2019 MAP Radio and HK Amp myself. I made sure to ask the junk yard to include pigtails so that I could build my own harness. Undecided if I will be tossing this in my Crosstrek or WRX but I will report back with a detailed post after I get everything working. I have a pretty busy summer so it may be weeks or even months but I will report back. |
06-09-2020, 02:49 PM | #436 | |
Member#: 490337
06-11-2020, 11:49 AM | #437 |
Member#: 515523
How much does the new head unit cost? When you put a new head unit in does it take special programming to match it to the computer or any security features?
06-11-2020, 02:51 PM | #438 | |
Member#: 490337
Once everything was installed there is no special programming or security issues. Everything works as it should. |
06-12-2020, 12:16 AM | #439 | |
Member#: 265148
06-12-2020, 08:39 AM | #440 | |
Member#: 490337
If you live in the Dallas/Ft Worth area, I am happy to do it for you. Otherwise, call around to various private shops. I am sure you could find someone to change 0.5-1 hrs of labor. I used this video: |
06-23-2020, 11:15 PM | #441 |
Member#: 265148
Just wanted to give a little progress update. I've been building a harness the past couple nights. My plan is to put it in my Crosstrek but the problem was the 13-17 XV's never came with Harman Kardon audio as an option. To solve this I'll be building an adapter harness to re-map the wires. Everything will be soldered and heat shrink wrapped. This harness will require ZERO cutting or splicing of my Crosstrek's harness so at any point the factory radio could be put back in.
This also isn't my first rodeo. Two years ago I built a similar harness for my father-in-law's Tacoma adding JBL Audio & Amp to a truck that did not have it from the factory. I documented that here if anyone wants to read. I'm following the same process and logic to build this harness. Night 1 Night 2 |
06-29-2020, 09:12 PM | #442 |
Member#: 211294
I might have narrowed it down to the 10 pin connector as my issue. When i only have the 10 pin connector plugged in i get full sound from the 2018 HU and not the 2019. There is no differences from what i can see in the diagrams. Any suggustions? I will see what the multi tells me on the amp side later on in the week.
07-05-2020, 11:39 AM | #444 | |
Member#: 265148
07-08-2020, 04:14 PM | #445 |
Member#: 358745
Vehicle:2017 Subaru WRX World Rally Blue |
Any chance anyone has this 2019 radio that they are looking to sell? I am itching to do this upgrade.
07-09-2020, 03:37 AM | #446 |
Member#: 490151
Vehicle:2018 WRX STI Limited Ice Silver Metallic |
What is the part number for the 2019 HK+NAV Head Unit that you sourced? What model/trim did it come from? I'm assuming it was from a USDM car since it has the telematics unit. Thanks.
07-09-2020, 07:59 AM | #447 |
Member#: 516262
South East
Vehicle:2020 STi Series.White |
Not trying to hijack but Subaru claims that 2020 wrx/sti's have wireless apple carplay, but that is definitely not the case. Anyone else confirm?
07-09-2020, 09:16 AM | #448 | ||
Member#: 265148
The 6" & 7" PHONE button radios are all over eBay. |
07-09-2020, 09:29 AM | #449 |
Member#: 438030
07-09-2020, 09:30 AM | #450 |
Member#: 358745
Does anyone know the part number for the 2019 non-HK 7in radio with CarPlay? My 2017 is a base model
