02-16-2020, 01:14 AM | #1 |
Member#: 510928
Vehicle:1979 DL Red |
1979 DL Swap EJ22T
So I have been working on this for a couple months now. I will do my best to keep it updated. I have a 1979 subaru wagon. I am putting a EJ22T from a 91 legacy with a 5speed into my wagon. Including full drive train. Its definitely a project. Here is a link to my photos. I will update them when I have more along with adding them to this post.
http://s38.photobucket.com/user/88ub...bile%20Uploads
02-16-2020, 07:30 AM | #2 |
Member#: 110078
Vehicle:02 Bugeye JDM STi OBP BLACK |
Subscribed
02-17-2020, 01:53 PM | #3 |
Member#: 13530
Vehicle:EA63 , EA81T, EJ20G, EJ205 |
Very cool! I've got a '75 4WD wagon that I plan to swap a 12A into, so I'm interested to see what you've got planned!
02-17-2020, 10:40 PM | #4 |
Member#: 510928
Working on the cross member right now. The left one is from the 79 and the right is out of the 91 legacy donor car. I am hoping to shorten the 91 x-member so I can use the power steering and then the mounting locations for the A arm's. If not the 79 x-member will need to be notched and re strengthened so the up pipe will be able to fit.
04-03-2020, 10:49 PM | #5 |
Member#: 510928
Custom X-member done.
Finally got my cross member back. Its started as a 91 legacy turbo cross member and was shortened to fit into the 78 frame rails. About 1 3/4 inches needed to be cut off of each side. Using the 91 legacy cross member will allow me to use the 91 suspension and the power stearing from the 91. I am able to use the stick motor mounts from the 91 also. It's a snug fit. But it doens fit. I'm going to have to notch the frame rails a tiny bit so the valve cover bolt doesnt sit on it. If anyone needs measurements or help. I would be happy to help. This project has been a handfull to say the least.
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] Last edited by Toh79DL; 04-03-2020 at 10:56 PM. |
04-07-2020, 02:19 PM | #6 |
Member#: 13530
The folks over at www.ultimatesubaru.org/forum would eat this up!
04-24-2020, 07:50 PM | #7 | |
Member#: 510928
04-24-2020, 07:52 PM | #8 |
Member#: 510928
07-08-2020, 11:17 AM | #9 |
Member#: 21676
Vehicle:RX 03Foz89RX85Brat RedBlackBlue |
Following...
Send me your log in info and user name for USMB, I'll see if I can get your account fixed (I'm a mod there) |
